Old 06-11-2012, 10:09 AM   #3376
Stormdragon
Oddometer: 1
Try Motion Pro. They don't list a choke cable, but at worst, you can send them yours and they'll duplicate it for you.
Stormdragon is offline   Reply With Quote
Old 06-11-2012, 10:36 AM   #3377
riderjohn
Tag Sniper
riderjohn's Avatar
Oddometer: 1,629
2008 Yamaha FJR1300
2005 Suzuki GSX 750F Katana
riderjohn is offline   Reply With Quote
Old 06-11-2012, 02:25 PM   #3378
JohnLocke
JohnLocke's Avatar
Oddometer: 195
Carb issue
I just finished getting a recently aquired 89' XT600 back on the road. Gas tank & carb cleaning, fluids, plug, valve adjust, etc. Anyhow it runs very well now.
I do have one issue with the carb. It has a slow drip, drip, drip gas leak - not a gusher like a bad needle valve/float situation, just a drip. Maybe 2 drips/minute.
Any ideas?
JohnLocke is offline   Reply With Quote
Old 06-11-2012, 05:56 PM   #3379
Noel73
Noel73's Avatar
Oddometer: 20
Just got my 89 xt going too
hey got an 89 here that I just got going after 13 yrs. sitting. I had to clean the float needle seat with pointed piece of dowel rod spun in a drill, if the rubber on thje needle is still in good shape that should make a new clean surface for the needle to seat into, just grind it down the same angle as the needle and spin it a few turns. I had to mess a round a bit with float settings myself, but sometimes it still sticks a bit and a little comes out the overflow when i turn the valve on. I think my gas level is running about 5 or 6 mm. and it runs pretty good.
Noel73 is offline   Reply With Quote
Old 06-12-2012, 06:51 AM   #3380
dzl
adventurer wannabe
dzl's Avatar
Oddometer: 84
Recieved my footpegs here in Australia from Bosley couple weeks ago and recently fitted to my ex Australian army XT. Excellent fit and a great improvement from stock. Thanks
While I was at it I ordered a Wilbers rear shock absorber and Wilbers fork springs from Kedo and fitted everything. Quite reasonably priced as we dont have to pay the VAT. 350 euro for the shocker and 80 euro for fork springs plus 80 euro for delivery to Australia.
Took it for a spin on some local tracks. Feels like a different bike. Will be able to load the bike up now with confidence. Used to be very soft and spongy and quite oftened bottomed out on potholes when loaded. Plenty of preload and rebound adjustability now. Recommended highly to any XT owner.
dzl is online now   Reply With Quote
Old 06-12-2012, 09:30 AM   #3381
bosley1980
Oddometer: 162
Eek nice
The Footpegs look like brand new
I'm glad you like it...
YES I change Spring too - change standart to HYPERPRO.
Really like the other bike - I know the feeling
bosley1980 is offline   Reply With Quote
Old 06-12-2012, 09:52 AM   #3382
Lvl. 29 Adventurer
Garage Inmate
Lvl. 29 Adventurer's Avatar
Oddometer: 44
I'm a cheapskate and bought some TW200 foot pegs but they look to be a similar size but are made of crudely cast steel and nowhere as pretty as the ones you guys have been posting. They perform waaaaaay better than the stock pegs! I just put 50 fireroad, jeep trail and single track miles on them the other day, complete with water crossings and some asshat pulling into my lane and forcing me into a 200' skid through a grass and rock filled ditch... kept the bike upright through the whole ordeal. Stock pegs suck!
Perpetually fixing a Yamaha XT600 as old as I am...
Lvl. 29 Adventurer is offline   Reply With Quote
Old 06-14-2012, 11:04 AM   #3383
bosley1980
Oddometer: 162
Ready for send
Next 5 sets Footpegs will be available
Who wanted it?
1) Pawlie - no answer
2) Damo - SENT (modification for XTZ660 - totally to the left)
3) SmokeyB - no answer
4) m84 - no answer
5) reserved 4.6.2012 - SENT
6) panterg55 - ready for send
7) W8EJO - no answer
8) Coots - no answer
9) ***Woody*** - reserved 24.6.2012 (stainless steel)
10) mopped phil - all 3sets (stainless steel) Ready for send
ready for powder coating
IF YOU STILL WANT Footpegs - write the private message I give you info.
If you not interested, maybe someone else have.
POWDER COATING DONE 15.6.2012
bosley1980 screwed with this post 06-24-2012 at 10:56 AM
Old 06-14-2012, 01:21 PM   #3384
panterg55
Formely panterg
panterg55's Avatar
Oddometer: 55
Footrests
Hi Bosley , You have a PM , I'm interested in a pair for my TT600RE , Regards Glenn
The inmate formerly known as panterg
panterg55 is offline   Reply With Quote
Old 06-16-2012, 03:46 AM   #3385
panterg55
Formely panterg
panterg55's Avatar
Oddometer: 55
Footrests
Hi Bosley , Thanks for the reply - have sent you another PM , Regards Glenn
Old 06-16-2012, 12:12 PM   #3386
panterg55
Formely panterg
panterg55's Avatar
Oddometer: 55
Question about TT/XT Carbs
I need to replace the carbs on my ' 03 Yamaha TT 600 RE I am under the impression that the late model XT carbs are the same ? I don't want more power or anything fancy I just want a direct replacement - any advice or suggestions ewould be appreciated (like a set of carbs !) , I've already placed this in the general forum , however I thought I may get a better response hear Thanks Glenn
Old 06-16-2012, 03:35 PM   #3387
yokesman
Oddometer: 514
boats .net,sudco,www.tenere.co.uk/forum/viewforum.php?f=44
yokesman is offline   Reply With Quote
Old 06-16-2012, 06:39 PM   #3388
Noel73
Noel73's Avatar
Oddometer: 20
shinko 705 tire pressure on my 89 xt 600
Hello everyone, just looking to see what pressure everyone is running these tires at. I got them at the standard 22psi front and rear and they feel kind of squishy and squirrely, especially the front, thinking about taking them to 25 or more and seeing if that will stiffen them up a bit. The old trailwing I had on the front before did not feel like that.
Old 06-17-2012, 01:53 AM   #3389
panterg55
Formely panterg
panterg55's Avatar
Oddometer: 55
Thanks Yokesman will give Mezo a try ! Regards Glenn
Old 06-17-2012, 02:29 AM   #3390
yamahaman
wannabe bike builder
yamahaman's Avatar
Oddometer: 223
carbs
I will have a set of carbs in the next fortnight that are coming off a perfectly running bike, I am using the motor for another project and I have no need for the carbs
Build it and you will ride
My crazy bike build
yamahaman is offline   Reply With Quote
Times are GMT -7.   It's 07:07 AM.
