Old 12-28-2006, 07:58 PM   #46
bemiiten OP
League of Adventures
bemiiten's Avatar
Oddometer: 4,938
The intermediate shaft was placed in the freezer while I heated a 1" set collar on top a kerosene heater. The manual shows pulling the bearing with a puller, but I decided to do the removal with a press instead. I removed the frozen shaft and placed it on top of the heated set collar to warm the bearing for a few minuets. I installed the bearing clamp and put the assembly in the press. The clearance between the gear and bearing is extremely tight. As soon as the bearing moved a little , the clamp was tightened to allow a better bite. The freezing and heating paid off when the bearing came off nicely without excessive force.
bemiiten screwed with this post 12-28-2006 at 08:06 PM
bemiiten is offline   Reply With Quote
Old 12-28-2006, 08:31 PM   #47
bemiiten OP
bemiiten's Avatar
Oddometer: 4,938
The original failed intermediate bearings are from Japan. The replacements are from Poland. (same part#) The original output shaft bearings are from England, the replacements are also from Poland. (updated part#) All the bearings new and old measure the exact same thickness with the exception of the failed bearing that is .001" bigger. EDIT-After a more accurate measurement with a dial gauge, The bearings were indeed the same size. The caliper is sensitive to hand pressure and I'm sure that's the .001 difference). If you recall , this is the same bearing that did not want to come out of the housing during disassembly. I believe the 100+ miles the bike was ridden with the failed bearing may have distorted it somehow. The bottom line is all the bearings seem to be made to very tight tolerances. To my thinking, this means I am replacing apples with apples and their should be no reason to re shim the shafts, right?
bemiiten screwed with this post 03-22-2007 at 02:40 PM
Old 12-28-2006, 09:08 PM   #48
bemiiten OP
bemiiten's Avatar
Oddometer: 4,938
Wrong! After allowing the shaft to warm back up to room temperature, I'm showing a difference of about .007" shorter. The manual list a maximum difference of .002"
The manual gives no absolute overall dimension for the shafts, and no inside dimension for the trans case. Just a .002 figure that I assume is endplay. Without the factory jig ,I can only compare what I had to what I have now.
Here is the procedure I used for installing the bearings. I start by using a washer to absolutely guarantee that no force is exerted on the outer race.
I freeze the shaft and use a heat gun on the new bearings. When the bearings hit about 150 degrees, I carefully line up everything in the press. It is easy to feel when the bearing is fully seated.
bemiiten screwed with this post 01-22-2007 at 06:50 PM
Old 12-28-2006, 09:17 PM   #49
bemiiten OP
bemiiten's Avatar
Oddometer: 4,938
Next up is the output shaft. The bearings are removed along with the adjoining gears.
I follow the same procedure as before and wind up with similar results. About .006 shorter overall.
This should read zero , the bearings are the same size. ?? ?? One step I failed to take was making sure the old bearings were pressed fully home. It's in the manual ,but I neglected this step. It's the only possibility I can think of. I'm very confident the bearings are the exact same size.
bemiiten screwed with this post 01-22-2007 at 06:55 PM
Old 12-29-2006, 06:14 PM   #50
bemiiten OP
bemiiten's Avatar
Oddometer: 4,938
Up last is the input shaft. Like before, A comparison of old and new bearings show them to be exactly the same.
Old bearing
New bearing
bemiiten screwed with this post 05-01-2007 at 05:56 PM
Old 12-29-2006, 06:31 PM   #51
bemiiten OP
bemiiten's Avatar
Oddometer: 4,938
While inspecting the transmission engagement dogs on the other shafts, I could not help but be impressed at just how good the condition of these parts were. With the input shaft disassembled , The title of the thread comes back to haunt me one more time!
This can't be good!
This is the Thrust block. Check out that nice crack on the left ear! I suppose it could be just a gouge, but it extends to far to be from some debris getting in between the mating surfaces. It is on the power side. Their is just no way this can go back in.
