Old 11-10-2006, 05:53 PM   #1
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 8,307
Look what I got today...
Funny what you can buy for $XXXX these days...
All this stuff, (+ a new windshield and mirror) and the bike too!
Rapid Dog screwed with this post 12-03-2010 at 07:59 AM
Rapid Dog is online now   Reply With Quote
Old 11-10-2006, 05:56 PM   #2
Gezerbike
Hey Rocky...........
Gezerbike's Avatar
Oddometer: 3,016
Nice haul.....let me know when you are parting ways with that silly lookin' front fender.................
___________________________________________
Mike
1998 R 1100 GS
2007 K 1200 GT
Gezerbike is offline   Reply With Quote
Old 11-10-2006, 05:57 PM   #3
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,307
apperas cleaner than she is...
Old 11-10-2006, 05:58 PM   #4
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,307
super cooler...info appreciado on this piece...
Old 11-10-2006, 05:59 PM   #5
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,307
looks like this may be an aftermarket floater...yes?
Old 11-10-2006, 06:07 PM   #6
Gezerbike
Gezerbike's Avatar
Oddometer: 3,016
No....just looked at mine and they are the same. That is a nice oil cooler though....definately not the stock one. But the bag mounts seem to be from a newer GS....for that year I think they were black, And the Roo bar I think was red on that bike. But hell, for $ 2500 you made killin'. Does the bike turn over ? Any idea on the mileage ?
Mike
1998 R 1100 GS
2007 K 1200 GT
Old 11-10-2006, 06:12 PM   #7
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,307
ohlies
Shock is a little corroded but so is most of the bike's general surfaces, will take some hours getting here aprkly.
I'll be needing a right side switch pod, the owner crashed it and slammed the right bar into the tank (no dents!) and busted of the little switch in the bottom, don't know what it's for...
I'll need some OEM crash bars.
Can one but the tank and side panel stickers. scratched where the bars hit the tank.
Barbacks, I'll need a set of those for the Renthals probably.
Just nick nacks...and here's the kicker...I thought it was a real derelict...the thing started right up after a few revs...doesn't even need a battery!
Turns out the friend who's shop I got it from at one time had installed a spunkier cam in the bike...I couldn't believe my good fortune when he started it and it revved up real strong...the thing sounds tits!
Then he started pulling stuff out of the back of the shop that went with the bike...a set of street wheels that appera to be of a K bike, evidently bolt right up with a spacer...a Supertrapp exhaust (which I doubt I'll use), a set of bags, and a new windshield. sparkplugs...yadda yadda..
The GS gods are smilin' down on me...now where's that VIN ...gotta see if it really is a PD...
Old 11-10-2006, 06:16 PM   #8
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,307
uno mas
yep, black fenders and stuff make me suspicious, but I'll find out...evidently this bike has a history in Baja, the owner lived there for a while...had extra valve covers bolted to the rear rack even...
Only thing I have to do is fix a leaking oil color fitting and I can take it for a spin...
Old 11-10-2006, 06:24 PM   #9
RedRocket
Yeah! I want Cheesy Poofs
RedRocket's Avatar
Oddometer: 17,777
As long as it don't blow up it looks like you scored.
RedRocket is offline   Reply With Quote
Old 11-10-2006, 06:27 PM   #10
Gezerbike
Gezerbike's Avatar
Oddometer: 3,016
If you do opt for the high fender, Acerbis makes one with the vent, which you'll need, for $ 90. The oil cooler conversion kit runs $ 175. And since it popped right over, you are WAY ahead of the curve on this bike. From you pics, does the Supertrapp have a y pipe that would allow you to use that along with the stock exhaust can ?
Mike
1998 R 1100 GS
2007 K 1200 GT
Old 11-10-2006, 06:41 PM   #11
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 7,934
Congrats! The bike is a score for $2500.
I have a right side switch I'll sell you for 1/2 the new rate, and I'll pay the shipping.
Make sure to have your Ohlins rebuilt... if it has been sitting and oxidizing alot 9esp the shaft), using it culd possibly cause issues, and these suckers are spendy to rebuild when worn out.
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 11-11-2006, 01:23 PM   #12
camgregus
riding gently now
camgregus's Avatar
Location: on the banks of the mighty mississippi, AR side
Oddometer: 2,945
do you want to sell the extra crash bars?
camgregus is online now   Reply With Quote
Old 11-11-2006, 01:40 PM   #13
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,307
yep
I'll take that switcheroo for sure.
The part that's mushed is the little switch that's between the sart button and the turn signal (right side)...nmaybe the horn? Anyhow I know you have to replace the whole unit.
The crash bars I'll let go of too....not sure who makes them but they appear to be J.C. Whitney in quality. Just pay for shipping and make a donation to my GS fund ;)...
I'll hold on to that fender at leastr for a while.
THe high fender I'd like to get. Not sure how it mounts or if there will be a clearance issue with the oil cooler location, that and the horn resides up there too byt could be relocated. Insight on the fender dealie appreciado...
The driveline appears solid. Chink in the armor appeasr to be the front end is tweaked a good 3-5 degrees. I'm going to looosen all the pinch bolts and try and bounce it around to see if it pops back in place....if not I may be in the market for a set of forks...
Old 11-11-2006, 02:16 PM   #14
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 7,934
PM me if you want my spare right side switch, it is held in by one or two screws, very easy to remove.
If your forks are bent, the hot ticket is "forking be Frank", he sells OEM replacement legs for much less than stock.
Also, I would suggest buying a manual and immediately doing a spine lube. Instruction for this can be found at www.ibmwr.org in the r-bike tech section.
SL
QUOTE=Rapid Dog]I'll take that switcheroo for sure.
The driveline appears solid. Chink in the armor appeasr to be the front end is tweaked a good 3-5 degrees. I'm going to looosen all the pinch bolts and try and bounce it around to see if it pops back in place....if not I may be in the market for a set of forks...[/QUOTE]
Old 11-11-2006, 06:12 PM   #15
Scary Mc
hellgrammite
Scary Mc's Avatar
Oddometer: 3,709
Sweet meat!
It's a friggen motorcycle, it's not supposed to be comfortable, quiet or safe. The windnoise is supposed to hurt your ears, the seat should be hard and riding it should make you shit your pants every now and then.
Scary Mc is offline   Reply With Quote
Times are GMT -7.   It's 11:49 AM.
