Old 04-05-2013, 01:37 AM   #6256
kirkkw
Oddometer: 111
Bought one
Didn't need it but for $40 delivered, I couldn't resist so now I have a spare.
Problem with this strategy is that I may need another bike to use with the spare trunk.
KK
kirkkw is offline   Reply With Quote
Old 04-05-2013, 04:27 AM   #6257
SAPB
SAPB's Avatar
Oddometer: 1,593
KK
Yes, it would be better if the mounting plate were flat with nothing sticking up, but I can live with it. I carry one each of these in my tank bag for securing things to the bike. The shear length of the AS one makes it extremely useful. you just need to tie the excess to something, or you'll have a long tail flipping behind you. Use two for heavier stuff. I've gotten one of those 16 packs of paper towels home with one. Not sure why people were looking and pointing for other people to look The 2nd one will secure a 12 pack of frosty ones nicely.
http://www.aerostich.com/bags/more-p...go-straps.html
http://www.amazon.com/Chase-Harper-B...r+bungee+buddy
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB screwed with this post 04-05-2013 at 04:40 AM
SAPB is online now   Reply With Quote
Old 04-05-2013, 04:54 AM   #6258
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,166
Could those JC Witney trunks be mounted as side packs? If so, you could carry a bunch of stuff for $120.
GlennR is online now   Reply With Quote
Old 04-05-2013, 06:18 AM   #6259
Pugsley/Hobbfather
Oddometer: 415
FAB-u-lous:
Make mounts. If they are designed to go onto a mount, the mount gets mounted wherever YOU want it.
Of course, then you have to figure out the mounts...but that's easier than designing and building your own bags.
If you're in or near VT, I can fab up whatever you need. Many places can.
Pugsley/Hobbfather is offline   Reply With Quote
Old 04-05-2013, 08:17 AM   #6260
Hawk62cj5
2 Cheap 4 a KLR
Hawk62cj5's Avatar
Oddometer: 593
Originally Posted by Spud Rider View Post
J.C. Whitney is once again selling travel trunks! They are now called Garage Pro Travel Trunks. The large travel trunk is on sale for $44.95, with free delivery, if you order before Tuesday! In addition, you can get another 10 percent off the price by using the promo code "zoom10."
http://www.jcwhitney.com/garage-pro-...58683y1989u0j1
My J.C. Whitney Travel Trunk has taken a lot of abuse for several years. I like it so much, I bought a spare when they were on sale for $48, delivered. At a price of $40.46, delivered, this travel trunk is an exceptional bargain!
Snip
Spud
Thanks I ordered mine . Im building my own rear rack , I cut them metal 2 months ago or more but just havnt gotten around to pulling out the welder and welding it together . Ill wait for the box now so I can make sure it it will fit before welding it up because I was planing on putting a rear loop/handle on it .
its been sitting on my basement floor just like this for a long while. I may be a procrastinator .
From the bottom when I was mocking it up , in the top pic you can see to holes for the wires and signal light bolts .
Cant wait to put it on so I will have a rack and get rid of the lolipop turn signals .
09 Super Sherpa KL250
62 CJ-5
Trailering a bike is like hiring a prostitute just to jerk off in front of her .
Hawk62cj5 is offline   Reply With Quote
Old 04-05-2013, 09:53 AM   #6261
Spud Rider
Spud Rider's Avatar
Oddometer: 3,798
Search ADVRider and you will discover some riders who mounted three of these travel trunks. They mounted one trunk on the luggage rack, and two trunks as saddlebags. I have also read reports these trunks will fit Givi mounting plates.
Spud
Old 04-05-2013, 09:58 AM   #6262
sandalscout
blah blah blah
sandalscout's Avatar
Oddometer: 2,253
Originally Posted by Rhompin45 View Post
What's involved in lowering a motorcycle?
I've never done it, so don't know the immediate consequences, but plenty have, so it will work.
Generally, you purchase lowering links for the rear shock assembly and then slide the front forks up within their mounts. Both are really easy to install/do.
