11-06-2012, 06:32 PM
#346 | |
Udafarkarwee Tribe.
Oddometer: 42
Plastics.
http://www.kfm-motorraeder.de/ Ask them to send you the XT660X parts catalog for the VOS4 (Orange) bike. In those days the tank shrouds and the headlamp shroud plastics were the same shape. Don't forget to order the foam dampeners. Excluding decals which are expensive any where in the world the order came to €160 plus €50 freight. If you PM me your email address I can send you the Orange bike Parts catalog. Also have one for the 09 R if you need it. Ciao
09, KLX250s, Stage 2 jet kit, etc, 09 XT660R, Stage 2 DNA Filter, Dunlop D606 Tyres, GYTR Bash Plate, Fork Spring Spacers, OTR Water Pump Guard, CNC Gear Lever, Rear B/lever ext, EGO B/Busters, Cameltoe S/Stand Puck, Ventura pack rack. |
11-06-2012, 08:51 PM
#347 | |
Oddometer: 523
can get the decal kit but not the plastics.. http://bikestat.com/images/510_Yamah...BMotoGP2B2.jpg
Here.... my XR250 leaner side car build http://www.advrider.com/forums/showthread.php?t=716993 |
11-06-2012, 10:00 PM
#348 | |
Udafarkarwee Tribe.
Oddometer: 42
Do you have part numbers for those shroud graphics shown in the picture link you posted.
11-08-2012, 12:49 AM
#349 | |
Udafarkarwee Tribe.
Oddometer: 42
Plastics
Find those sticker part numbers???
11-08-2012, 09:10 PM
#350 |
Oddometer: 24
buying 2009 xt660r
G'day
After a long period of deliberation, i'm just in the process of buying a 2009 xt660r from a dealer. My first bike was a 225cc and this'll be the first real bike, I'll be owning!. \ I'd say, I'll be making for a 60 / 40 road / off-road usage with it!... off road being some dirt road, nothing too serious or heavy and a lot of long distance riding! What are the xt660 specific things to look out for, when buying this model used bike (from a dealer)?? It's done about 4k on odometer, has 2 in 1 muffler, long range tank and larger pegs. Being from a dealer, I get 3 months warranty too! cheers |
11-09-2012, 12:00 AM
#351 | |
Try Hard
Oddometer: 317
Nice purchase...
Sounds ideal for what you have planned. Maybe look at the fork seals, wheel bearings, an 09 with 4K on it may have sat for some time, so you might want to dump any fuel in it & of course change the oil. Probably got rusty spokes, may negotiate with the dealer about that. Take the seat off & have a look at the electrics, make sure it hasn't been drowned. Corrosion can be a problem in XTs, so have a good look at the usual trouble spots. While you have the seat off check how much dust is in there (Thanks MickD for that tip) it might give you an idea of the type of use it's had. Take the snorkel out while the seat's off, although it may have been taken out already to help it breathe. Check inside the swingarm for water & corrosion. I'm sure others will add more, but they are generally renowned as a bullet proof bike (with electrical & corrosion being the weak points).
So far, so good... |
11-10-2012, 08:09 PM
#352 |
Now if we just.....
Oddometer: 513
If you have problems with the dreaded efi surge get one of Kevs O2 modifiers. He sells them on ebay and definitely worth the money (around $100). just plugs in series with the oxygen sensor and changes the fuel air ratio in closed loop mode to 13.6 instead of 14.7. Got one a couple of weeks ago, makes all the difference.
Sunday ride, Weathers ok
I used to think its great that I've developed more patience as I've got older But now I realise I just don't give a shit. plodalong screwed with this post 11-10-2012 at 08:29 PM |
11-10-2012, 09:13 PM
#353 |
when in doubt - power out
Oddometer: 142
Agreed I have done about 2500km with Kev's O2 controler fitted and it is brilliant, worth every cent and more. The country is looking good out there plodalong, I should be out Condo way in a week or two churning up some red dust and loving it (it gets in ya blood I reckon). |
11-10-2012, 09:37 PM
#354 | |
Oddometer: 523
Just got a set of Yamaha 660 ten engine bars.. now to make them fit the XTR... looks like I will need to cut the rear mounts off... build new ones & bolt to the B&B bash plate... Should look like this... https://www.adventuremoto.com.au/ima...E-BPresize.jpg
Here.... my XR250 leaner side car build http://www.advrider.com/forums/showthread.php?t=716993 Pete-NZ screwed with this post 11-10-2012 at 09:44 PM |
11-10-2012, 11:12 PM
#355 | |
Oddometer: 142
That should look good Pete you will have to post some pics when you have it done. Forgot to mention I have the fuel mod to. I have opened up the top of the airbox and have a pipercross filter as well. I am trying a NGK CR8EK plug at the moment, with the current mods she runs smooth and goes very well.
supamanaint screwed with this post 11-10-2012 at 11:21 PM |
11-10-2012, 11:30 PM
#356 | |
Oddometer: 523
i can see the day comeing when I'm in the middle of nowhere with a puddle of coolant under the bike.. ![]() Oiled foarm filters are good......K&N / DNA are ok if theres no fine dust around...
11-11-2012, 05:24 PM
#357 | |
Oddometer: 24
strewth
thanks for all the reply fellas! I'm hoping another point of advice before I go into a spasm making the right choice!!!! My local Yamaha shop in XXX giving away a 2012 xt660r stock for 10.5k ride away… This other xt660r is from another dealer, not coming down a dime for his 2009 model with low kms and 2in1 muff, large tank and pegs, bash plate, for 8.6k ride away. I have't had a chance to look at 2009 model xt yet but the brand new xt looks spotless (naturally!) I hope this doesn't sound silly but any advice on which one would be a better choice?? 2009 xt has those extras that would cost another ~2k to purchase but on the other hand, 2012 xt is stock but just brand spanking new!! Quote:
11-11-2012, 11:04 PM
#358 |
Now if we just.....
Oddometer: 513
Its a bit of a toss up, if the 09 looks like its had an easy life (4 k isn't much) I would probably lean towards that even though he's probably asking top dollar. The extras it comes with sound pretty appealing especially if you're planning to get them anyway. Also factor in how worn are the tyres and how much rego left. Maybe the dealer might do a deal on riding gear or other accessories. Happy haggling.
I used to think its great that I've developed more patience as I've got older But now I realise I just don't give a shit. |
11-12-2012, 12:35 AM
#359 |
Oddometer: 142
Also it doesn't hurt so much to drop a second hand bike, just ask boneman660
.While it is nice to have a brand new bike 4k is nothing (as plodalong said) and the more you can save the more you have to spend to equip, mod & ride with. I would suggest if I may to have a look at the 09 first and go from there, cheers. supamanaint screwed with this post 11-12-2012 at 12:50 AM |
11-12-2012, 01:25 AM
#360 | |
Try Hard
Oddometer: 317
