Old 02-16-2007, 08:34 AM   #1
gary138 OP
Oddometer: 98
R1200GS valve adjustment
Hi, I just picked up a cd owners manuel for my brothers 2005 r 1200 gs . I hope to do his valve adjustment to save him some $. I do all my own maintenance over the years but never on a BMW.
My questions on doing a valve adjustment are > Is there a easier way to make sure the bike is at TDC than sticking a special tool in some hole, if not the manual really doesn't say much and is there only one hole , in other words when I move to the other side am I using the same hole or is there one on that side also??
The valve adjustment seems straight forward but then it says to Set the valves actuated by a common rocker arm to exactly the same setting but doesn't show where ( no photo of this being done ). If the inlet valve is .15 that would mean the rocker would be the same ?? and .3 for the exhaust. And what kind of an adjustment is this rocker arm ? ( locknut like the valves ?? ) this is what this section looks like. Thanks for all feedback !!!!!!!!! is there easier write up to follow or video made by somebody from this group. Thanks agin !!
Measure valve clearance with feeler gauge.
[IMG]file://D:\Datas\Reprom\BMW-Motorrad\SYMB\KG\MODELLE\00\hinweis.gif[/IMG]
Note
You should feel slight resistance as the blade of the feeler gauge slides between the valve stem and the rocker arm.
[IMG]file://D:\Datas\Reprom\BMW-Motorrad\SYMB\KG\MODELLE\00\techdat.gif[/IMG] Technical data
Valve clearance, inlet valve
engine cold max. 35 C
0.15 mm
Valve clearance, exhaust valve
0.3 mm
Result: Valve clearance is out of tolerance.
Measure:
[IMG]file://D:\Datas\Reprom\BMW-Motorrad\imgs\icon\bullet.gif[/IMG]
Correct valve clearance with adjusting screw and tighten locknut.
[IMG]file://D:\Datas\Reprom\BMW-Motorrad\SYMB\KG\MODELLE\00\Anziehdrehmoment.gif[/IMG] Tightening torques
Locknut, valve adjusting screw, M6 x 0.5
8 Nm
Recheck valve clearances.
Set the valves actuated by a common rocker arm to exactly the same setting.
Check valve clearances and adjust if necessary and, repeat the same procedures for the second cylinder
Gary P
04 V-Strom 1000 42K, ,01 KLR650 24K,04 H-D Road King 8K
Sold but not forgotten 98 concours 110K
gary138 is offline   Reply With Quote
Old 02-16-2007, 09:13 AM   #2
impi
impi's Avatar
Oddometer: 1,247
Here's the link to the detailed procedure posted by JimvonBaden.
Impi
_____________________
2007 R1200GSA
impi is offline   Reply With Quote
Old 02-16-2007, 09:14 AM   #3
Jetjock
Oddometer: 1,012
try this
http://www.davedragon.org/Photos/BMW...-A_VA/pics.asp
or
http://www.bmwmc.net/uploads/tm11/R4...115_medium.wmv
Jetjock is offline   Reply With Quote
Old 02-16-2007, 09:17 AM   #4
St. Arbucks
Looking for clues...
St. Arbucks's Avatar
Oddometer: 368
Get the write up by Jim VonBaden. Excellent, with pictures. Also the write up in the hall of wisdom by JonJen and company - another excellent source. Lot's written on the subject. Good luck.
Jim
2013 Tiger 800 XC, 2007 ST-1300, 1991 KLX-650
I've seen things you people wouldn't believe...
St. Arbucks is offline   Reply With Quote
Old 02-16-2007, 01:34 PM   #5
Road Scholar
It's a Good Day To Ride
Road Scholar's Avatar
Oddometer: 94
On The Money??
Jim's write up is excellent, you won't go wrong with it.
However.
Setting up TDC need not be a hair splitting proposition, close is good enough.
What I have done.
