02-22-2013, 02:24 PM
#6631 |
Where are my tools?
Oddometer: 862
2005 KLR 650 A bit beat up but works just fine. Powered by really angry canaries. 1985 Suzuki GS700E Some assembly required 1977 Cimatti City Bike. What, you call that a build thread? Officially stalled... |
02-22-2013, 02:32 PM
#6632 |
Where to next?
Oddometer: 596
[QUOTE What's that Spot carrier?[/QUOTE]
Looks like a Ram mount. I've got one like it. Works great.
On two wheels....That's my Happy Place! |
02-22-2013, 02:43 PM
#6633 |
Having fun
Oddometer: 676
Looks like a Ram mount. I've got one like it. Works great.[/QUOTE]
Agreed. Holds it very well.
BC 2011 RR: http://advrider.com/forums/showthread.php?t=704469 |
02-22-2013, 03:00 PM
#6634 |
World Wide Inmate
Oddometer: 2,120
Thanks for asking or discussing it guys.
I used to run a great magnetic and strap tank bag. There was a "port" in it that was intended to push wires through, that I poke a RAM ball through instead. There was a map pocket right behind that area.... in true KLR fashion, I took a piece of plastic bread board and cut it down to fit snug in the map pocket. I mounted the RAM ball on the "board" and the rest was history. It worked very well using SPOT's Ram bracket-shell thingy. I did not want one more device on my handlebars at the time. I loved having the SPOT, but loss of employment dictated I drop service & sold it. Kept the KLR though ![]() ![]() ![]() ![]() ![]() I had a second posistion for the SPOT. If weather was bad, or I was riding quite alone, I had another RAM ball hidden inside a Pelican case. FYI, the SPOT shot right throught the Pelican case as if it was not even there. ![]()
´¯`·.¸¸.·´¯`·.¸ ><((((((º> `·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ´¯`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((((º> Everything happens for a reason. "Still seeking the reason" Unstable Rider screwed with this post 02-22-2013 at 03:06 PM |
02-22-2013, 03:11 PM
#6635 |
Where are my tools?
Oddometer: 862
I'll hav eto see if they have any for the Spot1, I love my first generation Spot. Looking forward to finally using it on the KLR next month!
02-22-2013, 03:16 PM
#6636 | |
World Wide Inmate
Oddometer: 2,120
That used to be fun. Great way to remember where the hell ya been too.
´¯`·.¸¸.·´¯`·.¸ ><((((((º> `·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ´¯`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((((º> Everything happens for a reason. "Still seeking the reason" |
#6637 |
Where to next?
Oddometer: 596
Those are two interesting places to mount a SPOT.
Tank bag mount looks good. I'm surprised it worked thru the Pelican case. I've got mine on the bars. Edit: Screenshot post is a great idea.
02-22-2013, 03:31 PM
#6638 |
Where are my tools?
Oddometer: 862
Spot folks - Check out www.spotwalla.com, it will track your history forever.
Here is mine i fyou want o see what it looks like: https://spotwalla.com/tripViewer.php...84e53447653840 Adjust the History box to see how far back you can go.
2005 KLR 650 A bit beat up but works just fine. Powered by really angry canaries. 1985 Suzuki GS700E Some assembly required 1977 Cimatti City Bike. What, you call that a build thread? Officially stalled... GSequoia screwed with this post 02-22-2013 at 03:39 PM |
02-22-2013, 04:47 PM
#6639 |
Gear Whore
Oddometer: 1,965
Spot...
..I am a spot user too.... I tend to ride a lot by myself... I don't like the idea of having the spot mounted to the bike... If you are ever seperated from the bike you may be SOL..... I use the little carrier that I got with it and attach it to the shoulder strap of my Camelback. I have ridden with it like that many times and you don't even know its there.... but you always know its there if you need it... This way if the bike takes a dump off a cliff..(it could happen).. and I don't at least I still have my spot to hopefully call for help....
Just a thought.... WP |
02-22-2013, 05:10 PM
#6640 |
Lust for dust...
Oddometer: 6,055
You guys sure chatter a lot for a pictures thread.
... grease, grit, and mud are runnin' in my blood. |
02-22-2013, 05:15 PM
#6641 | |
Oddometer: 36
Do you adjust the front height some how, and if not does the resulting sag cause stability problems? I could use a little lift, but I do too much gravel- forest type roads to create stability issues.. I rarely have more than a small repair kit and a change of clothes so I'm not loaded heavy. |
02-22-2013, 07:35 PM
#6642 | |
n00b savant
Oddometer: 78
1978 KZ650B2A 2007 KLR650 |
02-23-2013, 07:10 AM
#6643 | |
Oddometer: 1,243
http://www.youtube.com/watch?v=mWQf13B8epw |
02-23-2013, 07:41 AM
#6644 |
World Wide Inmate
Oddometer: 2,120
I heard recently, that people not being able to read is the leading cause of illiteracy.
02-23-2013, 07:45 AM
#6645 | |
Forever N00b
Oddometer: 1,607
http://activityworkshop.net/software...une/index.html I don't claim it's perfect, but displaying tracks and deleting points (pruning) work OK. That program combined with a cheap nuvi (just to see if I wanted a GPS at all) work OK. Since I got the KLR I've downloaded tracks to the computer regularly. ![]() Pic of the KLR later that day by Wabassus lake WAY north of this bit of track:
Motorcycles are magical. Grinnin screwed with this post 02-23-2013 at 07:51 AM |
