Old 11-07-2006, 05:25 PM   #1
Lone Rider OP
Registered User
Oddometer: 25,130
What is the best glue for leather/leather?
Anybody know...experiences?
Lone Rider is offline   Reply With Quote
Old 11-07-2006, 05:39 PM   #2
Stromdog
Howl at the Moon
Stromdog's Avatar
Oddometer: 2,703
Gorilla Glue.
Stromdog is offline   Reply With Quote
Old 11-07-2006, 05:48 PM   #3
Lone Rider OP
Registered User
Oddometer: 25,130
Originally Posted by Stromdog
Gorilla Glue.
That was my guess.
I bought some (well, VR did) and it doesn't list leather or any textiles, and their website says it will ruin clothing.
What's their definition of 'ruin'?
I don't give a toot about discoloring, but disolving might be a tad different.
Old 11-07-2006, 05:51 PM   #4
hgulledge
Adventurer-of-sorts
Oddometer: 1,282
Ask a shoemaker. They use rubber cement, I think. Just apply to both surfaces and let it dry. Be sure to line them up when you put them together. You can't adjust them later.
HG
hgulledge is offline   Reply With Quote
Old 11-07-2006, 06:07 PM   #5
xtphreak
from B4 "adventure bikes"
xtphreak's Avatar
Oddometer: 7,963
barge cement
used to glue soles back on ..."
"...The Original Barge Cement; Cobbler's 1st choice for gluing rubber and leather. Used in the motion picture industry by grips and set decoraters.
All Purpose Cement for rubber, wood, leather, glass, cork, metal, plastic, plaster, paper, concrete, etc..."
I used Freesole
to glue the sole on my Oxtar Matrix boot back on about 4-5 months ago ... still holding good
"... Freesole® Urethane Formula Shoe Repair Urethane Formula Shoe Repair is a patented urethane rubber repair system designed to restore and rebuild all types of footwear. Unaffected by heat or solvents, FREESOLE cures to a flexible thermoset rubber product providing superior adhesion, wear resistance, flexibility and waterproofing. The highly concentrated formula has minimal shrinkage: thick repairs can be made with only one permanent application. Ideal for worn heels, toes, sole and ski delaminations and more. FREESOLE will not separate with repeated flexing. ..."
used both
both work
not affiliated with either
Do one thing every day that scares you. Baz Luhrmann
Women and cats will do as they please,
and men and dogs should relax and get used to the idea.
Robert A. Heinlen
Adventure is discomfort recounted at leisure. Flash / GSWayne
Chrome don't get ya home. Rob Nye
Stamp Out Hoplophobia in Our lifetimes.
1999 Tiger 885
1995 XT600E
xtphreak is offline   Reply With Quote
Old 11-07-2006, 06:14 PM   #6
Lone Rider OP
Registered User
Oddometer: 25,130
Thanks, guy!
Good suggestions.
Old 11-07-2006, 06:51 PM   #7
rick danger
Off the wagon
rick danger's Avatar
Oddometer: 5,001
If you go with the gorilla glue I think they say to wet the surfaces some. Is it something you can rivet?
'08Husky TE 610 '07 R12GSA '07 KTM 950sm '92 GOLD WING '77 HUSKY 390 CR '72 Honda xl 250 '71 Honda sl 125 '79 HUSKY390cr '75 Can Am 250 MX-2 '70 Honda CT 70
'05 R12GS.....R.I.P. (rest in pieces)
rick danger is offline   Reply With Quote
Old 11-07-2006, 06:55 PM   #8
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,744
Tell me what it is your trying to do maybe I can help.
Seats www.renazco.com
Parts & Accesories www.renazcoracing.com
Renazco is offline   Reply With Quote
Old 11-07-2006, 06:58 PM   #9
Waco
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,972
Are you depending on glue to keep a layer of leather between you and high speed pavement?
Support the AMA.
Waco is offline   Reply With Quote
Old 11-07-2006, 07:24 PM   #10
luckyduck
Lost
luckyduck's Avatar
Oddometer: 54
Barge cement is the absolute best to use. I am a shoe maker and that is what I use if it is not going to be stitched as well. It is common to make a shoe by gluing the leather around to the sole with no stitching or mechanical means of holding the top to the bottom using barge.
Hints to happy gluing:
1. Have plenty of ventilation. The toluene in barge will knock you out.
2. Overlap the 2 pieces by at least 1/2 inch for enough surface area to bond well.
3. Wet both pieces with the glue. Put on 2 coats if you don't use contact cement regularly. Let it dry until you can touch it and it isn't sticky.
4. Press it together (if you just set them together, you can get them back apart) and pound the shit out of it. The pounding together really makes it stick.
Good luck. I use Barge by the gallon and it really sticks.
Paul
"My mother always told me you had to be very smart or very pleasant to succeed. I tried smart for 35 years, pleasant is much better." Elwood P. Dowd
luckyduck is offline   Reply With Quote
Old 11-07-2006, 07:40 PM   #11
Lone Rider OP
Registered User
Oddometer: 25,130
The sitching gave way on the inside half of the heel on one of my Contour Plus boots. There's the boot leather itself and then the outer cap that covers this, like an elongated 1/2 moon. It's here, not on the heel. The boot has an inner lining that I don't want to compromise with a local cobbler shop..
I can send it off and maybe have it covered and fixed under some kinda BMW warranty, but I don't want the aggravation and wait.
1 year of use.
Old 11-07-2006, 07:43 PM   #12
Lone Rider OP
Registered User
Oddometer: 25,130
Originally Posted by luckyduck
Barge cement is the absolute best to use. I am a shoe maker and that is what I use if it is not going to be stitched as well.....Paul
Good stuff, Paul, thanks a bunch.
I figure I'm gonna have one good shot at it.
Old 11-07-2006, 08:01 PM   #13
xtphreak
xtphreak's Avatar
Oddometer: 7,963
on my Oxtar Matrix (GoreTex liner) the molded sole was pulling off at the toe
I cleaned it with alcohol and filled the void with Freesole (my Barge Cement was like a rock) pressed it together and secured with duct tape
the package says it cures faster in a humid environment, so I stuck it in a trash can with a damp towel over the top.
next day it was set and it shows no signs of letting go
ureathane is tough stuff
also Dow Corning 5200 is what I caulked boats with below the waterline, 4200 above
4200 isn't as strong, but it lasts a few years in salt water and is a little more flexible than 5200
Robert A. Heinlen
1999 Tiger 885
1995 XT600E
Old 11-07-2006, 08:13 PM   #14
Lone Rider OP
Registered User
Oddometer: 25,130
I'll try something similar tomorrow.
I don't want to pry the layers too far apart, but do want to clean/prep them. Alcohol is a good idea and q-tips are cheap.....
I'll probably do duct tape too because I ain't gonna stand still in the boot for 'x' hours.
As the guy at the gathering said to the young stoopid fcker, before he found the lady wearing stockings....urethane.
Old 11-07-2006, 09:02 PM   #15
Mully
Kineticist
Mully's Avatar
Oddometer: 3,757
I've had really good results with "Shoe Goo". Fixed my BMW Gore-tex boot seams, and otherwise I'd have had to throw them away.
mully
Mully is offline   Reply With Quote
Times are GMT -7.   It's 01:57 AM.