With pulgs removed and having engaged 6th gear I rotate the engine to where I see the intake valves closing, which means that TDC compression is coming up (where you, ideally, want to set the valve lash). I put a screw driver, or a long soda straw, in the plug hole and work the rear wheel, gently, until I feel the piston come up and then fractionally decend--you can go back and sneak up as often as you want, but make sure that you stop moving the engine after moving the rear wheel only in the forward direction, this insures that the can chain slack is out of the equation. You can safely set the valves at this point. Don't forget you are setting the maximum clearance so you can check your work by measuring again when, say, the exhaust valves are at, or near, maximum open.
I am a fan of the hash mark on the cam, but anywhere between 2:55 or 3:05 is as good as 3 O'clock, given that 3 O'clock can be somewhat subjective.
Best wishes, you'll do great!
B.
Only Rich People Can Afford Poor Quality
Road Scholar is offline   Reply With Quote
Old 02-17-2007, 04:25 AM   #6
Jetjock
Oddometer: 1,012
B.
But surely there wont be any clearence when the valve is fully open or have i misunderstood
Old 02-17-2007, 01:50 PM   #7
Road Scholar
Oddometer: 94
Clearance
When the exhaust valves are at, or near, full open the intakes should be at, or near, full clearance (lash). Similarly when the intakes are at, or near, full open the exhausts will be at, or near, full clearance (lash).
The point being that if you set the lash correctly it will be the maximum measurable at any given point during the cam cycle while the tappet is on the cam's base circle. The base circle can be as much as 180+ degrees of cam, or 360+ degrees of crankshaft rotation.
Hope this helps.
Old 05-09-2010, 09:42 AM   #8
rtbain
buff
rtbain's Avatar
Oddometer: 9
TDC is nice. All you really have to do is have the rocker on the base circle of the cam. Anywhere on the base circle will do. It’s just an internal combustion four stroke engine. The principle is the same.
Measure the gap between the valve stem and the flat on the bottom of the adjuster.
buff
rtbain is offline   Reply With Quote
Old 05-09-2010, 09:54 AM   #9
hojo in sc
Oddometer: 935
Originally Posted by rtbain
TDC is nice. All you really have to do is have the rocker on the base circle of the cam. Anywhere on the base circle will do. Its just an internal combustion four stroke engine. The principle is the same.
Wow, only 3 years old.
hojo in sc is offline   Reply With Quote
Old 05-22-2010, 09:21 AM   #10
Jason1202GStime!
Jason1202GStime!'s Avatar
Oddometer: 251
Just curious, why do we need to remove the spark plug for valve clearance?
Any expert here care to share on this?
Jason1202GStime! is offline   Reply With Quote
Old 05-22-2010, 09:30 AM   #11
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 957
It/they are removed so it is easier to rotate the rear wheel in gear. Otherwise, the engine's compression makes it almost impossible with the plugs in.
whisperquiet is online now   Reply With Quote
Old 05-22-2010, 10:43 AM   #12
Jason1202GStime!
Oddometer: 251
Oh, so it should be ok if i just loosen the spark plugs right?
Old 05-22-2010, 10:47 AM   #13
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,409
Remove them and observe them...they tell volumes about what is going on in your combustion chambers.
def is offline   Reply With Quote
Old 05-22-2010, 02:00 PM   #14
GSman of La Mancha
So!? My dog loves me...
GSman of La Mancha's Avatar
Oddometer: 602
you need a thin wall socket
A regular socket will get stuck in the plug "hole". You need a thin walled deep well socket..... You can get 'em at most auto parts stores. ---- But, maybe not in Singapore! I havent been there since 85. Is Change Alley still hopin'?
Sometimes I believe what I see. Other times I see what I believe. Occasionally, I don't even look.
-Me
GSman of La Mancha is offline   Reply With Quote
Old 05-22-2010, 06:36 PM   #15
fir_chan
Little Red Dot
fir_chan's Avatar
Oddometer: 98
We get lots of stuff here in Singapore otherwise there is always the internet!
Change Alley from 1985 is lot different from today! Come by when you get the chance..... of course the weather is still hot as......
**2015** KTM 1190 Adventure R **2013** Honda CRF250L **2008** BMW R1200GS Adventure
fir_chan is online now   Reply With Quote
Times are GMT -7.   It's 07:11 PM.
