Old 06-14-2012, 09:59 PM   #5596
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,459
Originally Posted by XpressCS View Post
Got to play with the bike a bit today. My buddy isn't the best of photographers...
Nice pics considering they are action shots.
I think your friend did a pretty decent job.
You look good.
You might want to consider some protective gear.
Don't want to see you suffer any major injuries.
Not saying that you're a bad rider. Obviously you're not, but shit happens.
Mechanical failure can happen (subframe bolts do break on the KLR) or something in the road/trail could cause you to down.
I was downed once when my front tire caught a tree root coming out of a whoop.
I recently broke my fibula despite wearing knee high motocross boots.
However, if it wasn't for the boots, I would have had compound fractures of both the tibia and fibula.
And you'll get bad road rash wearing shorts and a T-Shirt for sure.
I did the drill through subframe bolt upgrade.
It's a bitch drilling it and takes a while, but well worth it.
If you keep the drill bit oiled and cool, it won't dull as fast and will do the job just fine.
EagleMike will give you two bits. One small and one large.
Start with the small one until through, then go to the large one.
Make sure you keep your carb covered so no metal bits get in it.
I covered the carb and actually used a vacuum during the drilling to minimize the issue.
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando screwed with this post 06-14-2012 at 10:03 PM Reason: My subframe upgrade bolts
RandoCommando is offline   Reply With Quote
Old 06-14-2012, 10:26 PM   #5597
XpressCS
Must. Have. Lumens..
XpressCS's Avatar
Oddometer: 1,309
We're working on protective gear, however I ride like that all the time. If I get messed up it's because of my own doing. My home town is very tolerant of anything with a motor and wheels, be it bike, trike, or quad
Helmet is NOT optional to me, at least protect my pretty face
I'm not going to get fully dressed up for a stroll, I'm more than confident enough I'm not going to do anything stupid (although jumping with road tires is pushing it quite a bit, hoping to change that soon). Very likely going to upgrade the subframe bolts to grade 8 or higher, there is a hardware store in town where I tend to splurge on stuff like that all the time
2015 Yamaha FJ-09
XpressCS is offline   Reply With Quote
Old 06-15-2012, 12:56 AM   #5598
2handedSpey
bunned
Oddometer: 237
I think your friend did a pret in it..
RandoCommando, thank you for the link to Clayton's story in your signature. I just read it. Wow... Thank you for the link.
Required reading, indeed. Thx
Originally Posted by kbasa View Post
If you're wearing Crocs, chances are that you're not smart enough to tie your shoes.
2handedSpey is offline   Reply With Quote
Old 06-15-2012, 02:35 AM   #5599
Velour Fog
Pants optional
Velour Fog's Avatar
Oddometer: 100
A bit OT but as the topic of the upper subframe bolt was mentioned.
The ones that come with the Motec crash bars are 10.8 grade, and I am lead to believe that these are about the strongest that you can get.
Is there that much strain that these break as well? Has it happened to anybody?
Scotty
Velour Fog is offline   Reply With Quote
Old 06-15-2012, 04:46 AM   #5600
MotoBoss
Bad Influence
MotoBoss's Avatar
Oddometer: 3,844
Scotty
It's not that there is that much strain ordinarily; but there can be considering load, terrain and riding habits (see above jumping man), but rather the "stock" set up is a two smaller bolt system. Drilling through the sub-frame and using one longer, stronger bolt lessens the chance of catastrophic failure and adds considerable strength.
Yes mine did pull out on one side but was able to complete the drill through without any problem for the fix.
Adventure Before Dementia
MotoBossMotoBlog
AdventureRiderRadio
Donate To ADV
MotoBoss is offline   Reply With Quote
Old 06-15-2012, 05:30 AM   #5601
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
Please take pics and post the progression for all to see.
I'm interested in seeing your restoration start to finish.
Grats and thanks
That's on the list. Along with a few other things
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 06-15-2012, 05:49 AM   #5602
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 667
I've never seen a KLR that high off the ground. Like playing with a sharp stick, fun till someone gets their eye poked out.
On the other hand, you go for it, killer kick a** pictures. It brings back an old saying:
"Those who can, Do. Those who can't, Teach".