To install the links, put the bike on a stand with the rear wheel off the ground. Remove the bolts holding the stock links, and install the new ones.
To slide the forks up, loosen the front fork bolts that "pinch" everything in place, and move them up the same distance that the rear links lower the bike.
sandalscout is offline   Reply With Quote
Old 04-05-2013, 10:02 AM   #6263
geniuskidzz
Oddometer: 14
hi guys, need a little bit help here :
i'm Indonesian, and im currently using a Bajaj Pulsar 220. with 21 HP and 19 NM this thing run quite fast while easy on my wallet
18l tank with 30-40 km/l make it easy for go 500-700km in one fillup, and cruising at 90-100 km/h is easy for this bike ( it could go easily until 120km/h, but from there until top speed at 144 is long way up)
its cheap ( with tax only US$1950 in here, new)
and my favourite, for a small displacement thumper, the vibration is really small ( the indian somehow use a balancer shaft on this thing, really supress the vibration)
this is my bike :
but im seeking for something new. as you can see, this thing is actually a full-street bike ( its even came with a sport clip-on handlebar - i change it to trail handlebar from yamaha YZ85 )
it could handle some gravel, some heavy clay mud ( ok not some.. ) but still, its a street bike. Its heavy for its size ( curb weight about 170 Kg if i didnt mistaken). and one biggest weakness, its subframe is not that strong ( a combination of loaded givi e45 with wingrack 2 and e-21 in several of my friends has left theirs with cracked subframe)
Im looking for these :
- low vibration ( to compare, maybe around ninja 250-650 vibration maybe )
- just enough power to do cruising speed at 120 km/h and could easily get to 140 km/h for overtaking ( i didnt asked much didnt i?)
- have around 500 km range in one fillup ( so either it sips fuel or it gulp fuel but got big tanks. aftermarket tanks is fine as long as got reasonable price. One example for unreasonable price is the front auxiliarry tanks for F800gs ( hell no im spending US$ 2000 on a fuel tank)
- my trip just around 2000-3000 km in single trip, so didnt that long. i guess every bike will have that durability
- prefer lighter bike. Reason : Plotholes. Lots of it. either 17-17 or 19-17 rim, but i will take dual sport tyres ( no knobbies-mainly gravel and asphalt, with just a little mud play. i could even consider battlax )
- have at least power output for a pair of 55 watt HID ( that means about 130-150 watt) and some accecories. 200 watt is a lot for me, but i need at least 150 watt.
- i'm considering new or not to old one ( 2009+ maybe? )
- water cooled thumper or twin.
- a little bit easy on maintenance ( so dont give me those RFS from KTM )
oh and i live in Indonesia, the tax here is quite crazy, so i'll prefer some cheaper bikes. maybe under US$ 10000 new? ( XT660z tenere is a NO GO - too expensive )
the bike on my list right now :
-Versys 650 ( this one only need dakar fairing)
-Ninja 250 Fi ( yes, it will got lots of modification. at least reinforced subframe, new front-end, and new dakar fairing)
whatever i got, i'll do same mod to them : dakar fairing ( i just love it)
thanks for the suggestion
edit:
for comparison in prices, xt660z tenere tagged at US$ 22.000 in here. Versys at US$10.000, ninja 250 FI at US$ 5500.
geniuskidzz screwed with this post 04-05-2013 at 10:25 AM
geniuskidzz is offline   Reply With Quote
Old 04-05-2013, 11:11 AM   #6264
SAPB
SAPB's Avatar
Oddometer: 1,593
Bike lift
My Tusk lift came today, and it didn't take long to assemble. At the lift's lowest setting, it won't fit under my bike, so I just roll the front tire up on a piece of wood, or whatever, then slide it under.
http://www.rockymountainatvmc.com/p/...=1365185158706
Old 04-05-2013, 11:35 AM   #6265
Rhompin45
Rhompin45
Oddometer: 250
I don't know if Suzuki imports the tu250 there there are a couple other names used in other countries such as grasshopper 250 or something like that I can't remember off hand. Anyways I cruse around on mine 75 mph all the time so 100 km/h (65)mph would be no problem the tank is not quite as big 3.2 gal (3.73l per gal) if you get 30km/l roughly 69 mpg I can get that if I drove 60 65 mph. I have had it on dirt/ gravel roads with the stock street tires and it does fine I wouldn't recommend overly bumpy roads or jumping it from experience the shocks bottom out really easy. Only 3. Something inches of travel.
