Old 07-08-2010, 06:46 PM   #151
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,893
Jet
Simplify - match shaft or tooth pick will do the job. Just puch it into the centre of the jet and it'll hold it for retrieval.
Pete
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 07-26-2010, 05:01 AM   #152
ElChico
East Yorks
ElChico's Avatar
Oddometer: 83
Laugh Thanks for great advice!
Just checked my plug and the hole didn't seem blocked at all, but was changing the sprocket and thought I should check it. I used very sharp pointed tweezers to pull the blighter out.. - well suggested whoever it was!
Cheers!
Col
ElChico is offline   Reply With Quote
Old 07-28-2010, 10:58 AM   #153
skipman
skipman's Avatar
Oddometer: 184
Mine was completely stopped up(6,000 miles).Like to have never got it out,my torch tip cleaners were too big, had to use guitar string.
skipman is offline   Reply With Quote
Old 09-04-2010, 10:22 PM   #154
ZReX12
Oddometer: 30
Word of warning, never play with the clutch lever with the actuator cylinder pulled off from the push rod, unless you really want to replace the cylinder......
ZReX12 is offline   Reply With Quote
Old 09-05-2010, 11:13 AM   #155
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,543
Pete
+1
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 04-13-2011, 05:10 PM   #156
guns&coffee
Gnarly!
guns&coffee's Avatar
Oddometer: 1,263
Where?
I'm having shift issues that seem to be related to engine RPM's and bike temp. Where can I get an oil jet for my 04 950?
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '75 Husky 360WR/CR,
guns&coffee is offline   Reply With Quote
Old 04-13-2011, 05:13 PM   #157
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
If you have an '04, it should have a .30 oil jet already. My '03 did. Otherwise, the part number is: 60038029200
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 04-13-2011, 08:17 PM   #158
thugdog
Druid Revisionist
thugdog's Avatar
Oddometer: 396
clutch pushrod and oil jet work together for passing lubricating oil into clutch.
my late '03 early '04 had a shiny (i.e., too FAT) pushrod, and an oil jet with no hole whatsoever. bike shifted rather peculiarly until i updated to the narrow pushrod and fitting a 0.03" orifice oil jet.
also, i have seen a few splintered (broken) pushrods, so i would perform a thorough autopsy if problems persist.
....there's nothing more permanent than a temporary solution
thugdog is offline   Reply With Quote
Old 04-14-2011, 12:30 AM   #159
spannerman
spannerman's Avatar
Oddometer: 51
My local dealer was going to take 7/10 days to get one so i got dellorto main jet from ebay about 10th of price exactly same part cured mine
spannerman is offline   Reply With Quote
Old 04-15-2011, 02:30 PM   #160
K2m
....58....
K2m's Avatar
Oddometer: 2,238
I did the Feliciani clutch mod, but left the #30 in. Also fitted a FP shorter lever from black dogs shop. A vast improvement in clutch action and feel. It feels as good as the clutch on my GasGas 300. Incredible, really different. Feels like a new clutch, well worth doing. Clutch slave is an Evo.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 04-15-2011, 06:32 PM   #161
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,893
When you say you did the Meoni clutch mod K2m - is that the drilling of the basket? I ask because Ive heard a couple of different versions??? Also how were your ramps when you pulled it apart?
Pete
Old 04-15-2011, 09:20 PM   #162
Balsta
Oddometer: 400
Cleaning mess can be avoided...
Instead, I bought a handful of new jets (.50 mm). Replace and discard the plugged ones.
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 04-16-2011, 06:32 PM   #163
K2m
....58....
K2m's Avatar
Oddometer: 2,238
That's it just drilled the basket, but did not go up in jet size. Ramps were fine, but two of the pins on the gear selector wheel were working their way out. I punched them in and then center punched the surrounding alloy to spread the metal...... and hopefully hold them in.
Old 04-16-2011, 07:28 PM   #164
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,893
Did you have any 'symptoms' before you did the mod - or was it done for the improved oiling?
Pete
Old 04-17-2011, 01:30 AM   #165
K2m
....58....
K2m's Avatar
Oddometer: 2,238
There was one thing, it made the clutch feel not right........ It was slow to feed out, not real slow, and did not slip, I thought it was the double seals of the Evo slave. I even cleaned and lubed it to no avail..... now it's perfect........ But the standard KTM clutch leaver is rubbish to your hand. Those FP (short) leavers are worth the money.
Times are GMT -7.   It's 04:35 PM.
