01-08-2007, 05:20 PM
#31 | |
Spudly Adventurer
Oddometer: 3,253
![]() Good to talk to you today Rich ! Mike
Cogswell Rides To Big Bend See my airhead project here Time Warp Vintage Motorcycle Club The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED. |
01-08-2007, 05:25 PM
#32 | |
Spudly Adventurer
Oddometer: 3,253
I guess you'll have to post your repair progress in here. Hope you heal fast and straight. Mike
01-27-2007, 01:37 PM
#33 |
Spudly Adventurer
Oddometer: 3,253
Project Update.
Well I'll revive this from a lonely page 4 with a progress update. I have all the parts back from powdercoat along with the redone frame. The guy did a super job masking things off and plugging threaded holes. For anyone in or around the east Tn area I can recommend Smith's Customs in Louisville.
Lots of time is being spent on time consuming projects like the brakes. ![]() ![]() BMW/Brembo has a really nice kit for the calipers. All the new rubber pieces are included along with new bolts. The pistons are a composite material so they cleaned up fine. ![]() ![]() ![]() ![]() ![]() Above is the rear caliper, the fronts have the same internals and they all run the same size pad. I'm having to spend some time sorting through the brake line upgrade to stainless braided. While mounting the front wheel and calipers I noticed a clearance issue. When I got the bike the right front rotor was toast and the caliper rubber was melted. It appears the front rotor shims are not installed/were lost at some time in the past. I'll get some of those on the way with the next parts procurement. ![]() I had all the small bits on the handlebars powder coated as well as the front master cylinder. ![]() I did get the frame set up with the front end on it and started to route the wiring harness, thank Dog for high quality digital pictures ! ![]() ![]() ![]() ![]() I really dig the color on the wheels, it shows a bit better in these pictures than in previous ones. ![]() ![]()
Cogswell Rides To Big Bend See my airhead project here Time Warp Vintage Motorcycle Club The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED. Cogswell screwed with this post 03-06-2011 at 10:42 AM |
01-27-2007, 03:28 PM
#34 |
Oddometer: 992
This will be a great ride. Nice to see old iron back on the road. Also nice seeing someone doing it right. Good work!
07 Ducati 1100 S Multistrada 07 Suzuki SV 650 05 Suzuki DL 650 01 Suzuki DRZ 440 00 KTM MXC/EXC 453 98 Ducati ST2 96 Ducati SS/SP 95 Ducati 900 Elefant 78 Ducati 900 SD Darma |
01-27-2007, 10:04 PM
#35 | |
Teach me this knowledge
Oddometer: 541
03-15-2007, 06:43 PM
#36 |
Spudly Adventurer
Oddometer: 3,253
Long overdue update.
Ok, I know it's been a while but work has been on the front burner for a while. The project has not been ignored. Most engine machine work, cleaning, and assembly has been done. I still have a couple of items to take to powder coat, bottom of the air box, and probably the engine front cover. It's really rough and I'll either try to match it to engine color or have them do it in black.
![]() ![]() ![]() ![]() ![]() ![]() I have the wiring harness run and everything plugged back in at the fuse panel in the headlamp. Rear brakes are on and bled, front brakes have been a bit of a pain. When I got the bike there was an issue with the right side caliper inner half interfering with the rotor. I think I have that sorted by shimming the rotor out from the wheel. Body work painting is going to be started soon, I will probably meet with the painter this weekend. Other than that it's a little fitting here and a little more cleaning there, and a few oops I forgot to order that too's Mike
Cogswell Rides To Big Bend See my airhead project here Time Warp Vintage Motorcycle Club The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED. Cogswell screwed with this post 03-06-2011 at 10:44 AM |
03-15-2007, 08:14 PM
#37 |
Don't buy from Brad
Oddometer: 7,403
looks great.
Is that position and mount for the oil cooler OEM or did you modify it? I've seen alot of folks relocate the oil cooler on the gs's and that looks like it would be great if OEM equip is used.
On tap:Nada Aging: 3 experiments in mead - blackberry, apple, and straight honey |
03-16-2007, 05:07 AM
#38 | |
Spudly Adventurer
Oddometer: 3,253
I looked on the RT online fische and didn't see the oil cooler listed, suprised ? Let me know if you want better pics, it just clamps to the frame cross tube. Mike
03-16-2007, 05:21 AM
#39 |
Oddometer: 1,075
Nice work !
Its normal BMW place and cooler for RT RS, I've got the same at same place on my unfaired RS |
03-16-2007, 06:11 AM
#40 |
Don't buy from Brad
Oddometer: 7,403
I would like some more pics if you don't mind.
If nothing else, for comparing which relocation method for a gs is easier/cheaper. Thanks.
03-16-2007, 08:41 AM
#41 | |
Oops...
http://www.mobilemrt.com http://www.dorkpunch.com "I've been going to this high school for SEVEN YEARS. I'm no dummy!" -Charles De Mar. |
03-16-2007, 09:06 AM
#42 |
Rudy in MT
Location: Helena, MT; mountains and dirt roads all around...
Oddometer: 337
Nice work Mike!
Very impressive to see one take on such a project! (I would be taking so many digital photos to keep track of things as I disassembled it!)
I hope to keep track of this and see how thing progress! Rudy in Montana
2009 Triumph Scrambler (purchased "'new" 2/21/12) 2005 Tw200 (purchased 020309) 2003 F650 Dakar (purchased 2/3/2007; sold 5/9/12) ------------------------------------------ It's good to be anywhere! |
03-16-2007, 11:59 AM
#43 |
Oddometer: 1,075
A drawing for the cooler
03-16-2007, 02:47 PM
#44 | |
Oddometer: 2,951
Temple Lodge,No 25.F.& A.M. Paddle faster I hear banjos |
03-16-2007, 03:55 PM
#45 | |
Spudly Adventurer
Oddometer: 3,253
Please excuse the dust. ![]() ![]() ![]() ![]() Mike
Cogswell Rides To Big Bend See my airhead project here Time Warp Vintage Motorcycle Club The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED. Cogswell screwed with this post 03-16-2007 at 05:32 PM |
