Old 05-22-2011, 08:16 AM   #211
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 75,146
fwiw, I've noticed since cleaning my jet the neutral light is harder to locate. No problem finding neutral but the light doesn't seem to always come on like it did.
Don't know if the clutch jet impacts the functionality of the neutral sensor or not. they seem like separate issues to me.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
My Wanderlust
Misery Goat is offline   Reply With Quote
Old 05-22-2011, 08:29 AM   #212
Black Hills
Oddometer: 1,183
Originally Posted by tomdubz View Post
Maybe I missed it but it's worth repeating. I'm a big fan of the shopvac crevice tool removal technique. Maybe it's not the most efficient but it's still fun.
take a 2' piece of fuel line and hold one end in the hose of your shop vac (sela the rest of the vac hose with your hand) stick the other end of the fuel line in the hole for the oil jet and the jet will stick to the end of the fuel line, works like a charm.
Black Hills is online now   Reply With Quote
Old 05-22-2011, 10:29 AM   #213
vf-17
vf-17's Avatar
Oddometer: 184
Or just use your mouth and suck through it like you would a straw... Just as effective.. Without having all the hassle of getting the shop Vac. Out.
05.5'KTM 950ADV. Orange with Akras. & 19/17 Black capo's from Woody's... ZUMO 550
05'KTM 450EXC.(plated)
00'KTM 400EXC.(plated)
97'KTM 360
96"XR 400
BIG orange KTM motorcycles and BIG orange Tennessee football....GO VOLS!
vf-17 is offline   Reply With Quote
Old 07-10-2011, 01:03 AM   #214
FuTAnT
KTM 990ADV
FuTAnT's Avatar
Oddometer: 341
Originally Posted by SFKLR View Post
The jet hole is so damn small, I can barely see through it. Seriously, I don't know if a human hair can get through there, let alone a guitar string. Since I could see light, I figured it was good, and I put it back in. Hope it's OK. NOt sure I did anything to help it. In fact, it appears I tweaked the copper slot a bit. At least i didn't torque the crap out of it going back in. Hope she shifts OK tomorrow.
Not to be a smart arse, but when you take it out you might want to clean it, rather than just look at it. Blow some carby cleaner or kerosine etc through it or a fine guitar string to make sure it's clear. You may have just been able to see through it, but it still could have been slightly clogged.
Cameron Corner - 6 Day Blast
FuTAnT is offline   Reply With Quote
Old 09-18-2011, 11:08 AM   #215
madbiker1
Evilman
madbiker1's Avatar
Oddometer: 162
Dell'orto Jet Sizing
OK, I did my jet yesterday. I had noticed a few months back that the shifting suddenly got notchier and wasn't butter smooth but had no idea why. I came across this thread a couple weeks back and decided to do it. I think it was plugged but I used a strand of electrical wire to clean it out. Sprayed it with carb cleaner and it seems to be fine. Reinstalled. I did struggle a bit to get the jet out of the hole but after finding one bobbipin, that was the answer - by far the easiest tool I found to use after trying a bunch.
I haven't taken the bike for a run to see if it makes a difference as it's still in pieces until the suspension gets back but I was mulling over the idea of getting a larger jet as I do a fair bit of slow speed clutch riding. I'd like to get a .040 and a .050 to experiment with and I don't want to drill. I was thinking about heading down to my local Lordco to see if I could get such a thing today - as I'm very impatient
On ebay, I saw two different sizes of 6413 Dell'orto main jets listed - one a 6mm http://www.ebay.co.uk/itm/dellorto-t...item5d2dd40c9a and one an 8mm http://www.ebay.co.uk/itm/dellorto-t...item20b7b416bc
Which do I want? And for a .040 and a .050, which Dell'orto number does it relate to?
madbiker1 is offline   Reply With Quote
Old 09-18-2011, 11:19 AM   #216
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Look at this first:
http://www.advrider.com/forums/showp...5&postcount=84
That specific issue is discussed in the HOW
"The oil jet selected by the engineers at Mattighofen for the 950/990 Adventure is a compromise based on the assumption that the bike will be used mainly on the street and gravel/dirt roads. If the bike is used hard (ie: slipping the clutch to manuver tight trails or get through rough terrain or deep sand, or racing conditions) the clutch jet size should be increased (.40 - .50mm) and possibly some modifications to the inner clutch hub made (AKA the Feliciani Mods) to accomodate the extra abuse. Don't go too big; unless you're racing the bike, the 1.0 mm size Feliciani talks about for desert racing is too big for non-racing use. Be advised that some "streetability" may be compromised even with the .40- .50mm sizes (ie: hard to find neutral, clunky shifting at slow speed, etc.). Best to start small and work your way up. Have a spare .030mm so you can go back down when you get too big."
