Old 05-07-2013, 03:11 PM   #4156
cramarc
Oddometer: 6
Originally Posted by thumpthumpthump View Post
CRAMARC, did you put the ball bearing in after the rod and before the adjusting bolt ? What you described is how it would act if it was missing. I just put a Barnett clutch in mine and I just turned in the adjustment screw until it touched and set the lock nut. thumpthump
Yes I did put it! Did you adjust it watching it matched the crankcase signal?
I did the adjustment with the clutch cable "unloaded" as it says in the manual, may the error be here?
Still finding no clue on the clutch adjustment ...
cramarc screwed with this post 05-07-2013 at 03:11 PM Reason: uloaded --> uNloaded
cramarc is offline   Reply With Quote
Old 05-07-2013, 03:43 PM   #4157
thumpthumpthump
Thumpthumpthump
Oddometer: 211
My clutch cable was still attached. I just turned the screw in until I felt resistance and locked it down. Then I adjusted cable to suit my preference. thumpthump
thumpthumpthump is offline   Reply With Quote
Old 05-07-2013, 04:23 PM   #4158
cramarc
Oddometer: 6
Ok Thanks I think I'll do that and see if it works out well and report it back here!
Old 05-08-2013, 11:01 AM   #4159
thumpthumpthump
Thumpthumpthump
Oddometer: 211
I have a question about the Acerbis large capacity gas tank. I find a listing for one that fits the 95-02 xt 600. Does anyone know if it will fit the 90-94 xt 600? How mant gallons does it hold ? one sight says 5.3 and another says 6.07. thumpthump.
Old 05-08-2013, 01:17 PM   #4160
JensEskildsen
Oddometer: 1,039
It wont fit.
mine holds 24,70ltr
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is online now   Reply With Quote
Old 05-08-2013, 02:15 PM   #4161
thumpthumpthump
Thumpthumpthump
Oddometer: 211
NOOOOOOOOOO not the answer I was looking for. They are very similar what is the difference ? Does one exist for the 90-94? thumpthump
Old 05-08-2013, 04:48 PM   #4162
cramarc
Oddometer: 6
This has been talked here already:
95- has different tank, tank scoops, seat, sidecovers and tail cover. As seen on next photos: (first one is till -94 type, other upon 95-)
So basically if you want to bolt it on you'll have to change at least that above and some mountings.
Maybe you can fit somehow the tank but you'll have to modify the seat I think.
cramarc screwed with this post 05-08-2013 at 04:57 PM Reason: added photos to explanation
Old 05-09-2013, 04:15 AM   #4163
thumpthumpthump
Thumpthumpthump
Oddometer: 211
I am asking about the the Acerbis 5.3 gallon tank. I am not running the side panels or the air box. The Acerbis has its own scoops so those are not an issue. All that really matters is will the tank fit on the bikes stock mounts and will it fit with the stock 90-94 seat. Thanks for the pictures , the seat is quite different. thumpthump
Old 05-09-2013, 05:15 AM   #4164
cramarc
Oddometer: 6
Yes I know but if you change the seat the rear fender, and side cover won't fit.
Old 05-09-2013, 05:48 AM   #4165
thumpthumpthump
Thumpthumpthump
Oddometer: 211
Doooomed to gas up every 120 miles unless I can find a discontinued 90-94 acerbis tank. What about one of those tenere xt600 tanks everybody has except the US? Would that fit a US 90-94 xt 600 , frame and seat? CRAMARC how did that clutch issue come out? thumpthump
Old 05-09-2013, 07:13 AM   #4166
Coots
That's what she said
Coots's Avatar
Oddometer: 155
Thump,
You might pose the question over at Mezo's site. I don't know if you followed his thread before he got sent to perma camp. He has tons of info on Tenere's. Link is http://www.tenere.co.uk/forum/viewforum.php?f=14
Coots Jr is just a younger me!
03 DL1000 "Bumble Bee"
91 XT600
03 SV650S SOLD
Coots is offline   Reply With Quote
Old 05-09-2013, 07:15 AM   #4167
Coots
Coots's Avatar
Oddometer: 155
XTZ part to XT
Thump,
Quick search and here is a link.
http://www.tenere.co.uk/forum/viewto...7a19684061015a
91 XT600
03 SV650S SOLD
Old 05-11-2013, 08:08 AM   #4168
bosley1980
Oddometer: 162
Wink TOOL TUBE - done
Hello all
I finally mounted tube tool on my bike.
Thanks to all who advised me.
What do you think?
Tube is attached to the base plate (2mm stainless steel) and the lid is secured against rotating steel wire (just nothing complicated).
Lock for helmet is still functional!
bosley1980 is offline   Reply With Quote
Old 05-11-2013, 09:36 AM   #4169
thumpthumpthump
Thumpthumpthump
Oddometer: 211
Looks great. Good job.thumpthump
Old 05-12-2013, 04:27 AM   #4170
wide
Oddometer: 390
Looks well mounted there Bosley
Honda Transalp 650.. back on the old favorite
XT 600 E... thumping fun but not for motorways
Suzuki DR350... mellow fun but now gone
XR 400 gone
Transalp 600 gone
wide is offline   Reply With Quote
Times are GMT -7.   It's 02:07 PM.
