Old 03-21-2010, 02:31 PM   #6796
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Originally Posted by Crofty
Rear Rim Lock
Put a Pirelli rear on the other day and after some snotty terrain on sat i have notice the tyre has spun slightly.
What size rear rim lock do i need??
I can never find anything i want when i use the 'search this thread' button dammit!
2.5" (Written on rim).
The best is from Talon.
NordieBoy is offline   Reply With Quote
Old 03-21-2010, 02:47 PM   #6797
Crofty
Life's a Garden, DIG IT!
Crofty's Avatar
Oddometer: 611
Cheers
1977 BMW R100S
2010 TM 450 FES
2008 DR 650
1995 WR 250Z
Crofty is offline   Reply With Quote
Old 03-22-2010, 12:24 AM   #6798
ozbikedude
so little time
ozbikedude's Avatar
Oddometer: 2,050
i have oil in the air box whats the cause of this ???help..................advice/knowlege/anyone???
nothing sweet about me
04 950 adv s
08 dr 650 (sold)
ozbikedude is offline   Reply With Quote
Old 03-22-2010, 12:40 AM   #6799
cmg
wannabe dirt rider
cmg's Avatar
Oddometer: 292
my limited knowledge:
oil breather/vent hose is run into the airbox (from the bottom end),
when a bike is ridden at high revs for an extended time (eg hwy use), or just ridden hard, the build up in oil pressure/temp can cause it to "vent", which may cause oil in the airbox.
Dont quote me, but this is how I believe it.
So I spose the questions are;
  • have you ridden in those circumstances recently?
  • how much oil are you talking about?
  • did you clean air filter recently and use too much filter oil?
that's all I've got, and Im not sure if its even accurate
Living the dream....well trying at least
Dont like what I post? leave your comments HERE
I used to ride.....
1, 2, 3, 4, 5, 6, 7, 8, 9
, 10
cmg is offline   Reply With Quote
Old 03-22-2010, 12:44 AM   #6800
ozbikedude
so little time
ozbikedude's Avatar
Oddometer: 2,050
that may be it i have done nearly 500kms on the highway at 120+ with 15/44 gearing so revs getting up there ,then turned around and did same again next day!!
04 950 adv s
08 dr 650 (sold)
Old 03-22-2010, 02:49 AM   #6801
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
That'd be around 5,400rpm.
Old 03-22-2010, 03:04 AM   #6802
ozbikedude
so little time
ozbikedude's Avatar
Oddometer: 2,050
yep around 5000-5500,is that upper limit,what is upper limit???
04 950 adv s
08 dr 650 (sold)
Old 03-22-2010, 03:05 AM   #6803
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Around 7,600rpm.
Old 03-22-2010, 03:11 AM   #6804
ozbikedude
so little time
ozbikedude's Avatar
Oddometer: 2,050
Around 7,600rpm.
how often would you recomend checking valve clearance?
04 950 adv s
08 dr 650 (sold)
Old 03-22-2010, 03:55 AM   #6805
greendude
greendude's Avatar
Oddometer: 1,134
check its not just air filter oil,it will sometimes pool up in the bottom from a heavily oiled filter .filter oil feels stickier then motor oil. get that on mine sometimes
greendude is offline   Reply With Quote
Old 03-22-2010, 04:02 AM   #6806
cmg
wannabe dirt rider
cmg's Avatar
Oddometer: 292
well, how often and long are planning on holding it around 5500 - 7600 rpm?
I used to ride.....
, 10
Old 03-22-2010, 04:05 AM   #6807
woopwoop
will think for food
woopwoop's Avatar
Oddometer: 5,509
Happens to me every time I do the filter myself. I never seem to get as much out as the bike shop does.
With previous bikes, I always had two filters and left one to "drain" on old towel in a plastic bucket for a few weeks. Must be a way to do it with just one element?
YOG1C
woopwoop is offline   Reply With Quote
Old 03-22-2010, 04:11 AM   #6808
ozbikedude
so little time
ozbikedude's Avatar
Oddometer: 2,050
its definetly engine oil,does amount of revs the bike does effect valve clearance???
04 950 adv s
08 dr 650 (sold)
Old 03-22-2010, 04:12 AM   #6809
greendude
greendude's Avatar
Oddometer: 1,134
better too much then not enough
Old 03-22-2010, 04:22 AM   #6810
greendude
greendude's Avatar
Oddometer: 1,134
any RPM the DR will do is not considered high RPM for a bike. IMO running flat out all day wouldnt change valve service intervals much but it would increase the amount of air/oil out the breather hose
Times are GMT -7.   It's 10:03 AM.
