Old 03-15-2013, 04:16 PM   #4531
crazybrit
crazybrit's Avatar
Oddometer: 8,556
anti oil thread
No, not another "what oil should I run" post
I thought I'd mention that there is a rebate running right now ($12 off 5 quarts or more) on Mobil 1 15w50 and my bike has been happy with it for the last 200 hours ..... this is the oil that Bill @HT Racing recommends if you run his RFS oil cooler
http://www.amazon.com/Mobil-94002-Sy.../dp/B000COPC9S
Anyways, thought I'd pass it along. YMMV. Coupon details say good for 2 per household, not sure if that's one person or two.
crazybrit is offline   Reply With Quote
Old 03-26-2013, 04:58 PM   #4532
robl245
robl245's Avatar
Oddometer: 30
I thought I'd throw mine up on here, but it's another not 525 post. I can't remember if I've seen a 400 on here, so here's mine!!
When I got it a couple of years ago with 9 hours and 125 miles on it.
Owner bought it and stashed it the garage for several years riding it only a couple of times. Then he sold it to me. For $3500!! Plus it came with a brand new set of brand new SIDI boots too.
2004 400 exc with EE goodies and Baja Designs kit
Here's what it looks like now. About 80 hours and something like 1800 miles.
First multi day dual sport on / off road ride through the Washington desert.
robl245 screwed with this post 03-27-2013 at 09:39 AM
robl245 is offline   Reply With Quote
Old 03-26-2013, 10:51 PM   #4533
sonic reducer
Oddometer: 256
this past weekend I did the JD jetting adjustable fuel screw to my bike, very easy to work with compared to the stocker. I got sick of playing with ratchet wrenches and screwdriver bits.
during that time I also went and tightened the primary nut as I was uncomfortable not knowing its status. upon removing the cover it was loose by a couple turns!!!! I went the full route removing the clutch and primary gear. Removing the clutch was by far the most difficult part(locking the basket). I ended up putting all the discs back into the basket with no tension plate, and applying pressure with small C clamps. I think a better way to lock would be to build a little tensioner from a scrap of wood or some such, and run some M6 bolts through it into the clutch hub, and the wood would be bearing onto the clutch plates but still allow a 27mm socket past. I wedged the gears with a brass elbow fitting that had a square edge on it, perfect. For my crank snout I was lucky, and there was no visible damage. the woodruff key was lightly indented. I put it back together with green loctite, lots on the woodruff key, red loctite on the crank threads, and tightened with a breaker bar. my torque wrench does not go high enough. I would strongly urge RFS owners to do the job. it is not really that difficult and worth the peace of mind and to see inside that clutch cover.
these links were of great help for this job:
http://www.ktmforum.co.uk/technical-...th-rattle.html
sonic reducer is offline   Reply With Quote
Old 03-27-2013, 09:16 AM   #4534
yondering
yondering's Avatar
Oddometer: 1,100
Owner bought it and stashed it the garage for several years riding it only a couple of times. Then he sold it to me. For $3500!! Plus it came with a brand new set of SIDI boots too.
Nice looking bike! Do you have any pics of your trip through the desert? I'm over on the wet side, but would sure be interested in some details of your trip, I love riding the east side.
yondering is offline   Reply With Quote
Old 03-27-2013, 09:44 AM   #4535
robl245
robl245's Avatar
Oddometer: 30
Sure, we've got a thread on it in Day Trippin. My friend posted to the thread on the fly durring the trip, and I'm adding all my pictures now. I'm not quite done. Here it is....
http://advrider.com/forums/showthread.php?t=870340
Old 03-27-2013, 09:59 AM   #4536
Swarthy_Red_Beard
Oddometer: 155
Took the 525 out to Saline Valley in Death Valley National Park a couple weeks ago. Ben put up a Ride Report Here.
Then Drove to Hollister Hills Hare Scramble and took 5th in class. Got to love the versatility of these bikes!!
Cheers,
Matt
Swarthy_Red_Beard is offline   Reply With Quote
Old 03-27-2013, 02:35 PM   #4537
bigtodd
Hi, wanna ride?
bigtodd's Avatar
Oddometer: 1,552
Cheers,
Matt
Will be riding mine in the same are this weekend
Life is an adventure that requires the correct equipment
SPOT - bigtodd - where I at now?
bigtodd.whereamiriding.com
bigtodd is offline   Reply With Quote
Old 03-27-2013, 05:26 PM   #4538
Swarthy_Red_Beard
Oddometer: 155
You're Stoked! If you want a challenge, head up that snowflake mine road. If you are at the springs, look across the valley (down Bat Rock road) and a little left and you can see it switchback up the Inyos. We stacked some rocks up for you so you should have a semi clean line.
Enjoy and let us know how it goes!
-Matt
Old 03-28-2013, 12:49 PM   #4539
Moto Vaquero
Trail less traveled
Moto Vaquero's Avatar
Oddometer: 326
Ready to roll. Off to Baja for a month...finally
I'm not day dreaming, I'm prerunning
21 days exploring Baja
http://advrider.com/forums/showthread.php?t=922187
Moto Vaquero is offline   Reply With Quote
Old 03-29-2013, 11:29 PM   #4540
MKJ
Married w/ Children
MKJ's Avatar
Oddometer: 578
Nice set up.^^^^^^^^^
Looks a lot like mine. I'm heading down on Tuesday. Not for a month though.
MKJ is offline   Reply With Quote
Old 03-30-2013, 12:59 AM   #4541
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,198
What spring rates are you guys running? I've been through the ktmt spring rate thread but many of the bikes on there aren't setup as DS bikes.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 03-30-2013, 10:03 PM   #4542
MKJ
Married w/ Children
MKJ's Avatar
Oddometer: 578
I run 95/260 on my EXC, 95/250 on my MXC. Set preload according to final weight with gear. I weigh 205 lbs.
Old 03-31-2013, 05:31 PM   #4543
dentvet
Oddometer: 1,369
Finally finished building my cush drive wheel. Wheel building is a steep learning incline for me, i spent many hours getting it setup for some reason (inexperience) I need to build another one right away so i don't forget all the things I learned on this one.
I'd never seen a rockhopper rim until I found this one so i'll post a pic. Dunlop 606, Tubliss
The assembly weighs 28 pounds with Tubliss system. I have another one with the oem 2.5 rim, Dunlop trials tire and i think UHD tube that weighs 2 or 3 pounds more. (bathroom scale)
dentvet is offline   Reply With Quote
Old 03-31-2013, 09:25 PM   #4544
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,974
I'm surprised to see a flanged rim on a dirt bike. Strange.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is online now   Reply With Quote
Old 03-31-2013, 10:11 PM   #4545
sashapave
riders on the strom
sashapave's Avatar
Oddometer: 1,429
I'm on the fence and wanted to see what y'all thought.
I'm considering selling my 05 450exc (ca plated) for a 2012 500exc.
I have about 160hrs on my RFS and after riding the new KTMs, I've come to appreciate all the advances in the chassis/suspension. Plus I wouldn't mind "going legit" with a legal dual sport.
I really appreciate the reliability of the RFS and my main concern is if the new engine and FI is as reliable as the 'ol truck RFS.
I'm 80% woods and 20% 1-3 day dual sport rides.
Does anyone have a sense for the new motors and their reliability?
Sasha
11 250XC: Tweak Bunny
09 TE 610: Gunnar
74 Vespa Rally: Cream Dream
A ship in port is safe, but that's not what ships are built for. -Admiral Grace Hopper
sashapave is offline   Reply With Quote
Times are GMT -7.   It's 09:44 PM.
