Old 01-19-2007, 01:06 AM   #16
tintinopsella
tintinopsella's Avatar
Oddometer: 77
great work mate....wonderfull
tintinopsella is offline   Reply With Quote
Old 01-19-2007, 01:12 AM   #17
WeaponX
Broken ankle
WeaponX's Avatar
Oddometer: 164
very nice dash...
Originally Posted by ehatcher
640LC4SM
WeaponX is offline   Reply With Quote
Old 01-19-2007, 02:55 AM   #18
Will LC8
I stubbed my toe
Will LC8's Avatar
Oddometer: 587
Man Eric,
When you said your body work might be up for sale because of a fairing you weren't kidding.
What are you doing for the suspension. Are you doing springs and catridge emulators like you mentioned or are you going with new forks?
It was once said the man who can not touch the ground on his bike is destined to lay under it
http://abuddyforlife.org/
Will LC8 is offline   Reply With Quote
Old 01-19-2007, 05:31 AM   #19
Giggity
Giggity's Avatar
Oddometer: 754
Nice!
Giggity is offline   Reply With Quote
Old 01-19-2007, 06:15 AM   #20
awschmidt
ride-reckit-wrench-repeat
Oddometer: 90
Looks great. I have a .28 6061 bash plate and skid under mine (for sliding over rocks, fallen trees and the like).
The one problem I had was cooking my water pump. My plate flares out as it wraps around to act in place of crash bars. I created a little oven for my wp to simmer in and after installation, could only get a few thousand miles between repairs. I vented plate and wrapped the exhaust pipe to cure my problem. btw, your layup work is awsome (mine sucks). Did you use vacume bagging, wet out, or vacume infusion?
Kevin
awschmidt is offline   Reply With Quote
Old 01-19-2007, 06:25 AM   #21
DAM
Lets Talk About Ducks
DAM's Avatar
Oddometer: 391
eric that is fine fine work. thank you for sharing with us.
could you take some more pictures? i am curious about the fastening mostly.
"The Internet is a great place to get on the net"
Bob Dole
DAM is offline   Reply With Quote
Old 01-19-2007, 07:10 AM   #22
TomN
TomN's Avatar
Oddometer: 2,505
Very nice! Almost as pretty as a KLR now
TomN is offline   Reply With Quote
Old 01-19-2007, 07:45 AM   #23
Beez
Given to fly
Beez's Avatar
Oddometer: 5,832
Eek
Eric your F650 looks killer! Way to go! You should be proud of yourself.
Beez is offline   Reply With Quote
Old 01-19-2007, 08:30 AM   #24
jessehere
Ridin'
jessehere's Avatar
Oddometer: 780
Awesome job
jessehere is offline   Reply With Quote
Old 01-19-2007, 08:58 AM   #25
514Advrider
Addicted
514Advrider's Avatar
Oddometer: 73
Impressive work!!
I am wondering... What is the exact procedure to mold the body parts? I guess you have to start with a block of solid material that you sculpt to obtain the desired shape, and then you lay the fibre\resin on it? Does this become the final panel, or do you use the resulting part as a pattern for the final piece? Could you explain a bit more on the procedure and material used, maybe you have some extra pictures?
514Advrider is offline   Reply With Quote
Old 01-19-2007, 09:05 AM   #26
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
Yep!
That's a sweet 650, Eric.
Thanks for the great thread!
Arch
Arch is offline   Reply With Quote
Old 01-19-2007, 09:07 AM   #27
ThorH
BMW R1200GS
ThorH's Avatar
Oddometer: 216
Originally Posted by richc
Did you post this over on the Chaingang? I'm sure they'd like to see it too.
Absolutely! http://www.f650.com/phpBB2/viewtopic.php?t=208511
Beautiful work you have done! Any worries about cooling?
ThorH is offline   Reply With Quote
Old 01-19-2007, 09:15 AM   #28
Shlongdistance
SHLONGDISTANCE
Shlongdistance's Avatar
Oddometer: 172
Me want!
Me want! mw want! Fantastic!
CHUMP
Shlongdistance is offline   Reply With Quote
Old 01-19-2007, 09:23 AM   #29
ehatcher OP
Hello? Is this thing on?
ehatcher's Avatar
Oddometer: 2,520
Will,
As it stands now I am going to put in springs and emulators and see how that works.
The rear shock is still in question.....Does anyone know if it can be rebuilt with an emulator? If so I would likely give that a shot before dropping $800 on an Ohlins
Eric
"Mostly the animals understand their roles, but man, by comparison, seems troubled by a message that he cannot quite remember or has gotten wrong. Bereft of instinct, he must search continually for meanings." Loren Eiseley
ehatcher is offline   Reply With Quote
Old 01-19-2007, 09:24 AM   #30
levity
nano-Adventurer
levity's Avatar
Oddometer: 1,088
SUPER job, Eric!
Improved looks and function!
The weight loss is especially impressive!
levity is offline   Reply With Quote
Times are GMT -7.   It's 09:50 PM.
