Old 03-02-2011, 06:52 PM   #19246
brownie2
brownie2's Avatar
Oddometer: 319
Not much help here but on an empty system, push fluid up from the bottom using a large syringe. Attach the syringe with a small felx hose to the bleeder nipple. Just go slow until you get fluid in the res. and your done!!!!!!!!
If I were you, I would drain what I could and then push up from the bottom. Or you could just open the bleeder and the res.(yeah, I can't spell it) and let it sit while your doing other things. Just keep the reservoir(sp) topped up.
The less lever action the better on a dry or empty system.
brownie2 is offline   Reply With Quote
Old 03-02-2011, 07:00 PM   #19247
Tukata
ADV Demo Rider
Tukata's Avatar
Oddometer: 1,483
Pull the caliper off the wheel without breaking the system.
check around the piston for any fluid...you may have messed up the o ring and it may be leaking.... or the master cylender may have a failing seal
money is on air though
Yes, I'd love to try
What ever happens to be in the stable at the current time.
H-ADV in fabrication
Tukata is offline   Reply With Quote
Old 03-02-2011, 07:05 PM   #19248
Willy-B
onebudwiser
Willy-B's Avatar
Oddometer: 7,809
Originally Posted by Gallowbraid View Post
This released quite a few more bubbles...but still no go...pumped until there were no bubbles...closed the bleeder valve back up...still not even spongy...tried again...tapped on the line and any parts where I felt air could get trapped...sealed back up...still nothing...
And the sytem was good before you started???
Check and double check.
I'd rather be legless than spineless. Any day of the week and forever.-Gravity
My theory, you only get one chance, go full fucking throttle, all the way, all the time.-Trip
Willy-B is offline   Reply With Quote
Old 03-02-2011, 07:22 PM   #19249
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,954
You CAN'T bleed air down hill [air rises] to the bleeder screw
Follow Brownie2 [am i brownie1?] instructions [only way to bleed any system]
Just remember to tighten the bleeder screw BEFORE removing the hose .
Use a clear hose to where you can see the fluid flowing with NO bubbles
Use a clean rag to absorb the dirty fluid OUT of the Reservoir until CLEAN Fluid fills it up
I had to do this Repair to my Hyd Clutch, at the last Fuzzy Beaver Ride
Buy the Large Sirenge from a Feed & Seed Store. Farmers use em
Brown Dog screwed with this post 03-02-2011 at 07:32 PM
Brown Dog is offline   Reply With Quote
Old 03-02-2011, 07:23 PM   #19250
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 13,783
Pump hold lever in, open bleeder then close bleeder before releasing lever, add fluid if needed and repeat. over and over and over.... until the air is out and you have a solid lever.
Never release the lever or pump while the bleed valve is open.
Al Tuna is offline   Reply With Quote
Old 03-02-2011, 07:34 PM   #19251
Gallowbraid
Gallowbraid's Avatar
Oddometer: 832
Thanks for the help fellas...figured it out...when I've done this in the past whatever bleeder valve I've dealt with I've just barely opened it...makes it easier to close without letting air in. Apparently on this KLR you have to open that sucker up all the way to get absolutely all the air out...did that and everything is working fine.
I guess it was holding back some of the air in the line not being wide open...huh...
Gallowbraid is offline   Reply With Quote
Old 03-02-2011, 07:40 PM   #19252
Brown Dog
Brown Dog's Avatar
Oddometer: 1,954
Talking Just Kiddn
on this KLR ...
I didnt know KLR's needed Brakes
Dag's said so
Old 03-02-2011, 07:49 PM   #19253
Land
Wanderer
Land's Avatar
Oddometer: 3,833
Would have one, but the neighbor that I went to borrow it from has already loaned it out, hasn't gotten it back, and forgot who it went to...
Didja look in your garage for it?
Glad you got 'em bled. They do come in handy.
Chris
I'm not lost. I'm explorin'.
"My dream is to live my life as best I can before I die, even if it kills me." -- Mr. Cob
"If you're on ADV and you're still anonymous, you're doing it wrong." -- Boondoggle
Land is offline   Reply With Quote
Old 03-02-2011, 07:50 PM   #19254
tagalong
tagalong's Avatar
Oddometer: 465
Best way I've found
I tried the syringe from the bottom method to no avail.
What I finally found worked best was to attach a clear hose to the bleeder valve and raise it to a height just below the master cylinder. While holding the end of the hose high, I opened the bleeder to allow the system to gravity bleed. When you see the fluid level rise to the top of the hose and about to run over, close the bleeder. Do a regular "pump & bleed" to finish it off.
08 950 SE
99 KLR 650
93 ST1100
tagalong is offline   Reply With Quote
Old 03-02-2011, 07:53 PM   #19255
Gallowbraid
Oddometer: 832
Dag's said so
Actually I carry two bricks tied to a rope in my milk crate panniers...when I want to stop I reach in and toss them behind me...the rope is tied off to the subframe...it takes some getting used to for the timing, but with a KLR you have to make sacrifices.
Old 03-03-2011, 03:38 AM   #19256
DirtDabber
cultural illiterate
DirtDabber's Avatar
Oddometer: 8,146
...... but with a KLR you have to make sacrifices.
Dating.
Friends.
I wonder where that road goes?
DirtDabber is online now   Reply With Quote
Old 03-03-2011, 05:27 AM   #19257
phideaux
phideaux's Avatar
Oddometer: 3,352
What do you know about farmers?
Dag's said so
Brakes? KLR's come with brakes?
Who'd a thunk it?
Iron Butt Association No. 22913
Mrs. Phideaux to her octogenarian friend when the granny wants to know if she can sit on one of my bikes:
"It's Okay, they only fall over when HE'S on them."
North GA Tag-O-Rama Map
Georgia Tag-O-Rama Map
phideaux is offline   Reply With Quote
Old 03-03-2011, 10:05 AM   #19258
Magnum1b
Magnum1b, yes I had one
Magnum1b's Avatar
Oddometer: 747
Picked up an EVS jersey and knee/shin guards at CG for under $105 today. Wjen you get to be my age you need mo protection cause the old body doesn't heal as fast as it did when I was younger.
Magnum1b is offline   Reply With Quote
Old 03-03-2011, 01:02 PM   #19259
klaviator
klaviator's Avatar
Oddometer: 6,486
And you should Know!
I ride, Therefore I Am.
klaviator is offline   Reply With Quote
Old 03-03-2011, 01:54 PM   #19260
Magnum1b
Magnum1b's Avatar
Oddometer: 747
I cannot deny, however you should be kind to us elders. ; )
Times are GMT -7.   It's 06:04 PM.
