Old 04-02-2013, 02:06 PM   #4051
webmonstro
A Aventura Continua....
webmonstro's Avatar
Oddometer: 564
Originally Posted by gingertom View Post
Anybody know the size of the bar end bolt i need for 2003 XT600e, Bought some Acerbis handguards and found out the bolt that goes in the bar end is far too big, Any recomendations or even the size i need ?
hi i can mesure it tomrrow if you need it but, do you have the stock bar end wheghts? if so you can use those
webmonstro is offline   Reply With Quote
Old 04-02-2013, 04:26 PM   #4052
feetchermancj
Oddometer: 19
Here is my 84 I got a couple days ago! only 12k miles on it. My first bike!
feetchermancj screwed with this post 04-03-2013 at 10:59 AM
feetchermancj is offline   Reply With Quote
Old 04-02-2013, 04:31 PM   #4053
Buddaman
Oddometer: 42
Tach Needle off
Hey guys my needle in the tach came loose and fell off and now is bouncing around inside, Last night I removed the tach, In the back there are 2 screws I removed but it didn't come apart, Is this thing sealed some how after the screws are removed? I tried pulling it apart and separating it with no luck.
Buddaman is offline   Reply With Quote
Old 04-02-2013, 09:03 PM   #4054
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,248
Yamaha Tach??
Yes, You can`t not get them apart. I try and broke my tach and speedometer too. yamaha.
So, you can get one off e-bay for big $$$$!! or look for a set of meters from a bone yard. Good Luck!!!!
BIG ED XT FAN is offline   Reply With Quote
Old 04-03-2013, 06:02 AM   #4055
thumpthumpthump
Thumpthumpthump
Oddometer: 211
Same problem here, bought a Trail Tech . Love it. Speedo, tach, ODO, trip, top rpm, top mph, shift lights and even temp if you hook it to the drain plug. [oil temp] Saw one on ebay for 100 bucks
thumpthumpthump screwed with this post 04-03-2013 at 06:09 AM
thumpthumpthump is offline   Reply With Quote
Old 04-03-2013, 06:06 AM   #4056
thumpthumpthump
Thumpthumpthump
Oddometer: 211
Shout out! I need a secondary carb[ right side] main jet fo the 84-89 xt 600. stock 130 or even the optional 125. The 135 from the TT is too rich for the altitude.
thumpthumpthump screwed with this post 04-03-2013 at 06:14 AM
Old 04-03-2013, 06:13 AM   #4057
thumpthumpthump
Thumpthumpthump
Oddometer: 211
Heads up! DG just released a mid pipe and silencer system for the 90-95 xt 600 $206. Have one on order. Let you know how it does. 4 levels of baffle available.
Old 04-03-2013, 11:10 AM   #4058
gingertom
Tom Holding
gingertom's Avatar
Oddometer: 14
Anyone know of any tail tidy to fit the 2003XT600 ? i was thinking (http://www.ebay.co.uk/itm/Motorcycle...item1e77a84fe8) But whether it will fit i do not know.
gingertom is offline   Reply With Quote
Old 04-03-2013, 12:01 PM   #4059
JensEskildsen
Oddometer: 1,039
Dont know any bolt on kits, I made a hack job myself, I think it cleaned it up nicely, specially considering our bigass plates...
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is offline   Reply With Quote
Old 04-03-2013, 08:10 PM   #4060
BIG ED XT FAN
Oddometer: 1,248
Nice shot of your riding!!
So, with all them miles, what oil do you use in your bike?? The 600 bike.
Old 04-05-2013, 06:40 AM   #4061
l1ndon
Oddometer: 19
Hi guys wondering if you could help me- Carb problems I think
I bought a non-runner which apparently was running - Petrol was rusty.
Cleaned it all out - cleaned the carb and now it starts and runs fine
But...
When I rev up the engine - it suddenly hits a ceiling and wont rev any higher, (it sounds like its bouncing of an engine limiter but obviously isnt)
Could it be the second part of the carb not opening (the vacuum operated bit)? whats the most likely explanation/fix
I checked the diaphragm on the second carb when I had it in bits last week and it looked fine - it moved the valve up and down when I sucked on the big thick tube -
l1ndon is offline   Reply With Quote
Old 04-05-2013, 07:04 AM   #4062
preppypyro
preppypyro's Avatar
Oddometer: 576
When you cleaned the carb, did you take out that tiny screen, if I recall it is located where the line from the tank switch goes on the carb.
I would try that if you havent removed it. I know the xt has the screen, I just work on various bikes and dont remember exactly where it is.
When I removed mine, the bike ran awesome. To this day, even in minus 20 celcius weather, the bike will start on one kick, no stumbling or anything through the whole throttle range.
preppypyro is offline   Reply With Quote
Old 04-05-2013, 07:50 AM   #4063
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,306
The optional smaller jet is very hard to find. I did find one in California a few years back (the 125 is in my bike now). I have my 130 still though.
P/N 5Y1-14343-63 for the #125 secondary main jet.
You could try a 120 main jet as an alternative.
And for the dude with the tach needle off, mine quit working a while ago and I took it apart. You should be able to put it back on. Probably won't work the same though.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. screwed with this post 04-05-2013 at 08:00 AM
D.T. is online now   Reply With Quote
Old 04-05-2013, 10:52 AM   #4064
feetchermancj
Oddometer: 19
First ride on my new to me 84 xt600. 120miles central Oregon starting off in the desert and climbing up into the timberline.
Old 04-05-2013, 11:05 AM   #4065
thumpthumpthump
Thumpthumpthump
Oddometer: 211
DT would you be willing to part with your 130? I would like to buy it from you if you do. thumpthump
Times are GMT -7.   It's 04:11 AM.
