Old 06-07-2003, 10:30 PM   #1
DIEZEL OP
True Miles Unknown
DIEZEL's Avatar
Oddometer: 584
KTM Adv true dual head lights
Recently I was able to modify the lights on my 01 KTM Adv so that the low beam would remain on when the high beam was switched on. It was amazingly easy one I thought about it and the benefits in the dark are excellent, wide beam for critters, cars and trees with the pencil beam showing distance. I have posted the information via the following link for those interested.
http://pub134.ezboard.com/fazbusasfr...opicID=7.topic
DIEZEL is offline   Reply With Quote
Old 06-08-2003, 08:31 AM   #2
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,612
I have found a position in the headlight switch for my Airhead GS where both filaments in the single H4 bulb are lit, and it does indeed make a significant difference. However, it really soaks up the watts, and I think a separate aux. headlight would be more efficient and I am afraid the wiring won't stand up to the greatly increased flow of electrons - especially the switch. In your case you have two headlights so there probably would be no harm.
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 06-08-2003, 08:48 AM   #3
Grover
Blinkenlights Adventurer
Grover's Avatar
Oddometer: 1,693
On a similar note, I expect Flanny to chime in here with more specific details, but anyhow - he experimented with a similar setup and found that having both beams on at idle or very low rpm will drain more current than the alternator is putting out, so he installed a switch to prevent running both beams simultaneously for tooling around at less than cruising speed.
Grover is offline   Reply With Quote
Old 06-08-2003, 10:07 AM   #4
DIEZEL OP
True Miles Unknown
DIEZEL's Avatar
Oddometer: 584
Grover
I agree with you and running like this for an extended period at low speeds may not be the best. One thing that amazed me was how thin the wires were that run the lights, not those that actaully plugin to the light but just before the white plastic connectors. My future plan is to run a fused heavy line from the battery and then use the switches to trigger a relay which in turn runs the lights. Still have a the current issue with the alternator but that will just have to be monitored by me and make a choice as to when I run both and when not too. No solution is perfect but at least this gives options.
Old 06-08-2003, 01:37 PM   #5
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,745
Gents,
I have not done this on a bike, but did with a car. I found that with the low beam on with the high beam, your ability to see longer distances is much less than with the high beam only. When your low beam is on it is a short wide patern (no shit loaded!). When your high beam is on you are usually traveling at speed. You want to remove focus on things that are close and change to things that are further away. When both are on (whether you know it or not) your body divides attention between. Is that really what you want while your ripping down a road at 100km in the dark?
Thats my 2 cents...
Colin
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 06-08-2003, 04:49 PM   #6
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
Hey Colin!
The two beams rock man...Yes...They really are what I want when doing 100!
What I did was install a switch and another blue indicator light. This way I know if I am running in "Dual Lamp" mode or not, and will keep me from having it on accidentally in the city during the day (when the alternator output is not particularly high).
All I can say is that it wors great. I've run it for 30 minutes at a time with no troubles at all.
Cheers.
Flanny is offline   Reply With Quote
Old 06-09-2003, 11:13 AM   #7
boyscout
sittin' down
boyscout's Avatar
Oddometer: 1,324
It's a little tricky but on my '02 you can put the switch halfway between low and high and get both lights to stay on. It takes some fiddling to get it to stay there but it's a nice way to try it out before doing the mod. I like running with both lights as I don't think the narrow high gives enough light on the sides to see deer etc.
-BS
Who me?
boyscout is offline   Reply With Quote
Old 06-10-2003, 12:28 PM   #8
Velocibiker
Adventure Antagonist
Velocibiker's Avatar
Oddometer: 1,164
Here's the wiring diagram I posted on KTMTalk. This leaves the low beam on when the high beam is switched on. I haven't noticed a drain at idle. I prefer the dual lights as it gives the cagers a better indication of closing distance.
Lights wiring diagram
Velocibiker is offline   Reply With Quote
Old 06-10-2003, 01:02 PM   #9
Velocibiker
Oddometer: 1,164
Old 06-10-2003, 01:15 PM   #10
Flanny
Flanny-it-up!
Flanny's Avatar
Oddometer: 2,738
Velocibiker..
You will be OK wrt voltage drops if the dual headlights are THE ONLY extra load, but if you run heated grips of other euipment you will find that you WILL draw more power than is available at city speeds...
You just need to manage your total load to about 7-8 watts at city, 8-10w at full cruise (5500rpm).
Old 06-13-2003, 08:54 AM   #11
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,720
Talking
Having read all these things that folks have done to get dual lights, which is definitely a must have at night with this bike, I tried something different. Boyscout mentioned that he would just fiddle with his switch so that it straddled the 2 positions and that got him dual lights. Thank you for that one, cause I wondered about hard wiring the system and then running my heated grips and vest. Found a simple solution to all this. I popped the switch apart, and using one of my favorite tools (The Dremel!), I just carefully made another landing for the detent ball of the switch to sit. 15 minutes from start to finish and I now have dual lights on demand that are easy to activate.
Hope this helps someone.
Drif10 is offline   Reply With Quote
Old 06-13-2003, 10:26 AM   #12
Grover
Grover's Avatar
Oddometer: 1,693
Said Drif10:
Damn, brilliant pennytech solution
BTW, welcome to the asylum Drif10!
Old 06-13-2003, 04:39 PM   #13
boyscout
sittin' down
boyscout's Avatar
Oddometer: 1,324
Said Drif10:
I know what I'm doing this weekend.
Who me?
Old 06-14-2003, 09:54 AM   #14
Grover
Grover's Avatar
Oddometer: 1,693
Said boyscout:
Take pictures, seriously. That would be handy to have around.
Times are GMT -7.   It's 11:02 AM.
