12-15-2006, 04:56 PM
#1 |
Oddometer: 1,099
Dirtbike or dual sport winch?
Anyone put something like this on a bike?:
http://www.basspro.com/servlet/catal...rTarget=browse Or seen it done? It says it weighs 11 lbs. Not that I'd want 11 lbs hanging off my bike most of the time, but in certain places at certain times... I may have a need for one.
Alaska ride 2005 http://www.advrider.com/forums/showthread.php?t=83480 Hard copy: http://www.blurb.com/my/book/detail/43597 Mexico ride 2006 http://www.advrider.com/forums/showthread.php?t=143434 |
12-15-2006, 05:08 PM
#2 |
Oddometer: 33
the issue before the weight is the amps consumption.... do you think that your charging syst. is up to the task.....
on Jeeps....most people have dual battery set up..... one to start the engine...and one used to winch.... if your engine crap out.... The other way would be to carry a come -along and a long prolypropelene (sp.) cable .... 20 feet should do it.... otherwise a light bike is the ticket Michel 80 DR400 |
12-15-2006, 05:19 PM
#3 |
Oddometer: 1,099
Oh yeah, it would have to have a seperate battery. I forgot about that. Maybe 20 lbs total added?
12-15-2006, 06:28 PM
#4 |
Oddometer: 1,258
Manual winch is better if you're thinking about maximum usability in "really fucked" scenarios.
12-15-2006, 06:30 PM
#5 | |
Oddometer: 1,258
12-15-2006, 06:33 PM
#6 | |
Oddometer: 1,099
How far can something like that spool out?
And how much weight could it handle? Could I lift 400 lbs straight up a cliff? Quote:
Alaska ride 2005 http://www.advrider.com/forums/showthread.php?t=83480 Hard copy: http://www.blurb.com/my/book/detail/43597 Mexico ride 2006 http://www.advrider.com/forums/showthread.php?t=143434 snowrider screwed with this post 12-15-2006 at 06:42 PM |
12-15-2006, 06:57 PM
#7 | |
Oddometer: 7,248
BUT, do you really think it's a good idea to be in a place where you'll need it when you're by yourself? If you have somebody with you, it's easier to pick the bike up and carry it. |
12-15-2006, 07:32 PM
#8 | |
Oddometer: 235
Brian Carscadden 1973 Honda CB 350F |
12-15-2006, 07:49 PM
#9 |
Oddometer: 363
Here's something. I have one but doubt I would carry it all the time.
Attachment 95869 http://www.cabelas.com/cabelas/en/te...159&id=0006250 MrEndo screwed with this post 12-02-2007 at 02:49 PM |
12-15-2006, 07:51 PM
#10 | |
killing the fatted calf
Oddometer: 2,050
2005 DR650, 2010 Triumph Scrambler |
12-15-2006, 07:55 PM
#11 |
Oddometer: 1,367
![]() I keep a ratchet tie-down in the under seat box. The model with 2 hooks on each end. it can only pull around 6" at a time, then you have to loosen it up and take another 6 inches, but it's better then nothing. But it does have a nice long strap that can be used as a tow rope. Also can be used for holding gear down, parts back on, getting the tire back on the bead, etc... Lot of good uses. And it's small to. GoNOW screwed with this post 12-15-2006 at 10:53 PM |
12-15-2006, 11:35 PM
#12 | |
Oddometer: 1,099
Uh... no? Why is it that it seems like an even better idea now?
12-15-2006, 11:37 PM
#13 | |
Oddometer: 1,099
By the way, if I use a winch it will be for a segment of a trip, then it would be uninstalled and mailed home or whatever. I wouldn't just ride around everywhere with a winch hanging off my bike.
12-15-2006, 11:40 PM
#14 | |
Oddometer: 1,099
That's an interesting idea, thanks. How much do you think you could lift with it?
12-16-2006, 04:34 AM
#15 |
whats a cagiva
Oddometer: 2,454
A hundred foot coil of good poly rope and a couple of two spool block and tackel weighs a lot less and is just as capable as a cable comealong for carrying on a bike . I cant talk bad about the comalong , I used to have an old beater adventure truck , I carried two comalongs and a high lift jack and a shovel . I might have taken a little longer but I could damn near go anywhere . SEYA
David H 00 Cagiva GC 04 9 fiddy 05 ST3 duck 07 KTM 450 EXC 86 Goldwing my geezer ride |
