Old 03-31-2007, 03:10 PM   #16
klm4755 OP
Oddometer: 575
As a aviation mechanically fastened joint rule, no threads should be at the shear plane (fay surface interface) or in bearing. I would say out of all the modifications and servicing I have performed on my KLR650 (the doo, oil screen, 400 watt rotor, electrical upgrades) the subframe drill thru was the most risky.
Keith
klm4755 is offline   Reply With Quote
Old 03-31-2007, 07:47 PM   #17
SWriverstone
Woodpecker
SWriverstone's Avatar
Oddometer: 281
One more "clean shop" tip: when I was drilling out the frame, I used a small bungee cord and lashed the open end of my shop-vac tube right beneath the drill, then just let the shop-vac run while I was drilling—it worked great! Sucked up those metal shavings as they spewed out—no muss, no fuss!
Scott
SWriverstone is offline   Reply With Quote
Old 04-01-2007, 01:10 AM   #18
Subcanis
Unskilled Aerofixer
Subcanis's Avatar
Oddometer: 1,115
Keith
As a fellow aviation mechanic... I have to ask why? Its a simple procedure with easy instructions. No theads in shear...
Any boob with a decent drill and any kind of instruction following abillity can do this...
"I’ve seen ‘em all for 65 years and I never saw a buckin’ hoss to top Steamboat. Bronc riders are harder’n scrap iron, but ol’ Steamboat put some of the toughest into the hospital for repairs.”
Subcanis is offline   Reply With Quote
Old 07-09-2007, 08:52 AM   #19
klm4755 OP
Oddometer: 575
No so sure I would agree with this statement. Breaking a drill mid-way thru this operation and/or not aligning the holes would be a major ordeal. Drilling steel is difficult, without a "real" piloted step drill.
Keithm
Old 04-09-2013, 07:44 AM   #20
Keating
pre-n00b
Oddometer: 202
Originally Posted by klm4755 View Post
Saw this thread yesterday and headed out to the garage last night to size things up on my "new to me" '04 and discovered the left side of the bike looks exactly as pictured here.
One more mod I don't need to do, now.
I'll probably take the bolt out, mic it (verify it's the larger .39" bolt), regrease it and locktite it back in there.
The lower subframe bolts appear to have been done at one time, as the left side of the bike as a grade 12.9 hex drive, cap head bolt, but the right side has some cheesy zinc plated, flange head bolt, with no grade markings.
Will head over to the local fastener shop for a 12.9 replacement, forthwith.
Keating is online now   Reply With Quote
Old 10-06-2014, 01:29 PM   #21
Capt_phun
Capt_phun's Avatar
Oddometer: 111
Rise from the dead, drill through upgrade!
I did the drill through and it was easy. I count myself as a boob & I didn't even have a decent drill, just a Ryobi 18V cordless that went through two batteries (1 was partially dead). Used a good quality cutting/tapping fluid, vacuumed out the shavings, and most importantly took my time to make sure I got it straight in the hole. The Mrs. has taught me how important that last step is!
Capt_phun is offline   Reply With Quote
Times are GMT -7.   It's 09:04 PM.