Rhompin45 is offline   Reply With Quote
Old 04-05-2013, 12:43 PM   #6266
SAPB
SAPB's Avatar
Oddometer: 1,593
this is my bike :
edit:
Looks like a bicycle water bottle mount on your left bar, nice! I have a CRF250L that puts out 337 watts, but only has a 7.76 liter tank, though an aftermarket soon to be on the market will be 11.5 liter. Not sure of pricing over there on this type bike. 29.7 kilometers/liter gas consumption. Good luck!
SAPB screwed with this post 04-05-2013 at 12:52 PM
Old 04-05-2013, 01:28 PM   #6267
judjonzz
Beastly
judjonzz's Avatar
Oddometer: 2,009
What's involved in lowering a motorcycle? I have an old dr250 that I started turning into a dual sport and gave up and bought a tu250. I thought about selling the dr but if I can lower it a couple inches my gf could maybe ride it to learn how to ride. My mind changes every 10 seconds on what I want to do. Thought about using it as a down payment on a dr650 of that terra 650 thanks to all who mentioned it. But I don't really know if I need that big of a bike. But sometimes it would be nice.
Kouba makes links to lower your rear suspension. For the front, just slide the fork legs up in the clamps. Swapping the links is pretty easy. On the front, you may need to do something with a spacer to limit travel. Look at the instructions for your bike.
http://www.koubalink.com/
Because the longer links give the rear swing arm more leverage on the spring, you will have to increase preload, or possibly install a stiffer spring (Kouba can sell you one) depending on your weight. A shorter side stand is also in order. There are at least 3 different lengths of side stand available from Suzuki. The stock DR650 stand is about right for a lowered DR350, and is probably the one you want for your 250.
For deMille, young fur-henchmen can't be rowing.
judjonzz is offline   Reply With Quote
Old 04-05-2013, 02:21 PM   #6268
Rhompin45
Rhompin45
Oddometer: 250
Thanks for the lowering input! I have seen the front done before but not the rear sounds easy enough. I put a lift on my jeep but obviously bikes are easier I just didn't know it was that easy.
Old 04-05-2013, 02:24 PM   #6269
Spud Rider
Spud Rider's Avatar
Oddometer: 3,798
If you are interested, you might enjoy reading my thread where I detailed the steps I followed while installing the Performance Design lowering link on my Honda XR650L.
http://www.thumpertalk.com/topic/839...lowering-link/
Spud
Old 04-05-2013, 09:31 PM   #6270
geniuskidzz
Oddometer: 14
will CRF do 140 km/h? and how about the subframe? will it hold aluminium panniers? if yes, im considering buying it off Thailand ( will be a CBU, but i recon it will be better than the other choices..versys is the top of the list right now but it got lots of power that i didnt need in here, not to mention its real heavy )
oh that bottle holder i dont know why but in here, lots of our rider use it. It was US$ 3 ( including bolt etc.. ), mounted on mounting bolt for left rear view mirror. But its not for some heavy stuff ( like alumunium bottle, etc) it will hold cans, plastic bottle, and other lighter bottle.
oh and im interested about that gas tank , how much it supposed to be cost when its ready? 300km might be a little low but will do for me ( the longest strecth in southern Java is 112 KM without any fuel station, but finding fuel station with 92-95 octane is a little bit hard. Finding one with EDC for credit cards is a lot harder though )
thank you for your response
Times are GMT -7.   It's 05:44 AM.
