11-28-2006, 07:35 AM
#1 |
Oddometer: 4,912
Up-to-date: KTM 640 LC4 Adventure changes between model years
Hi guys,
Since I am looking at buying an LC4 Adventure again, I did a bunch of searches here and on other forums what parts exactely changed over the years. I found tons of info and many long threads (with too much BS in between). So I started compiling the info in one up to date place. Feel free to make suggestions for changes or add some new info, I will update the first post in the thread to keep it current. Cheers, Lukas 1997 620EGS-E Adventure All orange 609cc, low-slung twin silencers, Dell Orto Carburettor WP 50mm Extreme forks 17mm front axle 1998 Changed to 640LC4 Adventure R Orange and blue 625cc, high level pipe main stand 2000 Slightly different colour scheme (all blue seat, tank graphics 'reversed') Mikuni Carb Dual odometers 2001 New colour scheme (orange back, silver front) Opaque screen with flip was discarded in favour of solid colour, lower non-flip screen Adopted rear subframe/panels/fenders from 640LC4-E, new opaque screen USD 48mm front forks, front brake disc 320 mm (vs. 300) 2002 Slightly different colour scheme (the 'KTM' on the tank became black) New type of tripmaster incorporating coolant temperature and fuel 'low' warning (instead of Touratech IMO) Frame has a cast lug rather than a flattened tube on the lower right engine cradle to accommodate the easier access to the oil filter Fuel pump was moved to the area behind the cylinder 2003 New colour scheme silver and black 'High flow' cylinder head with 32mm exhaust valves vs. 30mm, dual curve CDI, new cam, hydraulic clutch, oil level window in primary drive cover, input shaft bearing changed from ball to roller, bigger oil filler screw on frame, oil pump drive ratios increased Slightly different fuel plumbing, 40BST carb fitted with a TPS Secondary air system (SAS or SLS) for "Euro 2" emmissons standard introduced to EU bikes Different primary drive gearing (changed from 30:81 to 31:79) Location of merge collector and elimination of separate cross-over, exhaust pipe (still high level) Location of fuses moved to battery tray area, 10A un-switched powerlet plug in dash More comfortable seat Assist tab added to center stand, structural change in swingarm "arms" and chain adjuster blocks, 2004 New orange colour scheme Low front fender Same front suspension as 950 Adv with twin front discs, foot brake pedal wider and fold-away, wider footpegs with new rubber inserts, Front left footrest bracket made from aluminum Black wheel rims (no longer pre-drilled for locks) Locking fuel cap, fuel tank capacity is quoted as 25.5L rather than the 28L for the earlier models SAS/SLS for US spec bikes Reinforced outer clutch hub, CDI with optimised ignition curve, changed the auto decomp components but not design 2005 New oil feed line to base of piston Smaller indicators 15mm handlebar risers Sintered brake pads, a new Brembo brake disc with round holes X-ring endless chain 2006 Canadian model has no SAS/SLS Behr rims improved (do not bend as easily but still not as good as Excel) Black powdercoated frame
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 LukasM screwed with this post 01-02-2007 at 08:46 AM |
11-28-2006, 09:11 AM
#2 |
Exchange your GPS Track!
Oddometer: 2,535
Love it,. I am also looking... very instructive.
11-28-2006, 10:22 AM
#3 |
Ignostic
Oddometer: 13,843
Austria uber alles. The Index needs a one-stop post for this kind of info, danke Lukas.
I will look over it later, but I am not the best at model year changes.
Kronreif Trunkenpolz Mattighofen LC4 640 Its not so much staying alive; its staying human that counts. |
11-28-2006, 11:52 AM
#4 |
GSDude was pwned
Oddometer: 494
Two other versions were also offered in 97:
1997 620 R / XCe (Electric Starter) 1997 400 R / XCe (Electric Starter) I test rode a 620 in 96 (no electric) ... had to drive to Michigan though. ![]() 1997 620 EGS - E Adventure was called an LC4... I still have the original brochure. "Innovatave features like side mounted extra fuel tank and spare tire carrier are all over the LC4 Adventure." |
11-28-2006, 02:06 PM
#5 | ||
Oddometer: 4,912
![]() Quote:
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
12-10-2006, 07:54 PM
#6 |
Ignostic
Oddometer: 13,843
Bump
been a few questions along these lines, and this ain't in the index, yet.
12-11-2006, 06:54 AM
#7 | |
making chips
Oddometer: 26,648
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012 *** Stenhouse Racing - Specializing in KTM Upgrades custom cnc service available to suit your specific needs. |
12-11-2006, 08:11 AM
#8 | |
Ignostic
Oddometer: 13,843
I need a block of time to do that, and a reorganization idea of mine... check's in the mail.
12-11-2006, 08:35 AM
#9 |
Oddometer: 4,912
I am on standby too if anybody has more or different info....
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 LukasM screwed with this post 12-11-2006 at 09:11 AM |
12-11-2006, 09:07 AM
#10 |
Guest
Oddometer: n/a
No SAS on my 06
My Canadian delivered 06 had no SAS system. Blanking plate between exhaust header where SAS would inject.
The Behr rims seem to be better for 06 as well. Still too wide on the front but less prone to bending. I've had 3 pinch flats and no bent rim which sounds a whole lot better than others have experienced. Blair |
12-11-2006, 09:25 AM
#11 | |
Oddometer: 4,912
For the Behr rims, I couldnt find anything official if they had changed them. Let me know if somebody knows more!
12-11-2006, 01:31 PM
#12 | |
Guest
Oddometer: n/a
Don't know if the 04 and 05's had the SAS. Will try to find out but they are pretty rare around these parts.
The Canadian rep told me on the phone that the Behr rims were fixed for 06 for what it's worth. He also told me when I bought the bike that the rims would be D.I.D. for 06 to put the information in perspective. Quote:
12-11-2006, 01:34 PM
#13 |
Registered
Oddometer: 427
My model 2000 has dual odometers in IMO (2001) and pre-drilled rims (2002).
Are you sure about the different tranny gearing in 2003? I thought that the difference is roller bearings instead of ball bearings. |
12-11-2006, 02:11 PM
#14 | |
Molon Labe
Oddometer: 6,286
Chris '03 KTM Adventure 640 '43 BSA M20WD |
12-11-2006, 07:20 PM
#15 | |
Location: Southern Ontario, Canada ( Niagara Peninsula )
Oddometer: 329
I've had the 03, the 05 and currently ride the 06 version. The 05 had the SAS, the 04 was not brought into Canada! I was surprised to see it (the SAS) gone on the 06 when I took delivery, I also was told that the 06 rims had been strengthened, the rims do seem stronger in 06, still-- I bent the crap out of the front and am looking to upgrade to a set of excels from Woody's Wheels. Hope this helps. Ed... |
