Old 02-08-2007, 11:23 AM   #1
De Eee OP
De Eee's Avatar
Oddometer: 172
Clutch Bleeding Tricks on a KTM 450 EXC, Got any?
My clutch seemed to be a little out of adjustment so I decided to bleed it the other day. It was difficult to find neutral and was dragging some. My last bike was a XR400 so I had no experience with a hydraulic unit.
I went to 3 Bros and got the bleeder kit and launched into the operation. "How difficult can it be," I thought?
What is the trick to filling the syringe and hose with fluid and getting it on the fitting without getting some air in there? I was eventually able to bumble through the operation and got 'er done but I sure wish I had seen it done before.
I'm all ears.
De Eee is offline   Reply With Quote
Old 02-09-2007, 07:17 AM   #2
SpeedStar
XT1200Z and DL650
SpeedStar's Avatar
Oddometer: 533
I put a speedbleeder on my slave and fill from the master reservoir and pump the lever until no bubbles come out through bleeder with tubing attatched. Easy and takes only a few minutes.
FS: XT1200Z Super Tenere Gas Tank Side Panel Guards, Rear Tank Guards, Fork Tube Guards, Headlight Masks and Exhuast Shield Masks
http://advrider.com/forums/showthread.php?t=714789
FS: V-Strom Frame guards, triple-clamp guards and THE ORIGINAL Headlight Masks
http://www.advrider.com/forums/showthread.php?t=356383
SpeedStar is offline   Reply With Quote
Old 02-16-2007, 10:50 AM   #3
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,899
It took a while to bleed mine but the trick is, the syringe has to be completely full and all fluid must be pushed thru at once, handy to have two people but i didnt. good luck. F.D.R. (noob)
Foot dragger is offline   Reply With Quote
Times are GMT -7.   It's 06:29 AM.
