Old 12-20-2006, 11:33 AM   #1
speedirider OP
speedirider
Oddometer: 15
Why can't I use my strap wrench to remove oil filter?
I have a set of strap wrenchs...
Won't they work to remove the R1200GS oil filter???
Speedi & Duke Lehigh Valley, PA
BMW R1200GS - BMW F650CS
Honda CRF450X - Honda CRF150X
ride-windsurf-ski
speedirider is offline   Reply With Quote
Old 12-20-2006, 11:37 AM   #2
SKINNY
SKINNY's Avatar
Oddometer: 644
Because the filter is recessed into the engine case....only a socket type wrench will work since the end of the filter is all that is exposed...
SKINNY is offline   Reply With Quote
Old 12-20-2006, 11:43 AM   #3
Hedge36
Chasing parts.
Hedge36's Avatar
Oddometer: 44,982
Jeebus, genius - did you even look at where your filter is before posting this?
"When I joined ADV I was a fuckin brain surgeon, but 24,745 clicks from you and I can barely wipe my ass." Bender, former brain surgeon.
Hedge36 is offline   Reply With Quote
Old 12-20-2006, 12:14 PM   #4
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,735
I actually tried it once. You can sorta get the strap wrench on, but not enough to even come close to getting the filter off.
Jim
Old 12-20-2006, 12:38 PM   #5
speedirider OP
speedirider
Oddometer: 15
Thanks Jim!
One of 3 reasonable answers isn't to bad.... I thought it looked like I could get a strap wrench on it, but I havn't needed an oil change yet so haven't tried it...
Thanks again!!!
ride-windsurf-ski
Old 12-20-2006, 01:24 PM   #6
WildDuke
Dune Rider
WildDuke's Avatar
Oddometer: 69
I managed to do one oil filter change using a metal hose clamp (the same type that they use for holding radiator hoses on. All you do is slip it around the filter, tighten it and use a screw driver and a hammer to lightly unscrew the filter by tapping it loose. Its a pain in the a$$ but it worked. Same method used to put the new filter on.
After that, I jumped on the PC and on to Nippy normans web site and bought a propper tool. Its so cheap, everyone should have one in their tool box.
WildDuke is offline   Reply With Quote
Old 12-20-2006, 03:28 PM   #7
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,861
Alternatively, you can buy K&N filters witht he nut welded on. That's the cheapest since they cost roughly the sdame as the BMW filter and no need for a wrench.
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 12-20-2006, 04:33 PM   #8
dml232
Oddometer: 48
Yes, you can, kinda
I got mine off using a strap wrench. I had to angle it slightly. And, my secret I have used on cars. Sandpaper. The sandpaper prevents the wrench from slipping on the filter.
New filter is longer so no problems now.
dml232 is offline   Reply With Quote
Old 12-20-2006, 04:35 PM   #9
v8turbo
When in Doubt.... Gas it.
v8turbo's Avatar
Oddometer: 695
most dealers have a big socket like tool for the filter. about 30 bucks.
v8turbo is offline   Reply With Quote
Old 12-20-2006, 07:45 PM   #10
Cycletroll
Catastrophe Specialist
Cycletroll's Avatar
Oddometer: 1,082
Cycletroll screwed with this post 12-20-2006 at 07:56 PM
Cycletroll is offline   Reply With Quote
Old 12-20-2006, 07:59 PM   #11
macamoose
macamoose's Avatar
Oddometer: 644
The 12GS info site (http://www.r1200gs.info/misc/toolkit.html) had this idea using a bit of epoxy and a nut on the bottom of the filter:
Thad
Thaddeus
macamoose is offline   Reply With Quote
Old 12-21-2006, 03:44 AM   #12
Devil Dog
Q-Tip With Ears
Devil Dog's Avatar
Oddometer: 9,279
Yup, the cheapest thig on a BMW is the rider.
"A warrior does not get ready, a warrior IS ready." - Rudy Reyes
Fuck Jesse V
In his ass
With a chainsaw
Devil Dog is offline   Reply With Quote
Old 12-21-2006, 04:43 AM   #13
Idarider
R1200GS
Idarider's Avatar
Oddometer: 2,009
Channel Locks
Big Channel Lock pliers worked very good on the old filter.
Idarider is online now   Reply With Quote
Old 12-21-2006, 06:29 AM   #14
GB
Mod Squad
GB's Avatar
Oddometer: 55,995
Yup, that's what I've always said.. you spend $15 or $20 grand on a bike and don't want to spend $25 on a filter wrench.. If you wanna save money, sell the bike.
Old 12-21-2006, 07:00 AM   #15
scottpoley
scottpoley's Avatar
Oddometer: 548
oil filter wrench
Advantage Auto Parts offers a variety of oil filter wrenches that are packaged so you can try your filter for fit. I bought a 14 flute, 76mm wrench that was a perfect fit for my R1100GS for 5 or 6 bucks. Take your filter to the auto parts store and give it a try!
scottpoley is offline   Reply With Quote
Times are GMT -7.   It's 12:14 AM.
