11-15-2006, 09:06 PM
#1 |
Pawn Star
Oddometer: 992
Strom front wheel removal
Hi all
I have read a couple of strommers report on a cheap tool they bought at Sears to remove the front wheel, please could someone put a pic of this tool here so i know what to get? Is there anywhere i could order this over the net? many thanks
I'm your IceCreamMan stop me when i'm passing by!! |
11-15-2006, 11:37 PM
#2 |
n00bilicious
Oddometer: 1,290
Also interested here too. Time to put a new tire on :) Whats the sears part #?
11-16-2006, 12:11 AM
#3 |
Kumbaya my ass
I just bought a 12mm hexkey over at Orchard Supply Hardware. Took me 6 stores and 2 hours to find it.
Went to Lowe's, Home Depot, Kragen, PepBoys, Orchard and Sears. Largest one any of them carried was a 10mm. Finally decided to go to a different Orchard and buy a 12mm hex bolt, 3 nuts and improvise a hex key. Found the 12mm hexkey hanging in the metric bolt section. Orchards PLU # 9332750
"Honor does not need to defend itself nor does Valor need to fly a pennant to say 'I am brave'. This is Pride mistaking itself for Virtue." |
11-16-2006, 03:31 AM
#4 | |
The Gimp
Oddometer: 781
Dave |
11-16-2006, 04:29 AM
#5 |
ultra runner
Oddometer: 5,866
I bought a 12 mm allen wrench at sears for about 6.00$
the 12mm is what you want, go to sears first..
11-16-2006, 04:45 AM
#6 | |
Joe 40 ouncer
Oddometer: 15,234
11-16-2006, 05:28 AM
#7 | |
Ridin' all I can
Oddometer: 925
11-16-2006, 06:50 AM
#8 |
Pawn Star
Oddometer: 992
thanks all , i was fooled by the term"hex key" .... which is an allen key as i have now learnt.
Will look for the 19mm (as i have a 1000) , cant recall ever seeing one but who knows mebbe i get lucky. Many thanks
11-16-2006, 07:09 AM
#9 |
Michelin Man
Why isn't this tool in the toolkit?
11-16-2006, 07:32 AM
#10 | |
Oddometer: 3,850
"Deeply flawed people make deeply flawed decisions." |
11-16-2006, 09:16 AM
#11 | |
get in or go in
Oddometer: 12,995
or get a bolt with a 12 mm head and a few nuts on it locked on...to put in the allen head......? BTW I did 2 weestroms last night..FYI for the DL650 IIRC front axle torque 42 ft lbs...12mm hex (allen head) front axle pinch bolt 16 ft-lbs 12 mm bolt brake caliper bolts...26 ft lbs...?..forget...14mm?..
.... wait til you get younger to chase your dreams...... |
11-18-2006, 11:36 AM
#12 |
Oddometer: 1,318
Actually it is 3/4". I used a bolt with a 3/4" head, put jamed a couple of nuts on it, and it works great.
En el pais de los ciegos, el tuerto debe tener cuidado. |
11-18-2006, 11:55 AM
#13 |
Humble Adventurer
Oddometer: 15
Torque It
You need to get the socket/hex setup so that you are able to torque the wheel when you put it on. I have both, picked up the 12mm hex wrench at sears on the clearance rack for around $5. The 1/2" drive setup I ordered through a napa store for about $15.
You can find them cheaper but you get what you pay for, the cheaper ones will twist (softer material). Better tools come with Peace of mind when adventure touring. |
11-18-2006, 04:20 PM
#14 |
Freeeeze
Oddometer: 1,037
Took a craftsman spark plug socket, turned it around, the outside wrench flats were the right size for the front axle on my 1000. Put a short extension through the socket and used my wratchet to do the job.
done |
11-19-2006, 10:30 PM
#15 | |
squirtin dirt
A cut down spark plug socket. I cut it down so I could put a small extension into the sparkplug end and still fit it in a 3/8" drive ratchet. I had several old sparkplug sockets around and just sacraficed one to keep on the bike. (yes... I carry a 3/8" sliding T-bar too) |
