Old 10-01-2009, 07:53 PM   #796
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,779
Originally Posted by teti
buenas tardes,
paso a mostrar mi 530 exc 2009
5000 km 90 horas, y volo la 6 marcha, de paso cambie el piston
usaba transmision 14-45 , q puede ser la causante de la rotura?
Ouch.
Beautiful bike, though.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 10-02-2009, 10:52 AM   #797
Dirt Hooker
Oddometer: 326
buenas tardes,
that is badass!!!
do i have to ask??? is that a custom fairing, pirated off another bike, or aftermarket? please do tell
Dirt Hooker is offline   Reply With Quote
Old 10-02-2009, 12:15 PM   #798
Redline
Redline's Avatar
Oddometer: 313
I pm'd Teti about the fairing a while back. If I understood him correctly, it was one of these:
http://www.albertodottori.net/index.htm
Redline is offline   Reply With Quote
Old 10-02-2009, 02:44 PM   #799
teti
especie en extincion
teti's Avatar
Oddometer: 143
la idea original la tome de dottori, pero a causas de costos lo copie de mi 990 con fibra de vidrio , un artesano local de mi pueblo lo realizo.
de la caja de cambios alguno puede aportar algo?
saludos teti
teti is offline   Reply With Quote
Old 10-02-2009, 03:07 PM   #800
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,779
saludos teti
Maybe this will help:
"the original idea was dottori, but because of cost we copy my 990 in fiberglass, and a local artisan of my people just did.
As for the gearbox, anyone can contribute something?"
(I think that is close)
Old 10-02-2009, 10:02 PM   #801
GR0NK
Got some screws loose!
GR0NK's Avatar
Oddometer: 1,958
Originally Posted by LILBIT
It still sucks just less than stock. Mines got a 1" wider (towards the rear)home brewed unit. A touch thicker too so i no longer feel the bulge in the pan. One step better the Gutz foam.
I can feel the same bulge on the EE tall soft that is on my wife's 525EXC. I have an EE tall soft on my 525 EXC but mine is an 05 with the one-bolt seat while hers is an 03 with the old two-bolt setup. Mine does not have the bulge.
The EE tall soft feels nice and I can do some pretty long days but I stand a lot when I ride. Someday I would like to get a Renazco seat for it.
Sean
Team Valley Bomb Squad
Nullus Vereor ex Terra Incognita
GR0NK is offline   Reply With Quote
Old 10-06-2009, 01:13 PM   #802
rickf
oldfatguyMAN
rickf's Avatar
Oddometer: 1,695
Originally Posted by Yooper-at-heart
KTM guys,
i want one bad and found a 2004 450exc plated in my state with 6k on it for a starting price of $2500. Assuming it's been maintained as stated it sounds like a good buy to me.
Anybody agree or disagree?
Thanks,
Soon to be KTM guy
Seems pretty cheap......................
I believe that year had a kickstarter gear issue, might check that as well as how many hours are on the motor, especially the valves.
Check all the usual bike stuff, anything that is supposed to move needs maintaining and anything that shouldn't needs tightening.
2005 KTM 525EXC, 2006 Triumph Sprint ST, etc., etc.
"Begin at the beginning and go on till you come to the end: then stop."
Originally Posted by rickf
Oh no, Robby's still a pendejo, but he's OUR pendejo!
rickf is offline   Reply With Quote
Old 10-06-2009, 01:29 PM   #803
GR0NK
GR0NK's Avatar
Oddometer: 1,958
LOL. It's the 05s that have the intermediate gear issue.
Sean
Old 10-08-2009, 07:12 AM   #804
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,493
I picked up a second one for $1800 a couple months ago.
Its 09, people need the money.
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 10-09-2009, 09:20 AM   #805
BIG-E
AKA; Mongo-E
BIG-E's Avatar
Oddometer: 2,053
Hello All,
I just traded for a '04 525exc, and I am also riding a 990"S"
I have a couple of questions, and do not have the time to look at all 50 some pages, so forgive me if this has been gone over.
What is the highest set of bars that I can run with a Scott's Dampner installed and weilded?
What is the best skid plate?
You guy's are gonna kill me for this one, what is the best........oh I better search that one, I am sure there are lots of info. on oil....
Take care all, Eric.
BIG-E is offline   Reply With Quote
Old 10-09-2009, 04:29 PM   #806
rickf
oldfatguyMAN
rickf's Avatar
Oddometer: 1,695
Originally Posted by BIG-E
Hello All,
Oh, no you didn't!
Ask about oil!!!!
Get a sub-mount for the Dampner and that will raise your bars 25mm I believe. Beyond that there are spacers or different bends but 25mm is a lot.
I like Enduro Engineering for just about everything.
Don't forget the clutch slave protector, shark fin and radiator guards (I used KTM's)
Oh, and Mobil 1 20-50W from WallyWorld, $22.00 for the 5 quart jug.
Old 10-09-2009, 05:47 PM   #807
Wattner
Wattner's Avatar
Oddometer: 5,270
Oh man you didn't just recommend THAT oil did you? It'll make the muffler bearings whine... You should use... blah, blah, doh de doh
I have 12 billion miles on the original oil with no breakdown at all, you really should try....
Wattner is online now   Reply With Quote
Old 10-09-2009, 07:53 PM   #808
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,779
Top 1 Pro Racing Synthetic.
(if only because they support Team Rally Pan Am's Dakar effort. Go Jonah! )
Old 10-09-2009, 09:47 PM   #809
GR0NK
GR0NK's Avatar
Oddometer: 1,958
Just don't use snake oil.
I use the stock Magura bars and like the bend. I also run the GPR underbar steering stabilizer and that raises them about one inch. Don't forget longer throttle cables, I use Motion-Pro 3" longer ones or you can rotate your throttle tube down and that can give you a little bit more if you need it.
I have tried Enduro Engineering aluminum, Flatlands Racing aluminum and the KTM plastic skidplates. My favorite for protection is the Flatlands Racing unit and it also mounts better on the bike than the EE one. (uses factory threaded holes in the rear and a sano front mount) It also is easy to change the oil without having to take it off. Overall I prefer the KTM plastic one. It mounts with one Dzus screw so it comes off on on in seconds and doesn't reflect as much engine sound as the aluminum skidplates. On a lowered bike I would only run an aluminum one though. My wife's 525 is lowered about 1.5" and it takes a beating. Not sure if the plastic one would hold up.
Sean
Old 10-18-2009, 08:50 PM   #810
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,779
Got one this week. Put it to use offroad today. Best $2500 I'll ever spend. Runs great and PO seemed to know it's maintenance history and requirements well and gave me filters , tools, cleaners , and oils he had, makes me think he used them. I'd post a pic but I can only figure out how to do it half of the time.
Anyways, bike is awesome!
damn good deal. Congrats!
Times are GMT -7.   It's 12:33 AM.
