04-26-2008, 01:17 PM
#1546 |
Ubernoob
Oddometer: 151
XT250 skid plate
Hi, I'm having trouble finding a skid plate for my 2008 XT250. Anybody have any ideas.
Thanks, Guy |
04-26-2008, 02:09 PM
#1547 | |
Oddometer: 2,402
Vince @ SWFL or WNC 2001 Kawasaki W650 2012 Ural Yamal |
04-26-2008, 02:46 PM
#1548 |
waiting for spring...
Oddometer: 212
2006 XT225 1982 CT110 (in pieces) 1982 C70 1970 CT70 1969 CB350 |
04-26-2008, 03:39 PM
#1549 |
Oddometer: 2,402
04-27-2008, 12:09 PM
#1550 |
I've posted this bike before but not sure if it's in this thread. If it is, I'm posting it again. I sold this bike last year and want it back. I'm going to get another in the next few months and build it just like this one....again.
It started as a normal xr250R ![]() I tore it down and greased all bearings. I also replaced the shock linkage bearings (they didn't need it but I thought they did). ![]() I ordered a few parts ![]() I had about $2k total into this bike. It handled just like my kdx when I wanted it to. It was PERFECT for 55 and under dualsporting. It would climb any goat trail I cared to. I'm getting another one ![]() ![]() ![]()
04-27-2008, 04:32 PM
#1551 | |
Oddometer: 364
Thought I would toss out a couple of questions for all you MT riders.
Anyone going to the Aerostich 25th anniversary party in Duluth, Minnesota 8/22-24 (details at www.boringrally.com). My plan (I am going) is to take my DR250SE and then loop Superior and Huron (opposite direction as last time) on my return trip home. What about the BYOB 6/6-8. This one might be tough for me with my work schedule but possible. Anyone going to be there with their MT rigs. Quote:
Yater, that's a common look to my bikes on a regular basis. Couldn't part with my DR250/350SE's, no way. Well at least you know what to do the second time around. Have put about 500 miles on mine (DR250SE) sorting out areas yet to be addressed. Went out today for another run. Here's a shot from the cockpit. steve gs screwed with this post 04-28-2008 at 09:25 AM |
04-28-2008, 02:48 PM
#1552 |
Ben
Oddometer: 53
steve gs
I'll be headed to the Duluth rally in August if I can master some mechanical skills between now and then. I'm way too noob to attempt a ride from Ohio to Minnesota without some idea of what to do should I break down or puncture a tire.
04-29-2008, 01:33 AM
#1553 | |
Gypsy diver
Oddometer: 1,473
Think of the $$ you will save on not paying someone else to do it and you won't mind spending the $$. I also grabbed an old milk crate and slit an old innertube and stapled it around the edge as a place to break down the tire in the garage. It is something that you should practice in your garage once or twice before you go. there are plenty of write ups on the "how to do its" the hardest part for me is dealing with rim locks and getting the valve back through the rim. Most dirt bike type tires don't require a bead breaker either. Tubes are my biggest complaint on bikes like this, they are a PITA compared to the ability to plug a tubeless tire.
2005 Yamaha XT225 |
04-29-2008, 05:29 AM
#1554 |
Oddometer: 364
Good advice from motorbiker.
The rim protectors should be part of your travel kit, get 2 sets of 2. Add a set of good irons and a bit of practice which you will get when you fit the new tires for your trip and you will be good to go. Take the next step by balancing your wheelset with dynabeads (www.innovativebalancing.com). I have mentioned both of these things before in previous pages of this thread. You have three things to consider for long distance touring, the bike, you, and you and the bike. To prepare your bike for long distance touring go through everything whether it is new or a seasoned veteran, no assumptions accepted. Check everything by inspecting/repairing/replacing all bearing/pivot points for grease, final drive for wear, wheel bearings, controls, fuel system, electrical harness, connections, bulbs, and battery. If in doubt replace it. Don't forget you! Get out and ride ride ride. Learn your bike. Develope the physical and mental capabilities for hours in the saddle if long distance touring is your passion. This sort of naturally rolls into the third element which is the symbiosis of you and your bike. As I have mentioned before, READ Weary By Sundown by Dr Stroud which appeared in the 11/07 BMWMOA Owners News. Set up the ergos so you are comfortable and can move around to stretch out as you cruise along. Don't be surprised if you have the wrong bike for good ergos. I look for a weight distribution balance between my legs and arse with virtually no weight on my hands. My upper body is fully supported by my quads (a good reason to take up cycling). This is a somewhat leaned forward attitude with the added benefit that the back is unloaded with minimal weight on the arse. An indication of my form breaking down is when I begin to "grip" the bars in anything other than a control activity. Take regular breaks and you can ride all day long. NDVR or anyone else thinking of going to the Aerostich Rally and would travel through SE lower Michigan area PM me and perhaps we could put together a group run. As I have stated before the best way to MT with a group is to allow each to run at their own pace and have rally points along the route to keep track of riders. steve gs screwed with this post 04-29-2008 at 06:02 AM |
04-29-2008, 07:06 PM
#1555 | |
AKA Deanohit
Oddometer: 272
![]() Heres the vid from last weekend, a slow ride with Kanny on her Suzuki TU250 Volty that has been turned into a scrambler: Ride Report here: http://www.advrider.com/forums/showthread.php?t=336495 Bumble, the mighty ADV Volty! ![]()
It's more fun to ride a slow bike fast, then a fast bike slow. \m/ (>_<) \m/ My XT225 Build |
04-29-2008, 07:15 PM
#1556 | |
Oddometer: 1,112
interested in riding part way
If there is a group passing thru SE MI I would be interested in riding part of the way up. Can't commint to it all but maybe a couple of days headed north would work. I would be using a DR200.
04-29-2008, 08:14 PM
#1557 |
plainsman
Oddometer: 89,096
That's gorgeous. Another unavailable Suzuki here.
_______ |
05-01-2008, 04:13 PM
#1558 | |
just passing through
should anyone need assistance i can provide contact information ahead of time.
lookin' for a place to happen; makin' stops along the way - the tragically hip needless dickery |
05-01-2008, 04:44 PM
#1559 | |
Gigity gigity Gig-it-y!
Oddometer: 185
Scott 2008 Kawasaki KLR6Fitty (red, the fast one) Yamaha XJ600S Seca II (red, the fast one) RIP '04 Kawasaki KLR2Fitty (red, the fast one) "The North American P-51-D Mustang with the Rolls-Royce designed, Packard built, Merlin engine and Laminar flow wing is the greatest airplane ever built. We should build more of them, just because we can." Brian Nelson |
05-01-2008, 05:44 PM
#1560 | |
Oddometer: 364
Great, we'll be there in the morning! Route plan is rather simple, northbound through the lower (something like find way to 15 then to 13, pick up old 76, to 27, and run Grayling Hwy (old 27) and then I-75 to Mac). The UP is easy, stay with 2 or jump a bit north to run 28, depends what you want to see. Willing to pick up riders anywhere along route. I cruise at 50 mph. I have to travel to the BMWRA annual rally at Houghton (UP) in June and will run planned route for this trip.
