Old 06-18-2013, 05:43 PM   #4711
RB450
RB450's Avatar
Oddometer: 339
Originally Posted by davesupreme View Post
you sit up on the tank, and hit some silty/sugar sand or some muddy water at speed, and you're gonna see a problem immediately if not sooner....
I never have any problem with either sugar sand or muddy water at speed. I just give it more throttle. As I said, I stand 95% of the time, only sitting when riding black top and some dirt roads.
RB450 is offline   Reply With Quote
Old 06-20-2013, 03:12 AM   #4712
MadM
Dreamer
MadM's Avatar
Oddometer: 302
Hey!
Hopefully I am not to much off topic here. I need some help from 2001 EXC owners. I am doing a fork swap on my bike and since I won't be using a KTM wheel I need to know if the KTM front wheel axle from 2001 EXC 520 (part nr: 50309081200) is hollow or solid. The reason beeing, I would like to turn the thiner part of the axle down for 2mm to fit my wheel (from KTM 17mm to Kawasaki 15mm). I have been also searching on ebay for such axle to look at pictures but haven't found anything useful.
Thanks for help!
'08 Honda XL125V Varadero
'05 Kawasaki KLE 500
'03 KTM LC4 640 Enduro
My Blog
MadM is offline   Reply With Quote
Old 06-20-2013, 01:23 PM   #4713
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,736
Originally Posted by MadM View Post
Hey!
Thanks for help!
2001 EXC uses a 20mm axle.
It would be easier to make adapters for the fork bottoms to suit the correct 15mm axle. Thats what I do when I fit 17mm Duke wheels into 26mm KTM forks
Peanuts is offline   Reply With Quote
Old 06-24-2013, 07:33 AM   #4714
MadM
Dreamer
MadM's Avatar
Oddometer: 302
Thanks for the info and correcting what I knew. Do you know what is the diameter of the thick part of the axle?? Still is the stock KTM axle solid or hollow?
My Blog
Old 06-26-2013, 09:11 AM   #4715
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,661
Hey!
Thanks for help!
I believe it is solid, at least on an '02 400EXC (20mm)/
What forks? I found out that '03 and above have a 26mm axle.
This might be confusing the issue but here ya go: http://ktmtalk.com/index.php?showtopic=479877
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 06-26-2013, 10:43 AM   #4716
MadM
Dreamer
MadM's Avatar
Oddometer: 302
I have a set of WP43 forks off a 2001 620 SC SM, and the part numbers for the axles are the same for 2001 400/525 EXC, as the forks are the same, just diffrent springs. SM uses 5.0kg and EXC uses 4.2kg springs
My Blog
MadM screwed with this post 06-26-2013 at 10:46 AM Reason: typo
Old 06-28-2013, 09:13 PM   #4717
selaznog
Avoiding pavement
selaznog's Avatar
Oddometer: 3,029
Originally Posted by RAZR View Post
installing a Rekluse today in my 2004 525 EXC...
should I go with "low hard" setting or a "low soft" setting.
I ride mostly rocky singletrack here in California. slow speed stuff with technical sections. but I like some fast desert riding too.
my friend that has a 525 said "low hard" so you don't lose the engine breaking but my other buddy that rides a 250 Yamaha said "low soft" cuz of the tight technical stuff.
what do you guys run?
Mine is kind of soft, but twist the throttle and it's power. Eventually you will have to fine tune with bearings anyway, so go with your gut.
selaznog is offline   Reply With Quote
Old 06-29-2013, 04:42 PM   #4718
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,597
Finally my XCW 525 is almost on the road! It's been way too long since I sold the MECA kit on it.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 screwed with this post 07-01-2013 at 07:20 AM
skibum69 is offline   Reply With Quote
Old 06-29-2013, 06:31 PM   #4719
KTMInduro
Off Road Montster
KTMInduro's Avatar
Oddometer: 357
Originally Posted by SirJono_777 View Post
This is my 525 exc setup for a rough firetrail (3 day) ride earlier this year. The Kriega Overlander 30's a simply awesome. Next years ride I will add the Kriega US-20 or 30 up top and tidy the whole thing up.
Nice set up ! I'm thinking of the same set up with the Kriegas for my Berg FE390.
Monty
Husaberg FE 390
BMW F800 GS
Borneo Equator Expedition - Jungle , Swamps and Heatstroke
KTMInduro is offline   Reply With Quote
Old 06-30-2013, 12:50 PM   #4720
RAZR
yup ima hairstylist
RAZR's Avatar
Oddometer: 9,394
thanks mang.
I have it set up low-soft and it's perfect so far. love it!!! I have the Z-Start Pro by the way.
"when there is no more room in hell, the dead will walk the earth"
YOUTUBE
SPOT
RAZR is offline   Reply With Quote
Old 07-01-2013, 07:51 AM   #4721
Dave298
Dave298's Avatar
Oddometer: 39
Just did a 400mile day ride on my 520exc with my buddy who has a 525exc. Coming off a klr it sure is nice to actually have a bike that can go off road. We did pavement, fire roads, two track, single track, and these bike did it all with out a struggle!
http://www.everytrail.com/view_trip.php?trip_id=2199195
"Relax. My old man is a television repairman. He's got this ultimate set of tools. I can fix it!" Jeff Spicoli.
Dave298 is offline   Reply With Quote
Old 07-01-2013, 11:57 AM   #4722
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,732
1100 mile 5 day trip out in the SE Oregon high desert. a 450, 525 and dr650. my 450 worked flawlessly
Alvord Loop 2013(2) from clapped_r6 on Vimeo.
none of us is as dumb as all of us
clapped_r6 is online now   Reply With Quote
Old 07-01-2013, 12:05 PM   #4723
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Nice !!! We were there last year.
crazybrit is offline   Reply With Quote
Old 07-01-2013, 12:09 PM   #4724
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,732
pics or it didn't happen
Old 07-01-2013, 12:20 PM   #4725
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,732
hey, anybody running a wolfman explorer lite tankbag? looking for pics of one on an RFS.
Times are GMT -7.   It's 05:22 PM.
