Old 04-15-2012, 09:35 PM   #46
Gregidy
tallabanian
Gregidy's Avatar
Oddometer: 162
ok really old post but i need advice I cant find rebound 14 .15 and 10 .3 shims can anyone tell me if i can use 3x .1 in place of a .3
640 adventure rack for sale
http://www.advrider.com/forums/showp...1&postcount=23
Gregidy is offline   Reply With Quote
Old 04-15-2012, 09:43 PM   #47
WayneC1
Oddometer: 2,573
There is a substitution table to work that out, I cleaned one up & put it online, see the link below
http://www.f650gs.crossroadz.com.au/CalcShim.html
WayneC1 is offline   Reply With Quote
Old 04-15-2012, 09:50 PM   #48
Tseta
Lost
Tseta's Avatar
Oddometer: 673
Yep, can't just simply replace a .3 with 3*.1's. Wayne's calculator gives the same results as the formula I've been using.
Where are you getting your shims from? WP/KTM show a 6x10x0.3 as available:
40540447 SHIM 6X10X0,3
Also, a 6x14x0.15:
40540405 SHIM 6X14X0,15
Cheers,
Tseta
Tseta is offline   Reply With Quote
Old 04-15-2012, 10:50 PM   #49
bmwktmbill
Traveler
Oddometer: 5,194
Tseta,
You can buy shims here:
http://www.mx-tech.com/
They slipped them in an envelope and mailed them to me.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 04-16-2012, 10:06 AM   #50
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,199
There's an exception to the substitution table: when the shim is being used as a spacer then you should match the total thickness. In the case above, the 10-.3 shim in the rebound is a spacer- it won't flex itself, but controls when the 14 and 16 shims above it hit the 16 shim below it. So the correct substitution is 3x 10-.1mm shims.
Luke is offline   Reply With Quote
Old 04-16-2012, 10:27 AM   #51
Tseta
Lost
Tseta's Avatar
Oddometer: 673
Solid info there, Luke. Thanks!
-T
Old 04-16-2012, 10:51 AM   #52
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,199
BTW, and I should have posted this when it happened: After a bit of riding with the new valving I decided that the front was too soft, and added two 24-.1 shims to the low speed side of the base valve. It's still pretty plush, but holds the front up a lot better in whoops and stuff. Helps with the brake dive too.
Old 04-16-2012, 05:32 PM   #53
Gregidy
tallabanian
Gregidy's Avatar
Oddometer: 162
Also, a 6x14x0.15:
Cheers,
Tseta
Thank you guys very much I put .52 front springs in and now way stiff on top low speeds I'm 210-220 pounds and need to sort this before the p2d
was going to order from mx tech but they don't list some of the shims so I guess ill have to search through feichs rrrr
Oh and I went to the shim calculator and wtf it makes no sense t me I have never revalved so was just stealing/borrowing your # :) so off to ktm i go
and it seems some are back ordered
I would send my suspention away but it is riding season :)
well 2-3 weeks on the 6id 14od .15 but what do you do coming straight from austria lol
Gregidy screwed with this post 04-17-2012 at 10:29 AM
Old 04-17-2012, 04:22 PM   #54
Gregidy
tallabanian
Gregidy's Avatar
Oddometer: 162
bottom is low speed right ?? and did you put them in first?
Old 04-17-2012, 05:07 PM   #55
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,199
Bottom of what?
The valve in the bottom of the forks is the base valve. The low speed shims are the ones at the top of the stack, closest to the valve itself.
I went from stock:
Base: (6mm ID)
6 x 24 x .1
2 x 22 x .1
2 x 20 x .1
2 x 18 x .1
1 x 16 x .15
1 x 14 x .15
1 x 11 x .2
1 x 18 x .25
to:
2 x 24 x .1
1 x 12 x .1
1 x 24 x .1
1 x 22 x .1
1 x 20 x .1
1 x 18 x .1
1 x 16 x .1
1 x 14 x .1
1 x 12 x .1
3 x 10 x .1
to:
4 x 24 x .1
1 x 12 x .1
1 x 24 x .1
1 x 22 x .1
1 x 20 x .1
1 x 18 x .1
1 x 16 x .1
1 x 14 x .1
1 x 12 x .1
3 x 10 x .1
Terminology: There are three stacks, base, mid, and rebound. Each can have a low and high speed part. In the above base valve stacks the first 24mm shims in the list are the low speed part of the stack, the 12mm shim is the crossover, and the rest are the high speed part.
Old 05-03-2012, 10:13 PM   #56
Gregidy
tallabanian
Gregidy's Avatar
Oddometer: 162
my 05 has diff shims rrrr I ordered too few :)
base
6x 24 x1
2x 20x1
2x18x1
1x16x2
1x14x2
1x11x3
1x16x3
mid
4x24x1
1x22x1
1x20x1
1x18x1
rebound
5x24x1
1x20x1
1x18x1
2x14x1
1x12x1
1x10x3
1x14x3
not sure if it will help anyone but I'm in Canada might have set them up diff here
Old 05-11-2012, 07:34 PM   #57
Gregidy
tallabanian
Gregidy's Avatar
Oddometer: 162
so i still am missing shimms 3 orders later hahahah not really funny!. well gotta get the bike back together so my stacks will be
2x24x1-low speed?
1x12x1
1x24x1high speed?
2x20x1 ''
1x18x1 ''
1x16x1 ''
1x14x1 ''
1x12x1 ''
1x10x3 ''
let me know whet you thing of the substitution of the 1x22x1 to a 1x20x1 should blow through a little faster hope not too fast
have to try and see i could use a 1x24x1 but that might be a little to stiff high speed if I'm getting this correct ??
researched allot but all just theory so far
Old 05-11-2012, 09:20 PM   #58
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,125
2x24x1-low speed?
1x12x1
1x24x1high speed?
2x20x1 ''
1x18x1 ''
1x16x1 ''
1x14x1 ''
1x12x1 ''
1x10x3 ''
What's your midvalve float? I'd make sure to get that down to the .8-1.05 range while you're at it. To me, the basevalve sounds like not enough low speed damping (large diameter shims closest to the valve body), but I've only redone my 950 forks, not my 640.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 05-12-2012, 07:07 PM   #59
Gregidy
tallabanian
Gregidy's Avatar
Oddometer: 162
the plan of attack is soft lsc and stiffen the mid valve so plush up top stiffer down slightly in the stroke. well from what ive researched Im just using zdogs mid valve or id be afraid to attempt this
Old 05-12-2012, 07:30 PM   #60
slackmeyer
slackmeyer's Avatar
Oddometer: 3,125
zerodog's midvalve compression stack is 1.45mm, yours is 0.7, right? You're going to have more movement than you want at the beginning of the stroke I think. There were a few different midvalve taps, you should really try to measure the float on there with the shims you put on. . . you can use stacked feeler gauges if that's what you've got.
Zak
ktm
old bmw
others
Times are GMT -7.   It's 12:59 PM.
