Old 05-19-2013, 02:15 PM   #4651
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,669
And the second ride I took it on..:
I make a swear in it so it may be NSFW...
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 05-19-2013, 04:04 PM   #4652
bigtodd
Hi, wanna ride?
bigtodd's Avatar
Oddometer: 1,519
Originally Posted by Wallrat View Post
I just hacked some 1/4" aluminum angle. Plan on taking em off and trimming them up a bit with a die grinder to make em blend in a little better but fairly low priority so haven't gotten to it yet.
Finally got around to using your example. Used some smaller angle iron and hit them with the rattle can before mounting. These little Cree lights work great!
Life is an adventure that requires the correct equipment
SPOT - bigtodd - where I at now?
bigtodd.whereamiriding.com
bigtodd is offline   Reply With Quote
Old 05-20-2013, 10:39 AM   #4653
VidoSeaver
VidoSeaver's Avatar
Oddometer: 6
Howdy folks,
This is probably frowned on, but I figured it was relevant none-the-less. I have a Brand new KTM 640 Kush rear wheel that fits the 525 that I'm selling here:
http://advrider.com/forums/showthread.php?t=888618
Current Whip: 2002 KTM 520 EXC
VidoSeaver is offline   Reply With Quote
Old 05-21-2013, 02:52 PM   #4654
selaznog
Avoiding pavement
Oddometer: 2,891
Uh oh, electrical problem. Maybe the collective can help limit the possible diagnoses. And in full disclosure, I am quite noobish when it comes to electrical matters.
OK, I was riding my 2007 525 EXC (289 hrs, ~8500 miles) on Sunday with a few guys, and after the first beak my starter did nothing when I pressed the button. Yes, the key was on and the kill switch was rocked to the correct position. It started with the kicker and I completed the day's riding without assistance. So, here is what I know:
1. No starter
2. Runs if kicked
3. No lights with key in ON position when not running
4. Lights work when running.
5. No obvious disconnection of wires at the battery
6. I think I felt an few electrical shocks in my left hand during the ride.
I suppose somewhere there is a disconnected wire, but can anyone suggest likely causes, or eliminate impossible causes?
Is there a danger of other damage if I run it this way without correcting the condition?
selaznog screwed with this post 05-21-2013 at 02:59 PM
selaznog is offline   Reply With Quote
Old 05-21-2013, 03:23 PM   #4655
bryantjt
Oddometer: 1,011
I had similar symptoms except no shocking on my 06 450. Check the connections on the coil directly under the tank. Mine were loose and corroded so the starter only worked occasionally.
Sent from my DROID RAZR using Xparent Green Tapatalk 2
2006 V-Strom 650
2006 KTM 450
2006 KLX250S (9000 miles of fun) - gone
bryantjt is offline   Reply With Quote
Old 05-21-2013, 04:40 PM   #4656
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,036
1. No starter
2. Runs if kicked
Steve did you check to see if the battery is good. It might have gone tits up.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 05-21-2013, 04:51 PM   #4657
drdfblackm
VeeFeer
drdfblackm's Avatar
Oddometer: 839
I had a similar problem with my WR450. I understand not the same bike, but I checked my battery, bought a new starter solenoid, and still did not work....turned out that the starter button itself was broke internally and was not making contact with you would push on the button. Weird, but sometimes it is the simple things.
These are not the droids you are looking for.....
drdfblackm is online now   Reply With Quote
Old 05-21-2013, 07:54 PM   #4658
selaznog
Avoiding pavement
Oddometer: 2,891
If it were just the starter button, I should still have lights.
Multimeter shows 12.89. No history of weak starts. Not even a weak tail light with the key on. No headlight. No movement from the starter whatsoever. I don't think it's the battery.
I will check for this.
Thanks guys. Suggestions are still welcome.
Old 05-21-2013, 08:19 PM   #4659
drdfblackm
VeeFeer
drdfblackm's Avatar
Oddometer: 839
Did you try to jump across the starter solenoid??? See if it rolls over that way.
The WR450 has a solitary button for the starter....just a thought.
Old 05-21-2013, 09:09 PM   #4660
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,493
Main fuse/solenoid. Mine did that once
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 05-23-2013, 12:05 AM   #4661
team ftb
Befuddled Adventurer
Oddometer: 1,688
+2 I had my solenoid shit the bed after 485 hours.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 05-23-2013, 09:16 AM   #4662
team ftb
Oddometer: 1,688
Spam
After roasting the drive shaft on my 525 because of no cush hub, thought this may be of benefit to someone here.
Complete 640 DID rim w/cush hub for sale.
http://www.advrider.com/forums/showt...1#post21474321
Cheers,
Team FTB
Old 05-23-2013, 11:20 AM   #4663
selaznog
Avoiding pavement
Oddometer: 2,891
How exactly would I be able to tell if it's the solenoid?
Old 05-23-2013, 12:00 PM   #4664
bryantjt
Oddometer: 1,011
Jumper around it. Use a heavy wire, 12 gauge or better and touch it to the starter stud and the battery positive terminal. This will tell you if the starter itself is good.
If the starter is good you now know there is either a problem with the start button or the solenoid.
The start button can be checked with the continuity function on a multimeter. Find the 2 wires for it behind the headlight and plug your lead into the connector and try the button. If the meter beeps or gives a reading (depending on type of meter) then the button is good.
Then you can take your meter and flip to dc voltage and touch one lead to the positive lead on the solenoid (probably in your airbox) and the other to battery negative or chassis ground.
If that shows battery voltage that wire is good.
Then connect to ground (or battery) and connect to the lead leaving the solenoid that goes to the starter and watch the meter when you try the start button. You should see battery voltage and the starter should work if all is good.
If not it could be one of 2 fuses on the solenoid or a bad connection between start button and solenoid. You can check for voltage at the solenoid connectors when pressing the start button.
I went through all of the above and found no voltage out from the solenoid when hitting the start button so I bought a new one and that made no difference. Following my wire diagram in the owners manual I found that most everything is grounded in the bolt at the coil. This bolt was loose in my case. I cleaned the connection and tightened the bolt and all is well.
2006 V-Strom 650
2006 KTM 450
Old 05-23-2013, 12:02 PM   #4665
bryantjt
Oddometer: 1,011
I had to remove the tank to get to the coil.
2006 V-Strom 650
2006 KTM 450
Times are GMT -7.   It's 03:08 PM.
