Old 01-11-2007, 11:36 PM   #1
CDG OP
CDG's Avatar
Oddometer: 215
Electrical help 640 ADV
I have a gremlin or two in my bike it is a 98 640 ADV and was in need of some help or links or something.
Ok when I picked it up the battery was flat, so I have since charged it but it only seems to get say, 15 or 20 starts before she's all over and all you get is this clicking noise.
So what I did today was go to both the battery shop and an auto sparky to see what the go was.
The battery shop put a meter on the battery and it had some 12.45v showing which looked good ( this was after me charging it ), so I then started it up and at idle it dropped down to 12.2 or something like that so the next thing I did was rev it to about 3500rpm and all that happened was the volts started to rise but very very slowly almost like counting 12.45, 12.46, 12.47, this seemed a bit slow.
The guy seemed to think it was the regulator/ rectifyer which is what I was also thinking, so I went down to see the sparky and he told me the volts should go up quick as and pretty much told me to replace the regulator and it should be sweet.
When I went to leave him it would not start again, so I got a jump and rode it home. Once home I checked the battery while not running and I got 12.4Volts hit the button and nothing but the friggin clicking again and the slowest turning over ever.
The regulator is one thing, and I will replace it but why would it not start with 12+ volts in the battery?
I'm electricaly stupid so any help would be much great
CDG is offline   Reply With Quote
Old 01-12-2007, 12:03 AM   #2
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,205
Hopefully your gremlins will sound familiar to some other unlucky soul and you will get your answer.
I can offer a weak test: some folks who have had weak batteries have used the manual decompression lever to take some of the heat off the starter just for a wee bit o' time - don't hang on the bugger! But I tend to agree that 12+V should do something better than "clicking".
You don't have access to another similar battery that you know is good? Hopefully someone will post how to test the regulatory rectifier for ya.
An "electrical" link from the index:
http://www.advrider.com/forums/showthread.php?t=107961
(check out Happe's regulator tests )
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 01-12-2007, 12:31 AM   #3
bmwktmbill
Traveler
Oddometer: 5,047
CDG,
A couple of things from a guy who is also having a battery issue with symptoms like yours except my regulator is putting out, maybe too much.
Check your meter against another on to make sure it is accurate.
If you are running a "sealed battery", break into it to make sure it has electrolyte.
My battery would charge but not hold a charge(no electrolyte) and my meter was reading a volt high.
I would charge the battery disconnected and let it sit for a couple of days to make sure it holds a charge and then hook it up in the bike and do the same. I messed with mine all summer.
Thank goodness the bike kickstarts easily.
Bill.
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 01-12-2007, 12:50 AM   #4
CDG OP
CDG's Avatar
Oddometer: 215
Thanks guy's this give's me a start for sure.
It's all new to me atm as I've never done anything to do with electric's at all.
Happe's regulator test should maybe sort out whether she's buggered or not.
Old 01-12-2007, 01:44 AM   #5
crazybrit
crazybrit's Avatar
Oddometer: 8,553
You need to load test the battery. Any decent shop can do this. Hooking up just a volt meter won't prove much.
According to the 98 LC4 repair manual, @5000rpm (on a battery which is 90+% charged] a voltmeter across the battery terminals should read betwen 14 and 15VDC.
If this isn't the case you need to verify the stator output before you can be sure it's the R/R.
There are plenty of good charging system troubleshooting guides around, Electrex/Electrosport used to have a good flowchart online.
Tony
crazybrit is offline   Reply With Quote
Old 01-12-2007, 04:31 AM   #6
CDG OP
CDG's Avatar
Oddometer: 215
Just done a bit of mucking around with the multimeter and the strangest thing seems to happen.
At idle (1700ish rpm) it stays around 12.7-12.8volts, at 2000rpm's it goes up to just over 13v, 13.09-13.12 but then any more revs and the volts go down constantly to around 12volts!
Another question when the key is off volts are say 12.5-12.7, but with the ignition on it drops of hard and fast to say 10v real quick, I understand that the lights and whatnot require power but is this normal?
Old 01-12-2007, 08:44 AM   #7
bergdaddy
tire guy
Oddometer: 10
a good hot battery will test out at 13 plus volts.12.4 is not enough..also if the battery internally shorts out the ktm will not run learned this from experience in baja.i thought my electrical system was fried .replaced the battery bike started and ran great..i am a ktm dealer in las cruces new mexico and ride lc4s all the time..put the battery on a charger at two volts let it set for five hours.test it .if you dont have at least 13.2 volts replace it .a reg rec for that bike is over 100 dollars from ktm..start with the battery it is probably the cause ...tim
bergdaddy is offline   Reply With Quote
Old 01-12-2007, 10:27 AM   #8
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
I'm thinkin' you mean 2A not 2V... no?
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 01-12-2007, 10:38 AM   #9
crazybrit
crazybrit's Avatar
Oddometer: 8,553
2A is a lot IMHO
I never use more than a 0.5A charger. KTM Manual recommends 0.8A.
The manual states, just for completeness when measuring the voltage of the removed battery
>12.7v - fully charged
~12.5v - 75% charge, charge for 4h @0.8A
~12.2v - 50% charge, charge for 7h @0.8A
~12.0v - 25% charge, charge for 11h @0.8A
~11.8v - 0% charge, charge for 14h @0.8A
Old 01-12-2007, 10:26 PM   #10
CDG OP
CDG's Avatar
Oddometer: 215
Convinced it was thr R/R I went out and bought a new one only to come home and find out that the problem is still there.
An expensive lesson learnt.
I posted on the Oz forum that I tried another battery on the bike and this didnt change anyehing which is why I bought the R/R, silly me.
Old 01-12-2007, 10:55 PM   #11
crazybrit
crazybrit's Avatar
Oddometer: 8,553
Like I said earlier, "If this isn't the case you need to verify the stator output before you can be sure it's the R/R". Perhaps you should have read more closely
The R/R just regulates the incoming A/C. If that isn't correct, it can't perform magic. I'm not sure on the KTM but on other bikes you can just disconnect the R/R and measure the stator output, usually 3 wires in.
Tony
Old 01-13-2007, 01:13 AM   #12
CDG OP
CDG's Avatar
Oddometer: 215
Your right mate I should of read a bit more closely.
I took a punt, and when I rang KTM just to price it should I need one, the guy told me the he was 99% sure thats what It would be.
Bit of the old Blind leading the blind I reckon.
Old 01-13-2007, 01:19 AM   #13
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,110
I would suggest to inspect your wiring for abrasions at any rub points , an intermittent short could be the cause of your troubles.
gunnerbuck is offline   Reply With Quote
Old 01-13-2007, 09:46 PM   #14
CDG OP
CDG's Avatar
Oddometer: 215
Probably wouldnt hurt as most of the bits I have played with are pretty ordinary looking to say the least.
Old 01-13-2007, 11:04 PM   #15
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 760
CDG.
I am having the same problem as you are. Battery is reading about 12.4V after sitting for a week after a charge. But not enough to crank the motor over properly.
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Times are GMT -7.   It's 10:48 AM.
