02-05-2007, 03:55 PM
#1 |
Made in Wyoming, Proudly
Oddometer: 10
Drive Shaft Recommendations
Hello All,
I was hoping to get some advise/suggestions on which direction I should go as far as replacing or rebuilding my R100GS/PD drive shaft. The bike has approx. 88K on the clock, as far as I can tell its not the original (un-updated) drive shaft, changed at least once. It went out on Saturday while going down the freeway heading to a planned Dual Sport adventure south of Blythe, CA. Haven't torn into it yet, but when I peeled back the rear rubber boot on the shaft housing, pieces of needle bearings and housing fell out and it "clunks" when wheel is turned. My question is, should I replace the drive shaft with a stock BMW one or look to the serviceable aftermarket ones with Grease Zerks. I run the bike hard in the desert with full knobbies, trying to keep up with my buddy on his R80G/S, so the more robust the replacement shaft is, the better. If the aftermarket shafts are the way to go, please provide product name/purchase info. Also, is there any other service recommendations I should perform to the final drive while I have everything apart. Thanks very much in advance. Troy. |
02-05-2007, 04:04 PM
#2 |
black cloud wandering
Oddometer: 717
sounds like final drive destruction as well but maybe you knew that...