AdvGa is offline   Reply With Quote
Old 09-18-2011, 11:36 AM   #217
madbiker1
Evilman
madbiker1's Avatar
Oddometer: 162
[QUOTE=AdvGa;16880838]Look at this first:
That specific issue is discussed in the HOW [/QUOTE=AdvGa;16880838]
Sorry, when I said "what size do I want," I was referring to the head size of 6mm or 8mm. I want to try BOTH the .40 and the .50 hole size.
Old 01-17-2012, 03:42 AM   #218
dirtypumpkin
"Monster Truck Bike"
dirtypumpkin's Avatar
Oddometer: 13,972
Just wanted to say thanks for all the info here.
Was experiencing some hard upshifts, and the other day I couldn't
get it any higher then 3rd. At least I only had 10 miles to get home.
So after searching around I thought the worst, damaged shift roller wall.
But after running some fine wire through the oil jet and adding a 1/2 quart,
its shifts great now. My sight glass was reading correct level, until I cleaned
the jet, then it needed about a 1/2 quart to get to max at temp. Seems like
I was starving my trans of oil.
I recommend this for anyone experiencing hard shifting.
From now on that thing gets reamed every oil change.
Give big space to the festive dog that makes sport in roadway.
Avoid entanglement of dog with wheel spokes. - Old Honda Manual
If you wish to travel far and fast, travel light. Take off all your envies,
jealousies, unforgiveness, selfishness, and fears. -- Glenn Clark
dirtypumpkin is offline   Reply With Quote
Old 01-19-2012, 04:03 AM   #219
K2m
....58....
K2m's Avatar
Oddometer: 2,242
Sorry mate It just does not work the way you are describing it..... And the clutch jet does not lube the transmission. It looks like you were low on oil. It must be an SE thing as the ADV would not suffer this....................................... ....... It still does not make sense tho as the oil level would be controlled by the return pump. When the motor sits it will fill with excess oil from the tank because of the lack of a check valve. When the motor is started the return pump will return the excess oil to the tank. It's return to the motor must be controlled by the incoming pump. A dry sump motor does not depend on oil level in the tank..... in fact it would make no difference whether that tank is 1.5Lt or 3.5Lt as the level of oil in the transmission is controlled by the return oil pump.
If you are due to do a waterpump soon, I would advise you look below the clutch at the round thing with pins through it...... and check that the pins are all in place as that could relate to your 3rd gear problem.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 03-08-2012, 10:20 AM   #220
stevodadevo
What happened?
stevodadevo's Avatar
Oddometer: 177
Is there supposed to be a bolt "cap" that has to be removed before accessing the jet? I went to check the oil jet today and there was nothing covering the hole. I tried inserting a small screw driver but couldn't feel any "slot" to grab to unscrew it. I also tried shooting some WD40 in the hole in case it was full of crud. No luck.
Any ideas?
stevodadevo is offline   Reply With Quote
Old 03-08-2012, 10:27 AM   #221
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,269
#27 should be covering the jet (#29). If not and you don't have oil spewing all over the place,, you have other problem.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 03-08-2012, 10:34 AM   #222
stevodadevo
What happened?
Oddometer: 177
Well THAT'S no good. What do you think my plan of attach should be here?
I noticed that area was pretty dirty because it was covered in some oil but I assumed it was just road grime and chain lube. Perhaps the jet is clogged up and not able spew it's blood everywhere.
Old 03-08-2012, 01:24 PM   #223
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,269
That cap is a socket head (allen),,,, are you sure that's not what you are observing??
If it's that caked up around there, you need to really clean up that area before removing the cap anyway.
If the jet was that clogged, you would have toasted the clutch long ago.
Old 03-08-2012, 01:50 PM   #224
stevodadevo
What happened?
Oddometer: 177
Looking at that picture, that cap bolt is not there. Unless I'm misunderstanding how the oil jet works, wouldn't there be oil shooting out of the hole without the bolt?
stevodadevo screwed with this post 03-08-2012 at 02:18 PM
Old 03-08-2012, 02:20 PM   #225
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,269
[QUOTE=stevodadevo;18168702]Looking at that picture, that cap bolt is not there. Unless I'm misunderstanding how the oil jet works, wouldn't there be oil shooting out of the hole without the bolt?[quote]
There is full oil pressure there. Without the bolt, the oil engine oil would probably drained in about 2 minutes.
IIRC, Oil comes in through a port just below the cap. Then it goes down through the jet and through the clutch pushrod to the other side of the engine.
Can you post a pic?
Times are GMT -7.   It's 02:42 PM.
