Old 10-11-2014, 04:30 PM   #1
Sumi OP
Sumi's Avatar
Oddometer: 1,799
9x0 fly wheel bolts question
Hi!
Would it be possible to check the bolts with an endoscope through the big hole on the stator cover?
Old 10-11-2014, 05:22 PM   #2
Sumi OP
Sumi's Avatar
Oddometer: 1,799
Okay, I've found this picture in the forum, and I guess it answers my question:
Old 10-11-2014, 05:37 PM   #3
Sumi OP
Sumi's Avatar
Oddometer: 1,799
However, does anybody know a method to test the stator (and by this I mean if it got chewed up by the flywheel bolts) without taking off the cover?
I've measured the points on the 3-yellow-wire connector, and they all measured 0.3 Ohms.
Old 10-12-2014, 03:03 AM   #4
dmn0507
dmn0507's Avatar
Oddometer: 352
The stator should be attached to the cover and come off together with it, in that pic all the 3 bolts went loose or it was placed inside the rotor after removing the cover. EDIT, got your point, no room for endoscope :)
I'm not an expert, but if the stator is a little chewed it might have some shorts within the coils, but most probably those are not gonna change a lot the ohm reading, until the wire is broken.
http://www.instructables.com/id/Rebu...eting-the-job/
dmn0507 is offline   Reply With Quote
Old 10-12-2014, 03:09 AM   #5
DirtyADV
DirtyADV's Avatar
Oddometer: 2,324
Lay bike on its side and you should be able to pull that cover easily, gasket is metal and can be reused several times.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 10-12-2014, 03:44 AM   #6
Sumi OP
Sumi's Avatar
Oddometer: 1,799
Thanks for your replies guys! I appreciate it!
I've tested all 3 outputs on the stator, and they are all giving about 16-17VAC @IDLE and 62VAC @5000rpm. I think this means that the coils are ok, so I'm not sure I want to pull the cover. I'm afraid of fucking something up if I do
Times are GMT -7.   It's 04:27 AM.
