Old 04-02-2012, 01:59 AM   #11671
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Originally Posted by The Cougar View Post
All from one press of the kill switch.
They called it the "kill switch" for a reason.
NordieBoy is offline   Reply With Quote
Old 04-02-2012, 02:12 AM   #11672
Sleepy John
Grumpy Adventurer
Sleepy John's Avatar
Oddometer: 3,730
Could it be the side stand switch (it is still connected).
I don't think so.
Check the straps off the battery.
Are you sure this isn't a BMW?
Sleepy John
'10 R1200GSA Big Pig, '10 DR650SE Piglet
Don't shoot... It's only me!
Women and cats will do as they please, and men and dogs should relax and get used to the idea.
Sleepy John is offline   Reply With Quote
Old 04-02-2012, 02:14 AM   #11673
The Cougar
Barry Dawson's Twin
The Cougar's Avatar
Oddometer: 457
Originally Posted by Sleepy John View Post
I don't think so.
Very sure. At least the BMW will be getting me to work tomorrow Sleepy!
The Cougar is offline   Reply With Quote
Old 04-02-2012, 04:57 AM   #11674
arunta dreama
arunta dreama's Avatar
Oddometer: 243
cush drive
has anyone got a or know where i can get a second hand cush drive sprocket holder assembly
the bearing collapsed and i didnt notice untill the sprocket started chewing on the swing arm
this is my first dr650 ... went chasing info on dr cush drives it appears to be a common problem
how often do i replace the cush bearing ... every tyre change?
anything else i should be doing its got 12000km on clock
thanks
Dreama
arunta dreama is offline   Reply With Quote
Old 04-02-2012, 05:08 AM   #11675
outback jack
outback jack's Avatar
Oddometer: 6,915
thanks
Dreama
Mine just hit 14,000 and the chain is cactus, but the cush is okay. i would say the amount of water you have been riding through lately has added to your woes. I'm going to replace all my running gear, cush rubbers and bearings this time round.
There's something ugly about a NEW bike on a trailer.
CCC ride Cattle, Coal & Cane or Captains Crossing & Castlemaine.
http://www.advrider.com/forums/showt...1#post17025601
outback jack is offline   Reply With Quote
Old 04-02-2012, 05:11 AM   #11676
NoHillsNoTrees
mostly upright
NoHillsNoTrees's Avatar
Oddometer: 180
Changed cush drive bearing and both hub bearings in the back end along with replacing rear break pads and chain. All at 10000k's. All bar one bearing completely f#*ked. The only "substantial" repairs I've had to make. 10000k's of dust, mud, water and shit (I'm a contract musterer by trade) I think its bloody fantastic that this is all that i've had to do. DRs bloody rule!
Some fear....If there is no fear, you aren't goin' hard enough!
Alcohol....because no great story ever started someone eating a salad!
"...tried all day to blow up my DR650 so I can gracefully quit this psycho circus, but the little fucker just won't die!..." - Frenchy750 (APC Rally 2012)
NoHillsNoTrees is offline   Reply With Quote
Old 04-02-2012, 01:51 PM   #11677
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,654
thanks
Dreama
Still on my original cush rubbers at 40k. Third set of bearings including Sprocket carrier bearing. That has only been preventative because of water crossing etc but the cush drive rubbers seem to have a good life if adjustments are kept correct and you are not too hard on gear changes etc, Will probably replace rubbers soonish.
I would be looking at other things like swingarm linkage bearings depending on your use.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is online now   Reply With Quote
Old 04-02-2012, 10:50 PM   #11678
dobbo
dobbo's Avatar
Oddometer: 1,007
Cush Drive
Just replaced my wheel bearings, both front and rear .. at 35000km.
Front bearings looked pretty good, however, the rear bearings were knackered.. especially the cush drive bearing.
The cush bearing basically fell apart once removed, so I guess I was lucky that it never sh*t itself while I was riding.
while I had the wheel apart, I soaked the cush rubbers in Mineral turps for around 5 hours ( I have heard that soaking them in oil will allow them to swell and prolong their life), and refitted the cush rubbers along with new bearings; can't be 100% on whether the cush rubbers did swell.... but I no longer have any play in my rear sprocket. and the cush drive seems nice and tight.
dobbo is offline   Reply With Quote
Old 04-03-2012, 01:07 AM   #11679
fayeslane
Rankest of amateurs
fayeslane's Avatar
Oddometer: 1,836
I dream of a tight cush
fayeslane
Faster than a speeding pullet
2002 Yamaha TDM900
various BMW airheads
fayeslane is offline   Reply With Quote
Old 04-03-2012, 01:45 AM   #11680
Thumper Dan
Oddometer: 328
Hmm............tight cush!
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 04-03-2012, 02:52 AM   #11681
Dusty Rhodes
Yowie Chaser
Dusty Rhodes's Avatar
Oddometer: 1,558
thanks
Dreama
G'day Dreama, when ever I have a wheel off for tyres/chains etc I just stick my finger in the bearings and give it a twirl. If there is any hint of grindyness it's time for replacement.
Also if there is any sideways movement in the wheels while they are in the bike it usually means bearing time.
Hmmmmm maybe I should go and check mine now
Cheers.
I wondered why the frisbee was getting bigger , and then it hit me.
Dusty Rhodes is offline   Reply With Quote
Old 04-03-2012, 03:48 AM   #11682
arunta dreama
Oddometer: 243
bearings
cheers for the info lads
i pick up a second hand sprocket carrier $80 orderd all new bearings
lesson learnt.....
thanx again
dreama
Old 04-05-2012, 04:20 PM   #11683
NoHillsNoTrees
mostly upright
Oddometer: 180
Oil question
After an in depth discussion over a few frothies with BIL, I have turned now to the font of all knowledge! Can you use a general motor oil (Magnatec etc.) as opposed to a specific 4 stroke bike oil in your basic service?
Old 04-05-2012, 04:43 PM   #11684
Crofty
Life's a Garden, DIG IT!
Crofty's Avatar
Oddometer: 611
No.
You will have a nice slippery clutch if you do.
There is a diesel oil that it is possible to use but i can't remember which one.
For the service intervals of the DR, oil is relatively cheap by comparison to my enduro bikes using Belray semi-synthetic at $55 for 4 litres every 500km or less.
1977 BMW R100S
2010 TM 450 FES
2008 DR 650
1995 WR 250Z
Crofty is offline   Reply With Quote
Old 04-05-2012, 05:07 PM   #11685
BergDonk
BergDonk's Avatar
Oddometer: 3,788
I have used Caltex Delo 400 for years in my dirt bike fleet with no oil related problems and in fact it addressed a bearing problem I had with my old Berg using Mobil 1 R4T.
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is online now   Reply With Quote
Times are GMT -7.   It's 11:44 PM.
