Old 05-29-2012, 05:03 PM   #11986
Crofty
Life's a Garden, DIG IT!
Crofty's Avatar
Oddometer: 611
So is 16.7 km/l bad with a TM40?
It's the same as i was getting out of the stock carby.
Might need the leaner Main jet
1977 BMW R100S
2010 TM 450 FES
2008 DR 650
1995 WR 250Z
Crofty is offline   Reply With Quote
Old 05-29-2012, 09:20 PM   #11987
outback jack
outback jack's Avatar
Oddometer: 6,915
Depends where your riding, As a comparrison coming home from Springsure doing 120 on a DR speedo that probably is only 110, i averaged 19.28. i used exactly the same amount as the DRZ 400 i was travelling with, in the slower stuff he was fractionally better. So that's with a stock carb, so since i did my carby mods my fuel range is a fair bit better and it runs great.
There's something ugly about a NEW bike on a trailer.
CCC ride Cattle, Coal & Cane or Captains Crossing & Castlemaine.
http://www.advrider.com/forums/showt...1#post17025601
outback jack is offline   Reply With Quote
Old 05-29-2012, 11:14 PM   #11988
greendude
greendude's Avatar
Oddometer: 1,134
try leaning off the pilot jet as that effects cruising economy more then the mainjet
remember with the TM40 a higher number pilot is leaner
ie. a 17.5 is richer then a 22.5
greendude is offline   Reply With Quote
Old 05-30-2012, 12:12 AM   #11989
Crofty
Crofty's Avatar
Oddometer: 611
Ahh, righto, thanks for that.
That fuel economy was made with a hell of a lot more fun than with a stock carby though
1977 BMW R100S
2010 TM 450 FES
2008 DR 650
1995 WR 250Z
Old 05-30-2012, 12:24 AM   #11990
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,384
I got from 11 to 20 km/l on the open road.
15 km/l was about the worst with the BST40.
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 05-30-2012, 12:46 AM   #11991
greendude
greendude's Avatar
Oddometer: 1,134
the pilot and needle effect the less half throttle stuff
the mainjet controls the fun stuff.
dont miss out on the fun stuff and the TM40 contains way more fun stuff
Old 05-30-2012, 01:58 AM   #11992
grrant1058
Motorcyclist 24/7
grrant1058's Avatar
Oddometer: 334
1/ Acerbis tank fits my new DR fine with a 39mm FCR fitted, no clearance issues at all.
2/ With all the carb mods performed on the stock BST and then with a Dynojet kit fitted, there was still no comparison to the overall performance gain right thru the rev range with the FCR - PLUS fuel economy is better!
3/ Old Chinese saying...."hah, you cannot make silk purse from pigs scrotum"
grrant1058 is offline   Reply With Quote
Old 05-30-2012, 02:25 AM   #11993
DRjoe
DRjoe's Avatar
Oddometer: 5,151
Fcr's are cheap too, i just picked up a 40mm gen 3 for $250 and i bought a 39 gen 3 for less than $200 a few months back
most people would be able to knock up a addapter ring out of a peice of pipe with some hand tools and mugiverissem
the old gen 1 slant body 39mm fcr's of the ktm's are a nice fit for the dr without having to change much, there smaller than the newer fcr's so there easier to fit and work on.
They have a plastic bolt on bell mouth that is just slightly too big for the dr's air filter boot (it can be easily shaved down with a knife), the other end is the perfect size and there already the perfect length.
you'll need to swap your cables or alter the originals.
If you do decide to buy an early fcr make sure its not leaking fuel from where the two halves of teh carb bolt together.
The americans have issues with the gasket/O ring disintergrating, it doesnt seem to be such a problem overe here so maybe they have more ethanol in there fuel.
The gasket that leaks is not available to buy as far as I know.
DRjoe is online now   Reply With Quote
Old 05-30-2012, 02:48 AM   #11994
rod1
Old Australian Bull
rod1's Avatar
Oddometer: 90
DR 659 Throttle Tube 2007
Fitting Heated Grips to my sons 2007 DR 650. Got the left side off no problems. Throttle tube presented a different situation! Attempted everything possible before finally dismanteling tube and trying to cut the old grip off. AAhh..I knoe, I'll order a new Throttle Tube. New tube arrived in 24 hours..but..it has a bloody grip firmly attached. So, my questions, 1) Can I purchase from some source a Throttle tube to suit the 2007 DR650 without a bloody grip attached?, 2) If a gripless Throttle Tube is unobtainable and I perservere with my scraping/cleaning of the old Throttle Tube, do I have to grind off the small lip on the external end of the Tube, in order to fit Heater Pad and New Grip? Any suggestions greatly appreciated. Thanks.Rod
rod1 is offline   Reply With Quote
Old 05-30-2012, 03:42 AM   #11995
rutsthematter
rutsthematter's Avatar
Oddometer: 163
Originally Posted by rod1 View Post
Throttle tube to suit the 2007 DR650 without a bloody grip attachedThanks.Rod
Theres a motion pro one on flea bay.
http://www.ebay.com.au/itm/Suzuki-DR...item5d33bf4809
rutsthematter is offline   Reply With Quote
Old 05-30-2012, 03:54 AM   #11996
rod1
Old Australian Bull
rod1's Avatar
Oddometer: 90
Throttle Grip
Thanks Ruts...Ordered immediately. Be nice if its as quick as the FMF exhaust I purchased last week. Arrived today. 6 days since ordering. Really impressive. Rod
Old 05-30-2012, 04:24 AM   #11997
NoHillsNoTrees
mostly upright
NoHillsNoTrees's Avatar
Oddometer: 180
Where did you get the FMF from Rod? looking for one myself in the next week or two.
Cheers, Pete.
Some fear....If there is no fear, you aren't goin' hard enough!
Alcohol....because no great story ever started someone eating a salad!
"...tried all day to blow up my DR650 so I can gracefully quit this psycho circus, but the little fucker just won't die!..." - Frenchy750 (APC Rally 2012)
NoHillsNoTrees is offline   Reply With Quote
Old 05-30-2012, 04:27 AM   #11998
ADV8
ADV8's Avatar
Oddometer: 2,384
If a gripless Throttle Tube is unobtainable and I perservere with my scraping/cleaning of the old Throttle Tube...
The stock DR grip after cutting as much off as you can will come up nicely with a wire buff,be careful of course.
Old 05-30-2012, 08:24 AM   #11999
motolab
motolab's Avatar
Oddometer: 2,737
A TM40 uses a VM28/486 series pilot jet. Sizing on a VM28/486 pilot jet is larger number equals richer. In fact I don't know of any Mikuni pilot jet where the sizing is larger number equals leaner. The only time this is the case is with regard to air bleed jets. The TM40 does have a BS30/97 series pilot air bleed jet, but this should not be the primary means of adjustment, as it controls the slope of the delivery (whereas the plot jet moves the entire curve up and down without changing slope).
Regards,
Derek
motolab is online now   Reply With Quote
Old 05-30-2012, 08:35 AM   #12000
motolab
motolab's Avatar
Oddometer: 2,737
The needle does affect all ranges, but because it can be difficult to manufacture enough needle shapes so that there is one for all applications that works well at all openings (case in point, the FCR), the pilot jet overrides 1/16 and 1/8 openings, and the needle jet overrides 1/4 opening. Effectively this means that you only need to be concerned with needle shape for 1/2 and 3/4 openings.
Regards,
Derek
Times are GMT -7.   It's 10:32 PM.
