Old 04-04-2007, 03:43 PM   #76
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by bemiiten
Thank you and good night??? This bearing failure might have cost a additional $12,000 for a KTM 950 to hold me over until the parts came in.
In the end , I am assuming the failure stemmed from the bearing using up all it's lifetime lubricant.
Hella nice work. Many thanks for sharing the road trip
- Jim
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 04-08-2007, 08:31 PM   #77
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,071
So has enough time gone by to immoralize this thread into the HoW yet?
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 05-01-2007, 05:22 PM   #78
bemiiten OP
League of Adventures
bemiiten's Avatar
Oddometer: 4,969
2,500+ miles and nothing to report.
bemiiten screwed with this post 05-22-2007 at 01:49 PM
bemiiten is offline   Reply With Quote
Old 05-01-2007, 10:11 PM   #79
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,071
It's in the HoW NoW.
JJ
WingMakers.com
Old 11-07-2011, 12:06 PM   #80
Hootowl
Oddometer: 1,262
Originally Posted by bemiiten View Post
T]In the end , I am assuming the failure stemmed from the bearing using up all it's lifetime lubricant. [/INDENT]
What if the bearings were changed to non sealed type?
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is online now   Reply With Quote
Old 11-07-2011, 02:57 PM   #81
bemiiten OP
bemiiten's Avatar
Oddometer: 4,969
I've since read hear that the 1150s trans uses whats known as 'clean bearings'. They are indeed lubricated by the gear lube through tiny slots in the seal that act as a filter. As a result of the filtering , they are supposed to outlast the unsealed type. If that is all accurate, dunno, Maybe someone can confirm.
Old 01-02-2013, 04:09 PM   #82
NumberOne
NumberOne's Avatar
Oddometer: 26
Hi bemiiten and thank you for your experiece! I write from Italy, sorry for my english!!
I'll have to do your own work and the biggest problem will be shimming the shafts.
The first question is:
yor plan for shimming has been successful over time ?
Antonello
PS: my ADV : http://advrider.com/forums/showthread.php?t=793394
Ex Suzuki RF900RS2. Ex Honda Transalp XL650V. Today: BMW R1150GS Adventure 2003
NumberOne is offline   Reply With Quote
Old 01-03-2013, 05:13 PM   #83
bemiiten OP
bemiiten's Avatar
Oddometer: 4,969
Antonello
I've put over 30,000 miles on the bike since the rebuild with no problems. As far as I can tell the end play dimension is .000-.002. and getting a accurate enough measurement seemed daunting. Because the bearing went close to 50,000 miles before a failure, I was willing to roll the dice on the factory setup as opposed to basing my shimming on possible inaccurate measurements.
If the failure repeated or happened at a low mileage, I would disassemble the transmission. Confirm the old bearings are fully pressed on the shafts and then reassemble using plastiguage and go from their. Once I was satisfied the end play was in spec, measure the assembled length of each shaft and then re check the measurement once the new bearings are in place.
Another way is to measure from the edge of the case to the bottom of each bearing bore and add the two halves together and then compare to the assembled shaft length.
bemiiten screwed with this post 01-03-2013 at 05:29 PM
Old 01-03-2013, 10:08 PM   #84
vintagerider
vintagerider's Avatar
Oddometer: 1,962
Great thread. Many thanks to Bemiiten for his photos and contribution. Particularly appreciated are the photos of the bearings with covers removed and the brief discussion on mode of failure.
Bemiiten's bearings show no evidence of coagulated muck from "bad syns". Coagulation and resultant oil starvation is one failure mode alluded to by Getrag/ZWN development engineers in Kari Prager's translation of the coffe chat reprinted on Anton's pages. Regarding additives and presumably certain syns which are not miscible with yak grease, they say:
["We therefore rigorously recommend against their use"].
"Clean bearings" are not common in gear boxes and the refiners of most syn GL5's do not formulate for compatibility with yak grease. Nor is there any labeling convention that aids consumers in selection of a miscible lube.
I postulate that the grease is only there for initial lubrication. It must wash out fairly quickly with miscible hot oil. On the other hand, you'll likely encounter coagulation followed by bearing lubrication starvation if one of the cheap syn GL5's are used, even briefly. Once you have the coagulation I doubt that you can ever be rid of it w/o new bearings.
for sale: 1968 R 69 S-us original condition
vintagerider is offline   Reply With Quote
Old 01-04-2013, 02:41 PM   #85
NumberOne
NumberOne's Avatar
Oddometer: 26
Ithe end play dimension is .000-.002
mm??
plastiguage
Sorry, what for plastiguage?
Then, I'd like to know this: before measure the assembled length of each shaft, you have measured the backlash of each gear? From the manual 1 gear 0,1 - 0,33mm, 2 gear 0,1 - 0,33mm, 3 & 4 gear 0,1 0,67mm. It's right?
Old 01-09-2013, 06:18 AM   #86
NumberOne
NumberOne's Avatar
Oddometer: 26
Hey Bemiiten, abaut yor opinion, the gauge (difference) between cases and shafts, it will exactly zero or few (or one) tenths of a millimeter? My actualy gauge it's 0,108mm for center shaft, 0,133mm for output shaft, and 0,036mm for drive shaft (input shaft).
Antonello
NumberOne screwed with this post 01-09-2013 at 06:31 AM
Old 04-06-2013, 09:30 AM   #87
capnfranko123
Oddometer: 27
my tranny failed at 106000
pulled apart and the same bearing completely failed and chewed the end of the intermediate shaft. A friend/small bike shop owner had the shaft welded and ground like a crank and put 6 new bearings in. 116000 terrible noise and then the tranny seized. Now I need to replace. Aaarrg. living in an apartment too so I have to get a storage unit to do the work. I figured this would be a long process so I bought another 04 Adventure with only 48000 miles to ride while I work on my first one!!
capnfranko123 is offline   Reply With Quote
Times are GMT -7.   It's 10:46 AM.
