Old 05-12-2012, 07:52 PM   #61
Gregidy
tallabanian
Gregidy's Avatar
Oddometer: 153
Mine came stacked with same shims i thought it would be = guess ill measure em up and see thanks for the help
I am updating to zerodogs mid-valve and i checked fiches and the taps from 03-05 seem the same I should be ok but I will double check
640 adventure rack for sale
http://www.advrider.com/forums/showp...1&postcount=23
Gregidy screwed with this post 05-12-2012 at 08:04 PM
Gregidy is offline   Reply With Quote
Old 05-12-2012, 10:33 PM   #62
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 2,549
Ok, I thought the first stacks you posted were what you were going to end up with. Those midvalves are important, you're making a much larger change there than you are at the base valve with those stacks- that's fine, just check your work, and don't take anything for granted in the forks. On my 950 (same basic forks), the rebound needles were well rusted up, I've heard that's a fairly common problem.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Times are GMT -7.   It's 10:17 PM.