Old 12-30-2006, 06:45 AM   #52
bemiiten OP
bemiiten's Avatar
Oddometer: 4,938
After 55k and one spline lube at 35k, The input shaft splines look like they have some life left in them.
The clutch disk splines look a bit worse
I decide that replacing just the disk will accelerate the wear on both parts with their mismatched matting surfaces, so it makes sense to replace both while the trans is apart.
Old 12-30-2006, 07:02 AM   #53
bemiiten OP
bemiiten's Avatar
Oddometer: 4,938
Their is allot of debate over the toughness of BMW's dry clutch. I don't abuse my clutch , nor do I hesitate to slip it as much as needed when the situation calls for it. Compared to a new disk , the friction material shows very little wear and in my case, would probably outlast the splines by a wide margin.
Old disk
New disk
bemiiten screwed with this post 12-30-2006 at 07:38 AM
Old 01-13-2007, 03:53 PM   #54
bemiiten OP
bemiiten's Avatar
Oddometer: 4,938
Still waiting on one last part. I figured I would post some pic's of the failed transmission shaft bearing.
Left one is the culprit. You can see that the sealed bearing is out of it's lubricant. The seal shows metal shavings from the failure. Middle one is same (made in japan) bearing as left, also looking like it has some shavings and not much of whatever it is they pack these with. I do see what looks like ,the red trans fluid on the bearing cage. Maybe the synthetic penetrates the seal and dilutes the grease? The last on right is a output shaft bearing made in England. Looks like it has much more lubricant left then the other two.
[IMG]Photobucket - Video and Image Hosting[/IMG]
bemiiten screwed with this post 01-13-2007 at 05:47 PM
Old 01-13-2007, 05:17 PM   #55
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,878
This is a great photo writeup I missed it until just now. Very nice as a late unopened Xmas present.
- Jim
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 03-21-2007, 03:27 PM   #56
PaleHearse
Road Ranger
PaleHearse's Avatar
Oddometer: 1,017
Looking forward to the punchline. Great work!
Photos of the finished trans would be very cool!
When dealing with people, it’s often important to remember 2 things.
1) Never attribute to malice those things that can more adequately be explained by stupidity.
2) Never attribute to genius those things that can be more adequately be explained by fortuitous chance.
PaleHearse is offline   Reply With Quote
Old 03-21-2007, 03:50 PM   #57
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,878
+1 Great work
(And look at all those effective Harbor Freight tools. hyd press, dial gauge, mag base, caliper)
- Jim
Old 03-21-2007, 05:31 PM   #58
bemiiten OP
bemiiten's Avatar
Oddometer: 4,938
Originally Posted by Poolside
+1 Great work
- Jim
I have had great luck with HF tools. The day I pick to assemble the trans , the brand new HF laser temp gauge crapped out. Then when I re borrowed the one pictured before, The brand new $10 heat gun went up in smoke mid job. Lucky I had two. Both were replaced by HF inc. shipping both ways.
Old 03-21-2007, 06:10 PM   #59
bemiiten OP
bemiiten's Avatar
Oddometer: 4,938
I noticed this little bite out of one of locating pin bores. The trans housing precludes setting your drift for a straight shot. Had to use a smaller 3/16 drift at a angle and it resulted in this. BMW must have a offset drift for this as I recall it didn't make sense to drive the pin from the opposite side. Anyway this picture is after I removed a small aluminum burr.
Old 03-21-2007, 06:17 PM   #60
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,233
Originally Posted by bemiiten
One big assumption here is that they were shimmed properly to begin with!
and
I guess I'm late to this party, sorry.
Don't assume anything is shimmed right. Every 6-speed I've worked on is loose somewhere. The manual I have does give shaft lengths but that doesn't mean much; I always check them the old-fashioned way (shaft protrusion vs. cover depth). I've measured a bunch of cases and covers and have a decent idea of what they should be. They're generally repeatable within about 0.05mm.
Again, none of the numbers mean anything. Measure your parts as if it were an Airhead tranny.
Times are GMT -7.   It's 04:54 PM.