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 screwed with this post 06-15-2012 at 06:11 AM
Danger4u2 is offline   Reply With Quote
Old 06-15-2012, 06:15 AM   #5603
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,979
I see many, many broken parts in your future. My predictions include the following:
1. Adios license plate
2. Adios fork seals (and rear shock, depending on mileage)
3. As mentioned above- subframe bolts
4. Adios plastic skid "plate". Hopefully, the drain plug doesn't go with it.
Even with my lower body weight (~165#) and upgraded suspension, my KLR completely bottoms out on stuff like that.
But have fun.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 06-15-2012, 07:00 AM   #5604
Wallachian Spikes
Wallachian Spikes's Avatar
Oddometer: 925
Got a bad knee these days so I haven't had my '06 more than 8-10 inches off the ground. Occasionally got my "00 2-2.5 feet off the ground & upon landing there would sometimes be a horrific screech that I couldn't figgure out. One day I was looking at my bike & noticed the forks were sticking up about 2 inches through the triple clap. Light bulb went off "hey maybe that was the screech I heard on those jumps?"
Wallachian Spikes is offline   Reply With Quote
Old 06-15-2012, 08:16 AM   #5605
XpressCS
XpressCS's Avatar
Oddometer: 1,309
But have fun.
We shall remedy these issues with time. I'm still amazed at how well the suspension soaked up the landings, but it still bottomed out. Not as hard as some of my other ATV's though.
This thing was never taken offroad before I got my hands on it, everything was in awesome shape (minus plastics) when I took it home so I'd imagine there's a lot of mileage on the suspension still.
2015 Yamaha FJ-09
Old 06-15-2012, 08:27 AM   #5606
newcastleadam
Artful Tagger
Oddometer: 3,455
Hopefully, but the stock suspension isn't really meant for jumps and awesome offroad fun. I'd expect it to die a horrible leaky death in short order
Good news is it can be rebuilt, giving you some customization, or go aftermarket for even more customization.
Adam
Old 06-15-2012, 09:17 AM   #5607
VikB
VikB's Avatar
Oddometer: 762
KLR's like ostriches were not meant to leave the ground...
safe riding,
Vik...
www.klr650blog.com
I didn't done the doo!
VikB is offline   Reply With Quote
Old 06-15-2012, 10:59 AM   #5608
RevBill
Irreverent Reverend
RevBill's Avatar
Oddometer: 2,167
.. LOL .. go have fun with it .. that's what they are for .. having recently busted my butt and my bike on a little off-road excursion I can appreciate your adventure-lust .. go for it .. just don't kill yourself for lack of gear .. that would suck ..
.. RE the bolts .. someone smarter than I discovered the weakness really lay in the fact that right as the shank of the bolt goes into the frame it ends (stock bolts), meaning that the shear load is right at a weak point (the skinny little part where the threads start and the meat of the shank ends) .. poor design .. simply replacing them with bolts designed to put the shank into the frame solves this problem .. stronger bolts even more so .. thats my understanding of the sub-frame upgrade kits that came out ..
"On the road less traveled there ain't no TP, bring your own and that will make all the difference.."
RevBill's SmugMug Shenanigans
My '06 KLR
RevBill screwed with this post 06-15-2012 at 11:16 AM
RevBill is offline   Reply With Quote
Old 06-15-2012, 11:00 AM   #5609
RevBill
Irreverent Reverend
RevBill's Avatar
Oddometer: 2,167
.. funny this .. good stuff .. I should learn this lesson ..
My '06 KLR
Old 06-15-2012, 11:34 AM   #5610
CA Stu
CA Stu's Avatar
Oddometer: 47,659
Scotty
It's my best guess that the ones that break are just a bit loose.
The little bit of wiggle allowed by loose bolts makes for constant loading and unloading of them, eventually breaking them.
I'll bet $5 that if 100 KLR owners go out and check their upper subframe bolts, at least 30 of them will be able to tighten the bolts 1/4 turn or more.
That said, I have the drill-through kit on mine.
Hey, at least the rear subframe bolts didn't break!
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Times are GMT -7.   It's 01:24 AM.
