Old 02-15-2012, 03:28 PM   #4666
frog13
frog13's Avatar
Oddometer: 1,337
front disc brake
Front brake lever feels alittle stiff.....does it need bled?....bike stops well(as much as can be expected).Haven't seen any leaks.
frog13 is offline   Reply With Quote
Old 02-15-2012, 04:14 PM   #4667
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,123
Is the front caliper releasing all the way? You should check to see if the front wheel spins freely.
ps. What kind of bike do you have?
windigo
Klay screwed with this post 02-15-2012 at 04:19 PM
Old 02-15-2012, 05:25 PM   #4668
jon_l
jon_l's Avatar
Oddometer: 3,149
I'm still running the OEM trailwings,front is a tw31 and the rear is a tw34...do you folks run tire pressure as to what the manual states or do you go by the sidewall numbers...max pressure.This in regards to riding on thr road.
Manual or consensus of riders with same bike / tire set-up. Never sidewall.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 02-15-2012, 05:58 PM   #4669
frog13
frog13's Avatar
Oddometer: 1,337
09 TW200....wheel spins fine?.
Old 02-15-2012, 05:58 PM   #4670
frog13
frog13's Avatar
Oddometer: 1,337
Never sidewall even at max load?. The reason I ask this...I had a xr650L,used the manual recommended psi.....at the 600 mile check-up the mechanic said my tires were way to low(25psi,I think...he said they should be at least 30ish) can't remember what the sidewall read on the L.
Old 02-15-2012, 07:52 PM   #4671
poppawheelie
poppawheelie's Avatar
Oddometer: 560
Same tire can be used on many different bikes. Max pressure on sidewall is for heaviest bike at heaviest load. Max pressure you should use on your bike is per Owner's Manual. For off pavement, you should run less pressure so tires absorb shock of small rocks and grip better on sand and loose dirt with a lower profile. On a DR650, I run down to 15 PSI. Trick is to run as low a pressure as possible without getting snakebite. That's when rim pinches tire and tube against a rock and leaves two little holes in the tube that look like snakebite. Exactly the same principle applies to mountain bicycles.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie screwed with this post 02-15-2012 at 09:00 PM
poppawheelie is offline   Reply With Quote
Old 02-15-2012, 10:09 PM   #4672
DYNOBOB
lucky dog
DYNOBOB's Avatar
Oddometer: 1,024
A few pics of my KLX250S "touring" setup. Did a 730 mile weekend last fall, half street/half TAT in TN. Bike performed better than a 250 has a right to, will run 65mph (on gps) all day if needed.
TE630.KLX250S.GL1800.CBR900RRturbo.919
HoW (ForeverWest) 2014 CO/UT 2013
Northern Rockies 2013 IBA Key West 2014 Tentspace
DYNOBOB is offline   Reply With Quote
Old 02-15-2012, 10:16 PM   #4673
Trailrider ZA
Trailrider ZA's Avatar
Oddometer: 65
That is a very cool setup!
www.trail-rider.co.za
Trailrider ZA is offline   Reply With Quote
Old 02-15-2012, 11:03 PM   #4674
Spud Rider
Spud Rider's Avatar
Oddometer: 3,771
Your bike looks great! Is that a Turbo City windshield? How well do you like your windshield?
Spud
Old 02-15-2012, 11:09 PM   #4675
Kankujoe
Adventure Traveller
Kankujoe's Avatar
Oddometer: 156
Great looking setup!
Tell me about your seat? Looks like you modified it or added something to the sides?
Joe
2012 Suzuki V-Strom-ADV, 2013 Suzuki V-Strom-EXP, 2008 Yamaha TW200, 2013 Honda CRF250L
I'm never lost... Because I'm always right where I'm at...
Kankujoe is offline   Reply With Quote
Old 02-15-2012, 11:15 PM   #4676
Klay
dreaming adventurer
Klay's Avatar
Oddometer: 102,123
That's the sweetcheeks seat cover.
windigo
Old 02-15-2012, 11:37 PM   #4677
Kankujoe
Adventure Traveller
Kankujoe's Avatar
Oddometer: 156
Joe
Old 02-16-2012, 03:17 AM   #4678
Llamaha
Oddometer: 850
Very nice setup indeed
Llamaha is offline   Reply With Quote
Old 02-16-2012, 08:32 AM   #4679
sealsam
Sam...I am.
Oddometer: 1,851
Spud
Allow me...that is a TCI windscreen that Dyno told me about in another forum. I ordered it, put in on and did a little 100 mi zip around the Anza Boreggo. Great coverage! I would suggest this windscreen without hesitation. Good thick quality and mounts up without any real fuss.
sealsam is offline   Reply With Quote
Old 02-16-2012, 09:39 AM   #4680
Hannda
Short, fat, bearded, slow
Hannda's Avatar
Oddometer: 28,044
Great looking. :greenwithenvy
Hannda is offline   Reply With Quote
Times are GMT -7.   It's 01:33 AM.
