Old 04-17-2009, 08:18 AM   #766
mtothef
Oddometer: 397
i've got swingarm for ya
Originally Posted by =che=
how much would you guys think a swing arm with rear wheel and tire from a mid 80's xt with no real damage cost?
swingarm, shock, linkage, decent condition, off an 87 xt 600. PM me if interested:
mtothef is offline   Reply With Quote
Old 04-17-2009, 11:21 AM   #767
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,213
Originally Posted by acupuncture4u
This is a clarke tank with the stock seat. Has a bit of room up front...
How about a side view of your XT 600?
BIG ED XT FAN!!
BIG ED XT FAN is offline   Reply With Quote
Old 04-17-2009, 12:48 PM   #768
acupuncture4u
Freedom by knobbies
acupuncture4u's Avatar
Oddometer: 1,372
BIG ED XT FAN!!
Here you go
(((((((((RIDE)))))))))
www.betterthanyoufoundit.org At Least 1 piece!
How is your Heart Health
acupuncture4u is offline   Reply With Quote
Old 04-17-2009, 11:20 PM   #769
BIG ED XT FAN
Oddometer: 1,213
Here you go
Thanks ! What kind of rear shock are you running?
Old 04-18-2009, 10:39 PM   #770
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Headlight Conversion Tonight
I took the Mighty XTique tonight and stripped its head light and replaced it.
From crappy round light. That you couldn't see crap with to.....
Nice 55/60 watt Halogen setup.
Its a Baja Designs bulb, mounted into a KTM number plate. Its not a direct fit.
The shell had to be trimmed a little to make the light fit. Without it there would've been no adjustment. This light mounted to the fender.
Drilled two holes. Two bolts mounted.
I also had to modify the shell slightly, as the sides are asymetrical. At the back side one side had a notch cast into it. So I made it the same on both sides. The headlight rests against the turn signals just above the headlight for top support.
These lights throw a fan shaped light on low beam, and high beam is almost spot light like. The fender creates a slight shadow but not bad enough to bother you.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 04-19-2009, 12:34 PM   #771
acupuncture4u
Freedom by knobbies
Oddometer: 1,372
Rear shock is stock and it's kinda a problem. I have a dirt tire on the rear and it kept tearing my fender and license off. If you look at the exhaust it's taken a beating as well. This before shot shows how I wanted to back rack to be. After you can see how it was bent way down and the mounts broken off. The fender just has the white piece with the tail light mounted upside down.
The front forks are stock springs but have 1" of pvc in them. It seemed to help going up the stairsteps. I need a new rear tire and maybe to drop some weight. How much gear in weight would you say you strap to the back?
Dustin
Old 04-19-2009, 07:16 PM   #772
Calkins
On Any Sunday...
Calkins's Avatar
Oddometer: 501
Can you add spacers to your front tank mounts to move the tank rearward alittle to get rid of your seat gap? Just an idea.
Justin Calkins - Iowa Falls, Iowa USA
1973 Yamaha DT3 - 250 - FOR SALE
Boss Framed Yamaha RT3 Flat Tracker
2007 Triumph Bonneville America - 865
WANTED - Boss Flat Track Frames - WANTED
Calkins is offline   Reply With Quote
Old 04-26-2009, 07:28 PM   #773
thinairflyer
Oddometer: 161
rear tire size '95 XT600E ?
4.60 or 5.10? Which is nearest the stock metric size? Thanks
thinairflyer is offline   Reply With Quote
Old 04-27-2009, 01:59 AM   #774
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
I've ordered a YZ465 shock and triple clamp. I got the forks already. My old 550 is going to get a real suspension.
I know I've got to modify the frame to give the YZ shock to fit. I'm going to try and keep the stock swingarm on it.
Future plans for it, once I got this mod done.
  • replace the forks with Mazarcchi Shivers, I got them already.
  • Locate a front wheel and triple clamps, brakes (Honda CR or Cannondale)
  • Replace rear wheel with CR500 for disc brakes once front end is done.
This is a low budget build up so its a long term project. I can't wait to see the improvement with the better suspension, maybe it won't beat the heck out of me on high speed dirt roads and gain some ground clearance for the boulder alleys I get into on occasion.
Stay tuned.
Old 04-27-2009, 06:10 AM   #775
huggybear
huggybear's Avatar
Oddometer: 384
I have a Kenda 270 size 5.10x17 and it works good I believe the 4.60 is much to narrow for the wide rim on the XT600
huggybear is offline   Reply With Quote
Old 04-27-2009, 10:13 AM   #776
JensEskildsen
Oddometer: 1,012
I've got a 4.60x17 on my xt600, pictures on page 46.
JensEskildsen is offline   Reply With Quote
Old 04-27-2009, 04:47 PM   #777
BIG ED XT FAN
Oddometer: 1,213
Dustin
Hi, Back again. Down in the sunshine state for a few days with the kids! I got a good stock shock on my xt 600. In the front i have prog. fork springs. Helps big time. I run a kenda 450x18 rear tire. "Trackmaster" I say about 20 pounds would be tops out back. I have a set of yz 250 forks for the front and will order a "Works" shock for the back. Hope this helps!
Old 04-28-2009, 04:43 PM   #778
Calkins
On Any Sunday...
Calkins's Avatar
Oddometer: 501
I have an exhaust question.
Will a Grizzly or Raptor header work on my '83 TT600? I saw one in Dennis Kirk that looked nice. The primary tubes where a little longer. Could I use one of those headers and then cut up and fab the rest of the piping to fit? I want to use a SuperTrapp Race Slip-on.
Old 04-28-2009, 10:05 PM   #779
Olas
the darkness
Olas's Avatar
Oddometer: 3,972
So, I know we touched on the topic of JT sprockets being a bit loose on the counter shaft but are there any documented problems that arose from this?
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 04-28-2009, 10:46 PM   #780
Greengo
Oddometer: 35
I was just wondering what kind of oil you guys would use in a 1984 xt600. I could not find the 20w40 oil as in the manual i got some 10w40 will this be ok?
Greengo is offline   Reply With Quote
Times are GMT -7.   It's 11:33 AM.
