Old 09-14-2009, 08:24 PM   #121
LoFlow
Oddometer: 972
Originally Posted by ridewestKTM
-if you can feel the oil pulse the clutch then the jet's clean - no need to check.
Are you saying that you can feel the pulsation in the cluch lever?
LoFlow is offline   Reply With Quote
Old 09-14-2009, 08:31 PM   #122
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,698
No
No you feel it in the bike (like clutch drag)
My 950KTM makes me feel like a little kid again......because it's so tall!
ridewestKTM is offline   Reply With Quote
Old 09-14-2009, 11:33 PM   #123
Patacca
Pimp my SE italian style
Patacca's Avatar
Oddometer: 563
Could you explain better, could you show us some pics, are you selling his item?
Thanx
If you aren't sure, open to MAX!!!
www.raffaellophoto.com
check out my pimped SE @
http://www.myktm.it/viewtopic.php?f=50&t=223
Patacca is online now   Reply With Quote
Old 09-15-2009, 09:53 PM   #124
ridewestKTM
Oddometer: 1,698
Sorry forgot to respond
I did get one good picture of my quick jet. The thread was ~ who's tired of cleaning the clutch jet. I'll go look for the link. I was going to offer this for sale and gave away one proto-type which didn't seem to work. The dimensions were touchy and without a screw machine the fabrication was slow. If you're really wanting to try it I'll see if I can make a workable one.
Let me know. The concept is the jet is about 1" long and the jet hole meets a cross drilled hole about .25" up. The other end is slotted (or hex) and just below is an O-ring. The plug that filles the hole is drilled thru and the oring seals in that hole.
Old 09-15-2009, 10:17 PM   #125
ridewestKTM
Oddometer: 1,698
quick jet
http://www.advrider.com/forums/showt...ghlight=clutch
took a couple trys to get the pic right so go to the end
Old 09-16-2009, 12:12 AM   #126
Patacca
Patacca's Avatar
Oddometer: 563
Thumb
I remember to have read that thread, but I missed the final post...the most important...your pic!!!
That's simply amazing the best solution to that...unbeievable.
So please don't stopo you research, when you can produce the final piece tell everybody witha good advrtising in the vendors section or just write to these threads......
THANX for you studies about that you will be really useful to us!
Old 09-27-2009, 08:54 PM   #127
Thumper996
Thumper996's Avatar
Oddometer: 592
Well i took on the challenge today and removed my clogged jet and cleaned it.
Heading out on a four day trip Friday, so hopefully the recently noticed clutch drag will disappear after opening up the little hole witha strand of speaker wire.
Thanks to all for posting tips and tricks.
Thumper996 is offline   Reply With Quote
Old 10-07-2009, 01:59 PM   #128
sven520
Oddometer: 94
I removed the oil jet yesterday. It took 30 min. It was plugged solid, I couldn't get anything though it. I bought a finger drill kit off the Mac truck and put a .0225 hole though it. The noise went away the pulsing though the clutch lever went away. The down side to this is I can't find neutral and it grinds going
into gear. The new jet is on its way. Thanks for all the help.
sven520 is offline   Reply With Quote
Old 10-08-2009, 03:21 AM   #129
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,464
It seems that enlarging the oil jet always makes it hard to find neutral. I live with it as I'd rather have more oil to cool the clutch, judging by the colour of the metal plates it can get pretty hot when riding the dirt.
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 02-16-2010, 01:32 PM   #130
spannerman
spannerman's Avatar
Oddometer: 51
Just checked my 03 its got blanking plug any ideas who would carry these in stock need one for weekend hopefully going to ace cafe
spannerman is offline   Reply With Quote
Old 02-17-2010, 10:51 AM   #131
Chipper
Oddometer: 708
Dellorto jet size?
Anyone know which Dellorto jet their using? Is it the 6mm? I've got the rekluse and was thinkin' should increase size.
Chipper is offline   Reply With Quote
Old 02-17-2010, 11:22 AM   #132
spannerman
spannerman's Avatar
Oddometer: 51
Yep think so have ordered a 48 today will let you no how it goes
Old 02-17-2010, 07:05 PM   #133
vgstef
Oddometer: 197
Originally Posted by Patacca
I've a SE 2007 and in my engine it was 30 the jet. I removed it changing with a 60 and everything works perfect.
were did you get the 60 jet ?
Stephan
vgstef is offline   Reply With Quote
Old 02-18-2010, 02:54 AM   #134
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,876
Hey guys, I was told oil pressure is not too high on that bike.
So I suggest do not go too far on increasing pressure leaks on the lubrication system.
My 990Adv at 10k kms showed some initiation of wear on camshafts, which indicate poor lubrication. My mech says these bikes when hot raise 2.5bar at 6000rpm while Ducattis raise 6bar.
So any additional or increase on lubrication orifice reduce oil pressure.
Thought I should mention it.
Cheers.
Old 02-18-2010, 06:04 AM   #135
Patacca
Patacca's Avatar
Oddometer: 563
I bought my 60 jet in a shop of automotive parts.
Here in Italy it's quite easy to find a this kind of things because Dell'Orto it's an italian brand and all the old car with carbs where using these kind of things.
With jet #60 the bike goes like sharme, no issue at all, but all my friends who goes in Africa change it with #100 for sand and HI temperature and when they are back the change back to #60. So long no issues.
I believe that you may even ask that jet to your KTM Delear as it should be availlable. No idea of extra costs. Mine was 1 or 2 ....
CIAO
Times are GMT -7.   It's 02:39 PM.
