Old 01-04-2007, 01:32 PM   #1
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 8,300
Question starter bolts der airhead
...well gee, my last airhead had capscrews holding in the starter motor...this derelict GS has two 13mmm hexhead bolts...
oh sure, I can get a socket on the left side bolt but that's it...the useless tranny flange is in the way....what's a mother to do???
Rapid Dog is offline   Reply With Quote
Old 01-04-2007, 02:32 PM   #2
Ugh
Redneck Adventurer
Ugh's Avatar
Oddometer: 35
Do this...
I use a 3/8" drive wobble extension to get to the rear one. Works pretty well.
________________________________
Dyslexics of the world - UNTIE!
Ugh is offline   Reply With Quote
Old 01-04-2007, 02:53 PM   #3
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,451
I've gotten that one with a little 1/4" breaker bar and a 12 point socket. JT
jtwind is offline   Reply With Quote
Old 01-04-2007, 02:59 PM   #4
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,300
...oketdokey
...'ll give it a try den...
Old 01-04-2007, 08:34 PM   #5
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,300
grind
only thing that seemed to work was grinding down a spare 13mm 10pt boxend wrench....just barely...
Old 01-05-2007, 07:00 AM   #6
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
there's always 1 ridiculously tight space to get a bolt from in every vehicle.
I've read that people replace these bolts with recessed allen head bolts to make it easier the next time.
If anyone knows where to buy these bolts, please cough it up. My starter is in the mail and I wanna have the bolts ready to upgrade.
The local hardware store only has standard. Bastards.
Size according to the fish is (M8X45)
On tap:Nada
Aging: 3 experiments in mead - blackberry, apple, and straight honey
datchew is offline   Reply With Quote
Old 01-05-2007, 07:34 AM   #7
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 8,300
Mcm
...only place I kmow for sure you can get high quality metric bolts is MCMASTER.COM...but you have to buy boxes of them.
you find a source let me know!
Old 01-05-2007, 08:47 AM   #8
Motomech
Adventurer in Latin Amer.
Oddometer: 337
I just swap the airbox mounting bolts(Allens) with the starter mounting bolts.
Motomech "One modification a day"
'92 BMW R100GS Bumblebee
'91 Suzuki TS 200R
'96 KTM 300EXC
Playas del Locos
"The BMW Airheads, riding yesterday's technology the day after tomorrow".
Motomech is offline   Reply With Quote
Old 01-05-2007, 10:05 AM   #9
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
Why the hell didn't I think of that?
On tap:Nada
Old 01-05-2007, 11:31 AM   #10
Suppermotodd
Tag Thief
Suppermotodd's Avatar
Oddometer: 1,018
Thumb Starter Bolts
That's F**ing Brilliant dude!
Man I'm broke as a stick! NoPC-Lance
http://www.motocompound.com
Suppermotodd is offline   Reply With Quote
Old 01-05-2007, 12:59 PM   #11
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,238
my local true value and lowe's both have metric bolts and fasteners. might give one of those a shot if you haven't.
motomech, good idea on swapping bolts with the airbox. very elegant solution.
bmwblake is offline   Reply With Quote
Old 01-06-2007, 05:50 AM   #12
Motomech
Oddometer: 337
Yeah, kinda makes you wonder why BMW didn't think of it.
'91 Suzuki TS 200R
'96 KTM 300EXC
Playas del Locos
Old 01-06-2007, 06:02 AM   #13
Hennepinboy
Have battery will travel.
Hennepinboy's Avatar
Oddometer: 420
BMW part number, for the trans to engine bolts
07119901029 fillister-head screw (M8X40) BUY 2 $1.03
From the Max BMW web site.
Hennepinboy is offline   Reply With Quote
Old 01-07-2007, 07:29 PM   #14
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
just a quick FYI:
put in my new valeo today after some extensive cleaning.
Some dead bugs, dirt, grime, etc.
Those stock bolts are very hard to get to. I was starting to cuss because i don't have a grinder or a file handy when i remembered this super cheap $9 set of wrenches i bought from harbor freight. It's the crappy chicago brand of box end's that goes from 5mm to 32mm.
Anway, my ratchet wrenches certainly didn't fit. several sockets did but not with a ratchet or wobble socket attached. an old s-k breaker bar almost fit, but not quite. none of my box end wrenches fit, but amazingly, that piece of crap chicago wrench set's 13mm just barely BARELY fit in there on the left side bolt. (left leg as riding it)
The other side i had to pull the crankcase vent rubber tube from the airbox and put an extension and socket through it to get it.
Anyway got them out and replaced with allen bolt M10x40 from Lowes. The originals are 45mm long but i measured the portion of the starter that the threads go into. They're a full 15mm deep and threaded all the way through. So the M10x40 (also same as the upper two tranny bolts mentioned) will still catch a full 10mm of threads.
Since they're mostly working against shear forces (keeping the starter from rotating in place) I think they'll be just fine like that.
If they shear off, i'll let you know.
On tap:Nada
Times are GMT -7.   It's 06:52 AM.
