Old 01-06-2007, 05:25 PM   #1
OldDog OP
Smelly Adventurer type
OldDog's Avatar
Oddometer: 4,678
Mikuni fuel pump problems
Howdy All,
Having some trouble with the mighty Rallye, looks like it's not pumping fuel through to the carb (Dellorto PHM40).
I had the bike going and was riding it about but a dud battery pulled it up last week. While i waited for the replacement i've been finishing off stuff like the fuel line routing, chasing oil leaks etc until eventually i used up what fuel was in the fuel lines, filter etc, the bike started and ran fine with the tank removed.
Anyway, got the new battery fitted up, put on the tank etc, and it don't go! Just the occasional backfire etc. No fuel in the line, and after draining the float bowl it's obviously not pumping, this hadn't been a problem when i first assembled the bike though . So i primed the fuel line and filled the bowl, it but that hasn't helped, theres obviously no fuel pressure. I've removed the tank and wound the engine over watching the fuel filter, the level drops, but when i stop turning it over the fuel returns to the filter. I've turned the motor over with the fuel line off, it spits out the fuel i've poured in then nothing. I've hooked up a gravity feed line, but thie carb needs fuel pressure it seems. I suspect some sort of air lock inside the pump. Anyone know anything about these pumps? I can't find any identification on it other than "Mikuni" as you'd expect a search on here is only turning up carb info.
Any help appreciated!
Bill
Your time is limited, so don't waste it living someone else's life. - Steve Jobs
Yesterday afternoon I was planning to ride Dakar, this morning I was planning to throw up in my helmet - Boris Mihailovich
Objects in the rear view mirror.....appear to be losing - Me
OldDog is offline   Reply With Quote
Old 01-06-2007, 07:09 PM   #2
whiskeythrottle
whiskeythrottle's Avatar
Oddometer: 46
Make sure you have all the hoses are on correctly, and then - check to make sure the vacuum hose isn't collapsed or kinked.
If that doesn't solve it, get another pump. They're pretty common in northern lands as most snowmobiles use a similar vacuum pump. I reckon, however, that snowmobiles aren't too popular there downunder.
whiskeythrottle is offline   Reply With Quote
Old 01-06-2007, 10:45 PM   #3
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,247
I bumped up a fuel pump thread for you from a while back.......Probably many more but not so easy to search out.......
gunnerbuck is offline   Reply With Quote
Old 01-07-2007, 04:17 AM   #4
OldDog OP
OldDog's Avatar
Oddometer: 4,678
Thanks Gunner, I wasn't sure if these pumps were also used on the 640. I'll give the gravity feed trick a try, pressurising the tank didn't. Dammit
Old 01-08-2007, 02:28 AM   #5
rjf
SBS's #1 fan in January
rjf's Avatar
Location: Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
Oddometer: 4,376
Turn the fuel tap on
bloody spoilt BMW riders
Central Coast ADVenture bike training courses and 1 on 1 lessons - For details Click HERE
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadslide, thoroughly used up, totally worn out and loudly proclaiming- WOW-WHAT A RIDE!
rjf is online now   Reply With Quote
Old 01-08-2007, 04:23 AM   #6
OldDog OP
OldDog's Avatar
Oddometer: 4,678
Eh?
Fuel tap........................?
I wish it as that easy! Actually this thing mysteriously flamed out on Shane and we never got to the bottom of it......have now, bloody rooted pump eh. No big drama's though i've made one good one out of the two i just got it running, bet the neighbours arn't impressed
Old 01-08-2007, 12:55 PM   #7
Jan from Finland
Registered
Oddometer: 567
A simple question, does it pump fuel from the tank if the cap is open? Tank venting might be blocked.
Jan from Finland is offline   Reply With Quote
Times are GMT -7.   It's 02:28 AM.
