Old 04-27-2011, 01:20 PM   #196
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Originally Posted by ttraynor View Post
. Plus I see the brass is not drilled thru. Now what?
Since your bike is New, Make a Warranty Claim. Show it to your Dealer and see if they have a Replacement, if not ask them if it is OK to Drill it out while you are waiting on a New One.
AdvGa is offline   Reply With Quote
Old 04-27-2011, 01:21 PM   #197
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
OK--Got the jet out on my 2010 Supermoto 990 R and there definitely is NOT a thru hole in it at all. I see the pinhole started in the hollow side but it is NOT drilled thru. I tried poking wire and pressure air hose. Plus I see the brass is not drilled thru. Now what?
We're talking about the ADV and SE bikes here. Your SM may be different in this aspect.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 04-27-2011, 01:25 PM   #198
ttraynor
Oddometer: 32
OK. I will order another one as I am sure my dealer is clueless and compare. For now, back in goes the old one.
Thanks.
ttraynor is online now   Reply With Quote
Old 04-27-2011, 01:52 PM   #199
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Thanks.
Looked at the fische for your bike and it shows a "30" clutch oil jet:
60038029200 REDUCING JET 30 M6X0.75
Apparently the troll on the assembly line in Mattighofen didn't check the jet before installing it in your engine. Fortunately, they seldom f^$# up more than twice on a single bike.... cough, cough,
-cp
Old 04-27-2011, 01:54 PM   #200
ttraynor
Oddometer: 32
thanks--It is the 30 saw the number. The 30 should be drilled--correct?
Old 04-27-2011, 01:57 PM   #201
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Correct. The steeler should give you a new one under warranty. I don't need to tell you to look at the replacement carefully. See if you can get "something" extra for your trouble.
-cp
Old 04-27-2011, 04:29 PM   #202
ttraynor
Oddometer: 32
The shifting has become notchy--and I just changed the oil to little avail. I may try to press them to inspect clutch maybe?
Old 04-27-2011, 07:24 PM   #203
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,914
Just checked mine. It's clear!
'06 KTM 950S Adventure
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox.
DakarNick is offline   Reply With Quote
Old 04-27-2011, 07:57 PM   #204
heffa
Canyon Hillbilly
heffa's Avatar
Oddometer: 1,008
Remove the outer clutch cover and watch the pressure plate as you pull the clutch lever. It should move proportionally to the lever. If not you may have a bad slave cylinder, master cylinder, or air in the clutch line.
Originally Posted by MortimerSickle View Post
Mine would nearly disengage, but still drag some. I flushed, and bled the system, and the problem was cured.
Originally Posted by FuTAnT View Post
Just do both. I'm sure Pyndon recommended in his thread that the clutch be bled with every 6000 or 7000 km service, as he thought there was a close link to the slave longevity and bleeding the fluid regularly. Easy enough, check the oil jet and flush the system routinely and it'l save you heartache.
Thanks guys. I will work on it this weekend, I will report my findings...
Well, Strip my gears and call me Shiftless...
She said, " Your a Flippin' Moron!"
heffa is offline   Reply With Quote
Old 05-04-2011, 04:47 PM   #205
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 75,190
well that little jet was a pita to get out.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
My Wanderlust
Misery Goat is offline   Reply With Quote
Old 05-04-2011, 10:59 PM   #206
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,850
+1
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 05-04-2011, 11:09 PM   #207
EZ300
EZ300's Avatar
Oddometer: 1,116
Just did mine. I swear there was no hole drilled in it.
Put the red tube from the WD40 can up to it and tried to blow through it. No luck. Must be plugged or no hole...
Nah, I'm just retarded. Soaked it in some brake cleaner and SHAZAM! It's all clear now. Now I get a nice spray jet of WD40 through it.
Slow speed shifting seems less notchy...
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 05-05-2011, 07:28 AM   #208
Phil in K.C.
Oddometer: 504
I tried and tried to get mine out to no avail....did the E string thing and POW!... poked right through.... unbelievable the difference in the way it shifts...still would like to get it out but at least I know I can get it clear.
'06 950 Adventure
Communism doesn't work because people like to own stuff......Frank Zappa
Phil in K.C. is offline   Reply With Quote
Old 05-05-2011, 03:09 PM   #209
tomdubz
getting there
tomdubz's Avatar
Oddometer: 518
Maybe I missed it but it's worth repeating. I'm a big fan of the shopvac crevice tool removal technique. Maybe it's not the most efficient but it's still fun.
This is my signature: TD
tomdubz is offline   Reply With Quote
Old 05-05-2011, 07:00 PM   #210
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,914
I used a small bolt with a little glob of that sticky picture-hanging putty to stick it and pull it out.
Times are GMT -7.   It's 02:31 AM.
