Old 03-08-2012, 01:22 PM   #226
stevodadevo
What happened?
stevodadevo's Avatar
Oddometer: 177
There is full oil pressure there. Without the bolt, the oil engine oil would probably drained in about 2 minutes.
IIRC, Oil comes in through a port just below the cap. Then it goes down through the jet and through the clutch pushrod to the other side of the engine.
Can you post a pic?
I'm at a loss as to how I could have no bolt and at the same time not be losing oil. I'm starting to get worried.
I'll post pics when I get home.
stevodadevo is offline   Reply With Quote
Old 03-08-2012, 02:01 PM   #227
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,462
The pic on the right shows where it should be.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 03-08-2012, 02:33 PM   #228
stevodadevo
What happened?
Oddometer: 177
If that's what it's supposed to look like, then the bolt is not there.
Old 03-08-2012, 02:34 PM   #229
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
Originally Posted by slackmeyer View Post
I use a Q-tip to get the screw out,
Thanks! This worked great for me, just pressed it in after unthreading the jet, and it stuck right to it.
viola-tor is offline   Reply With Quote
Old 03-08-2012, 05:16 PM   #230
stevodadevo
What happened?
Oddometer: 177
Originally Posted by stevodadevo View Post
Looking at that picture, that cap bolt is not there. Unless I'm misunderstanding how the oil jet works, wouldn't there be oil shooting out of the hole without the bolt?
Nevermind!! I'm retarded. The bolt is there. Thanks for the help.
Old 03-08-2012, 06:41 PM   #231
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,462
Old 04-14-2012, 01:20 PM   #232
ultrachrome
Poser
Oddometer: 274
The jet from my SMT is marked "30" but it doesn't have a hole on the top of the cone. There is a hole on the bottom but I can't get anything to poke through.
ultrachrome is offline   Reply With Quote
Old 04-14-2012, 01:34 PM   #233
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
My thoughts would be it's plugged.....
I think everything newer then 05' came with a JET, not a plug.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 04-14-2012, 01:46 PM   #234
Patacca
Pimp my SE italian style
Patacca's Avatar
Oddometer: 568
If you aren't sure, open to MAX!!!
www.raffaellophoto.com
check out my pimped SE @
http://www.myktm.it/viewtopic.php?f=50&t=223
Patacca is offline   Reply With Quote
Old 04-14-2012, 02:00 PM   #235
ultrachrome
Poser
Oddometer: 274
I got it. Even though the top of the cone looked all brass with no hint of a hole, I started picking away at it and ultimately got it opened back up by with a few spins of an Xacto blade.
Old 04-14-2012, 06:00 PM   #236
FuTAnT
KTM 990ADV
FuTAnT's Avatar
Oddometer: 342
I'm sure it's been mentioned before, but electric guitar strings are brilliant for cleaning these jets, and other similar jets of different sizes. A pack costs all of $10 or so, great for the toolbox.
Cameron Corner - 6 Day Blast
FuTAnT is offline   Reply With Quote
Old 04-14-2012, 08:11 PM   #237
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
Dang, That was REALLY plugged. I'd check your booster system "ramps" and make sure it's not cooked before you have more issues for lack of oil flow.
Old 04-14-2012, 08:37 PM   #238
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Here's what the New Version (Convex design) of the Jet (hole seems smaller) Looks like whereas the Old Version was Concave.
http://www.advrider.com/forums/showt...196367&page=12
" I got a new #30 jet, installed it, and immediately enjoyed the drag-free clutch action I had before the mod.
One nice little detail about the replacement jet-
If you look close, you will see the center area of the jet is convex, and resembles a volcano's profile, as opposed to my original jet which had a concave center. The old jet allowed even the tiniest amount of debris block the the extremely small opening.
The new-style jet will require a relatively large amount of debris to pile up high enough to restrict flow. Nice!"
AdvGa is offline   Reply With Quote
Old 04-14-2012, 09:15 PM   #239
ultrachrome
Poser
Oddometer: 274
I literally unwound the E string on my Martin (on which I can currently play three or four chords) and it still would not poke through.
I don't know no booster system ramps. Please elaborate.
I haven't noticed any shifting issues. I forgot to check it during the bike's first oil change last year. I just performed its second oil change. The bike has just over 5000 miles.
Old 09-14-2012, 11:20 AM   #240
propilot10
Oddometer: 121
Originally Posted by aurel View Post
I tried to get the jet out that way without success...
I was not able to put enough force vertically on the screw so the screwer was sliding out of the head screw everytime before it starts turning...
I'll try with a hot engine But what a pain to access that screw, I'll try to make a special tool to make the job easier...
I tried this method. Worked like a charm. Little clay bar from my car detail supplies on the end of a small screw driver pulled it out. But I failed to check the box end of the wrench which was full of crap from my 73' bronco rebuilt. Yup I dropped a ton of crap in the hole. Cleaned it all out and put it back together. Working great. Life, live and learn. Die and forget it all.
propilot10 is offline   Reply With Quote
Times are GMT -7.   It's 05:49 AM.
