Old 08-13-2010, 10:27 AM   #136
TrainedChimp
Consistently wrong
TrainedChimp's Avatar
Oddometer: 185
Originally Posted by rattis
I don't have a relay on my bike, 2004 GSA, so will it respond to "Steptoeing"?
It might, just try it. That's how mine was when I got it, it had no cat code plug.
"Fools congregate."
TrainedChimp is offline   Reply With Quote
Old 08-25-2010, 03:26 AM   #137
ALX
R1150GS
ALX's Avatar
Oddometer: 93
Goodmorning from hottest Greece.
I saw before many days that thread, and i put the jumber like Steptoe's pic (30-87a).
In Greece we have high temperatures the summer. Before some days we have 40C (104F) and my '00 R1150GS it pinging again and again. Big problem to the motor.
Before 1 year I purchace the PowerFRK module and when install it, i saw the pinging it's gone
After that i try to learn some more things for that module, and i learn cos the module make the mixture richer. This is the answer for the pings. Rich mixture because the gas in Greece is so pour in octane (and it cost now over the 1,5/l )
The module powerFRK increases the fuel consumption and for that, i don't install it all the time. (I install it only for a quick travel at the roads with many turns )
Now I install the jumber and the pinging in hottest Greece is gone. Not completely, but it's gone and the bike shows stronger at the low and middle rpm's!
The jumber work perfectly!
In the next days i will try to combine the jumber with powerfrk and i tell you the results.
PS: The jumber (alone) increases the fuell consuption? (I don't have yet any feedback for that)
I apologies for my bad english
Steptoe...you are the best!!!
No matter what motorcycle ride, but... how to ride! ΑLX
ALX is offline   Reply With Quote
Old 08-25-2010, 08:26 AM   #138
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,563
Installed the Autolite plugs, surging & pinging still there, though light.
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 08-25-2010, 12:40 PM   #139
ALX
R1150GS
ALX's Avatar
Oddometer: 93
Off topic
Hey... where I find a dealer who have autolite 3922 to ship worldwide? (Greece)
I search many time in google, but didn't find someone Even the Amazon it don't send the spark plug to Greece
Old 08-25-2010, 03:03 PM   #140
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,196
Provide your shipping details and I'll send my 3922s to you. They are slightly used (about 3-4 hours) but still have many miles of life remaining.
Δεν έχω χρησιμοποιείται το autolite 3923s για πολλά χρόνια με πολύ καλά αποτελέσματα. Το 3922 μοντέλο είναι ελαφρώς ψυγείο και μια καλή επιλογή για θερμών καιρικών.
def is offline   Reply With Quote
Old 08-25-2010, 05:33 PM   #141
def
def's Avatar
Oddometer: 10,196
Originally Posted by Steptoe
How you guys managed to land on the moon i'll never know
We removed the CCP altogether.Oh, and we asked the Canadians to build the grappling arm for us........We chose Canada 'cause Lucas had no idea about electricity.
Old 08-25-2010, 05:46 PM   #142
def
def's Avatar
Oddometer: 10,196
Originally Posted by Dokken FronkOlder riders who remember the twin SU setup certain cars (like the old Jaguars?) had, will know what I talk about when I say you had to[FONT=Comic Sans MS
balance your carbs[/FONT].
I recall having to change dashpot oil.....silly!
Old 08-25-2010, 06:39 PM   #143
ThomasJ2895
Oddometer: 96
Final Pinging Update
Final Pinging Update for my fix
Installed a Techlusion gizmo...much better...fixed about 95%. The Techlusion guy said I could get my $ back if it didn't completely eliminate the ping but its so much better I'm keeping in installed.
Came home from work this afternoon in about 110 deg temp...was still able to get some slight ping up around 5-6k in 4th at WOT. But with that I'm calling it good enough. Guess there was a
good reason for BMW to develop the 1200.
These are the things I tried:
1) Techron...many bottles worth
2) Seafoam
3) Water torture
4) Cam Chain Tensioner upgrade (fixed the marbles in a can)
5) valve adj
6) TBS
7) Motronic jumper
8) 100 octane...it loved this stuff but at $7.50/gal somewhat impractical.
9) Techlusion gizmo (showed the most improvement)
10) Autolite 3922 plugs
The only thing that had any real ping reducing effect was the Techlusion unit.
Good luck to others with similar issues.
Tom's Barn...
R1150GS
XR600
XT225
and too many broken cars...so says the wife
ThomasJ2895 is offline   Reply With Quote
Old 08-25-2010, 07:18 PM   #144
sbrownn
SlowMo
Oddometer: 457
Lennie's sprockets
Lennie's sprockets = Pinging Gone
sbrownn is offline   Reply With Quote
Old 08-25-2010, 08:21 PM   #145
Uncle Crumpet
Uncle Crumpet's Avatar
Oddometer: 615
just bought an 02 1150 GSA and the first hot day I went for a run it pinged like a bastard, particularly rolling on at around 130kmh.Pulled out the yellow cat code plug, stuck in the Steptoe jumper as per pic, no more "breaking Glass" noises anywhere and a better running bike to boot.As has been said before, "Thanks Steptoe."
there is no mechanical problem so bad, that with a little more fixing, cant be made worse.
Uncle Crumpet is offline   Reply With Quote
Old 08-26-2010, 01:19 AM   #146
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,609
Here to help . The best part is what it cost you in cents -
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 08-26-2010, 04:07 AM   #147
ALX
R1150GS
ALX's Avatar
Oddometer: 93
Thank you my friend for your kindness, but I do not trust to put this kind of used parts on my motorcycle. You cannot give me a proof that only work a few hours and I can not trust them for the next 20K. I always prefer new.
Thanks again!
Old 08-26-2010, 07:22 AM   #148
ALX
R1150GS
ALX's Avatar
Oddometer: 93
Originally Posted by geode
Maybe check with Cos, see if he'll bring you back a set or two when he flies home? I think he is in the USA right now, or will be shortly.
Cos?
Old 08-28-2010, 02:55 PM   #149
ALX
R1150GS
ALX's Avatar
Oddometer: 93
Οh thanks mate! I send him a pm.
Old 08-29-2010, 12:10 AM   #150
AdventureDave
MMMMM Bundy!
AdventureDave's Avatar
Oddometer: 734
Sorry if this has been noted earlier but I wanted to give some knowledge without reading the whole thread.
We had four 1150 adventures all dual plug bikes (bmw club) that developed pinging One of the guys worked out that the coil pack that develops the charge to the second set of plugs was generating enough power to give a spark if it was manually inspected but when checked with proper equipment it wasnt generating any where near the correct number of volts to operate properly. When replaced the pinging disappeared and engine noticably smoother.
This wasnt picked up by two different mechanics. They corrected the problem when told what to look for. Hope this helps.
cheers
David
AdventureDave is offline   Reply With Quote
Times are GMT -7.   It's 01:08 AM.
