Old 05-18-2010, 07:43 AM   #1546
Yzlvr
Oddometer: 845
Originally Posted by fuzzydude2
I have an 2005 525EXC will, the cooling fan work with the IMS tank?
No, only Clarke tank will clear.
Yzlvr is offline   Reply With Quote
Old 05-18-2010, 07:54 AM   #1547
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,494
+1
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 05-18-2010, 07:56 AM   #1548
CodyY
CodyY's Avatar
Oddometer: 9,494
header wrap is much easier.
Old 05-18-2010, 09:01 AM   #1549
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,967
Not the stock fan, but I'm using a large computer case fan and it clears.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 05-18-2010, 07:26 PM   #1550
selaznog
Avoiding pavement
selaznog's Avatar
Oddometer: 2,950
Ahem.
The Acerbis 6.6 clears.
selaznog is offline   Reply With Quote
Old 05-18-2010, 07:45 PM   #1551
Wings
marmaduked
Wings's Avatar
Oddometer: 14,591
Originally Posted by selaznog
Ahem.
The Acerbis Valdez clears.
Fixed!
Originally Posted by adv397 View Post
they are upside down under the ice you tard
Wings is offline   Reply With Quote
Old 05-18-2010, 10:16 PM   #1552
wakewop
Hucker
Oddometer: 785
I am also using a computer case fan. Sidewinder to be exact. 110 cfm. Fits perfect, cools fantastic, cost me 15 bux.. Been washed, muddy, drowned, rained on for 1.5 years.. still working.
wakewop is offline   Reply With Quote
Old 05-19-2010, 05:07 AM   #1553
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,458
riding style...
How do you ride your 450/525/530 on open gravel?
I find it very hard to stick to 60mph. Its painfull and slow! Is it just one of those things I need to get used to if im planning on doing some distance on my 450?
Whats an acceptable rpm range for crusing on a performance 4t? 7000rpm? 8000?
06 950S, YZ250WR, 300 TXT Pro
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV,Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 05-19-2010, 12:40 PM   #1554
spaceman_spiff
spaceman_spiff's Avatar
Oddometer: 1,027
did you have to make a shroud for it?
spaceman_spiff is offline   Reply With Quote
Old 05-19-2010, 01:06 PM   #1555
crazybrit
crazybrit's Avatar
Oddometer: 8,554
usually you just zip tie them to the cross bars running across the radiator, basically there are 4 holes at each corner of the fan assembly. also depends on what sized fan you use .... there are several threads on this over at ktmtalk. Others have made use of the radiator guard supports (depending on what type).
I was using a PC fan (and IMS) for a while but the body of the fan snapped, not sure why, branch maybe. I have the Spal (KTM) now and a Clarke tank. AFAIK the KTM MX/C tank works with the KTM fan as does the Aqualine Safari (and Acerbis 25l as mentioned). It's really just the IMS that doesn't fit.
crazybrit is offline   Reply With Quote
Old 05-19-2010, 02:20 PM   #1556
LILBIT
Ride you must.
LILBIT's Avatar
Oddometer: 1,675
Gear it up.
I've run 15/49 quite a bit on my 525/540 and it wants at least 60mph to be happy in 6th gear. For a bunch of road i'd consider 15/47 myself.
I eat my candy with the pork and beans-
LILBIT is offline   Reply With Quote
Old 05-19-2010, 06:59 PM   #1557
HutchCab
HutchCab's Avatar
Oddometer: 139
Originally Posted by crazybrit
AFAIK the KTM MX/C tank works with the KTM fan [snip] It's really just the IMS that doesn't fit.
MX/C tank and fan on mine.
.03 KTM 525 EXC
HutchCab is offline   Reply With Quote
Old 05-19-2010, 07:20 PM   #1558
GR0NK
Got some screws loose!
GR0NK's Avatar
Oddometer: 2,309
Originally Posted by LILBIT
Gear it up.
+1 on 15/xx for lots of road use.
I've even ran 15/52 (or 14/48 same gearing) and found that 6th wasn't happy below 60mph. IMO anything with a 15 on the front is highway gearing. (with a 525/450, not a 400) I ran 14/52 as a 525 and now 14/50 as a 540. A stock 525 can't pull much more than about 8600 RPM in 6th with 14/52 and even as a 540 I doubt it can pull much more than 9000 RPM in 6th with the 14/50. This is with a big and tall T-Flex so maybe a smaller rear tire will let you pull more revs.
Sean
Team Valley Bomb Squad
Nullus Vereor ex Terra Incognita
GR0NK is offline   Reply With Quote
Old 05-19-2010, 10:21 PM   #1559
lamoson
something catchier
lamoson's Avatar
Oddometer: 727
rebuilding the 540.
2005.5 KTM 950.....it goes.
lamoson is offline   Reply With Quote
Old 05-19-2010, 11:14 PM   #1560
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,458
Sean
Thanks Sean!
Whats the average acceptable cruising speed? 60/7-/80mph?
with my 14-50 - cruising is smooth at 50mph, 15-50 - 60mph - 15-45 65-75mph. Obviously the more you gear it up, you loose a lot of low end and you find yourself all over the clutch if things get even the slightest technical. with 15-45 ive pulled to just over 105mph, but the the 450 is sceaming 9700rpm! But when im down at 70mph shes purring along at about 6500rpm.
When you are riding in a group, there is always somebody with a faster bike and they always shoot out in front leaving us to play catchup. There no problem for me to get on the gas and persuit and play a bit, but running at 100mph for 50miles is not really what I had in mind.
I need to relax about the strain on the motor when im out on the gravel and figure out at what working range the motor is its happyest.
I can also imaging, the lower you go on the gearing, the more strain you put on the top gears. Man having 5 gears sucks (wr450f).
Times are GMT -7.   It's 12:04 PM.
