Old 07-13-2012, 07:50 PM   #12226
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
Originally Posted by DR Steve View Post
So that is an E07 in 140 width ?
It also looks to be a bit of a rounder fit than some of the 130 E07's I've seen which appear to be a very flat tyre.
If so I think that my next tyre to try - I think the wear bar will make the 130 useless for most of my riding as soon as it wears that far.
It would appear to still have plenty of tred depth beyond the center wear bar ?
It's not a wear bar.
The wear indicators are much closer to the carcass than the centre strip.
Once you hit the centre strip, there's about 2-3,000km left in the tyre.
NordieBoy is offline   Reply With Quote
Old 07-13-2012, 07:54 PM   #12227
BergDonk
BergDonk's Avatar
Oddometer: 3,596
These sorts of things are designed to stiffen up the knobs, reduce flex and heat and improve mileage as a result.
The one I have on at the moment is nearly down to the bar, so after thinking about it a few times, I've ordered a knobby knife and will remove the bar for more effective drive for a few more kms. Its a bit slippery around here in places at the moment.
http://www.knobbyknifedownunder.com/index.html
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 07-13-2012, 08:40 PM   #12228
robmoto
robmoto's Avatar
Oddometer: 3,854
The tyre on the blue bike mine is a E07 / 130 I run these untill about 1mm of tread left to the centre bar then chuck em, so Berg,s idea of grooving the centre sounds good to me.
The E07 is now to soft and doen,t last like the old ones used too, probably 1500k,s less me thinks but a real good all round use tyre value for money.
when they are down to the centre bar straight line drive is a bit useless but does add to the fun factor of things or one could let an extra 6lbs of air out of it helps , I think Nordie mentioned this allso a while back.
I am running a 140 E07 on one of my BIGS and it has no centre bar which I prefer because they are a softer compound like the new E07,s AND DON,T crack next to the edge of the centre bar like the old version hard ones.
The 140 I have never tried on the 650 and may not fit where it gets close to the swing arm on the right hand side at the front, going 140 allso I think may start to push the front out because of to much grip.
robmoto is offline   Reply With Quote
Old 07-13-2012, 08:55 PM   #12229
DR Steve
DR Steve's Avatar
Oddometer: 325
Thanks for the reply rob,
So the tyre pictured has the center tread bar, it's just not really visible in the picture ?
You mention the "old" and "new" E07 - how do you tell the difference and does it even matter ?
I assume the new softer one is a little better on wet roads.
'13 DR650
DR Steve is offline   Reply With Quote
Old 07-13-2012, 09:40 PM   #12230
robmoto
robmoto's Avatar
Oddometer: 3,854
Steve, it has a centre bar its just a bit hard to see, both the old and new softer compound E07,s have the centre bar.
Be very cautious in the wet with them on tar, wet hot mix they are not bad. I run 30psi loaded on the tar though.
Keep away from the front E07,s for the dirt if you like going quick .
Old 07-13-2012, 11:35 PM   #12231
Eddieb
Eddieb's Avatar
Oddometer: 988
I'm running a 140 E-09 on one of my 650's and there's room to spare, not sure if there is any shape difference to an E-07 though that might make an E-07 different.
'05 DR650 - '06 Wee Strom - '86 BMW R80 with Velorex sidecar - '67 Ducati 250 Mark 3 Narrow Case
www.AdventureRidingNZ.co.nz Free GPS tracks for New Zealand, over 60 Owners and workshop manual downloads, ADV bike specs chart & more
Eddieb is offline   Reply With Quote
Old 07-14-2012, 03:12 AM   #12232
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
Anyone know what's up with TBAM?
No sight of the June one yet.
The website is also down.
The publishers link to subscribe to the mag says "magazine not found".
Nooooooo!
h::calm:
DR650 Wiki
Old 07-14-2012, 03:14 AM   #12233
racca
racca's Avatar
Oddometer: 331
Nooooooo!
h::calm:
TBAM is no more buddy, all went down the gurgler a couple months ago. RIP. Sorry to be the bearer of bad news.
racca is offline   Reply With Quote
Old 07-14-2012, 03:27 AM   #12234
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,138
Nooooo!
First Woose, then TBAM.
DR650 Wiki
Old 07-14-2012, 03:35 AM   #12235
Spart
DR Crash Brother
Oddometer: 55
Morrison Media sent out subscription refunds at the end of June for existing subscribers.
Spart is offline   Reply With Quote
Old 07-14-2012, 03:57 AM   #12236
Hardhead
Hardhead's Avatar
Oddometer: 2,427
Tbam
There was a whole thread about its demise.
You think hiring a professional is expensive, wait until you hire an Amateur!
Hardhead is offline   Reply With Quote
Old 07-14-2012, 01:35 PM   #12237
Crofty
Life's a Garden, DIG IT!
Crofty's Avatar
Oddometer: 608
18" SM Pro rim
Anyone had a drama with lacing a new 18" SM pro rim? one side it appears the holes have been drilled on the wrong angle. When laced up the spokes have a bend in them? while the other side is spot on.
Bit hard to explain, but the angle of the rim holes doesn't match the angle on the hub, sproket side from memory. So when looking at the wheel side on, the spokes have a slight arc in them.
The bike tech rang the importer and they were not much help. He will have to redrill the holes.
Is he missing something?
1977 BMW R100S
2010 TM 450 FES
2008 DR 650
1995 WR 250Z
Crofty is offline   Reply With Quote
Old 07-14-2012, 02:27 PM   #12238
outback jack
outback jack's Avatar
Oddometer: 6,915
That doesn't sound right, but i wouldn't go redrilling anything, maybe the bloke is lacing it wrong. Also SM pro can be dicks to deal with, years ago they're rims didn't have enough grip marks in the alloy lip and even double rim locks wouldn,t hold a tyre. Only due to our bike shop who was sponsoring my kid, being persistant about the issue, SM pro finally relented and took the rim back and had it re grooved, which fixed the problem. Personally i stick with Excel rims now, they seem to be no trouble and have always had decent grooving to hold the tyre.
There's something ugly about a NEW bike on a trailer.
CCC ride Cattle, Coal & Cane or Captains Crossing & Castlemaine.
http://www.advrider.com/forums/showt...1#post17025601
outback jack is offline   Reply With Quote
Old 07-14-2012, 02:54 PM   #12239
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,231
Sounds like that sm pro rim was made for a motocrosser or enduro with no cush drive hub.
The cush drive side of the DR wheel is a larger diameter than the disc side and therefore a different angle necessitating a different spoke angle in the rim.
The rim can successfully be drilled but you will end up with 18 elongated spoke holes or you could also just put up with slightly bent spokes.
If you ordered a rim specifically for the DR, check that the wheel lacer hasn't put it on the wrong way round (although all 36 spokes would be showing as slightly bent if that were the case I would think)
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 07-14-2012, 03:22 PM   #12240
Crofty
Crofty's Avatar
Oddometer: 608
I would hate to think how many wheels he has laced, so i kow this is ok.
John Titman is the importer and apparently where not overly helpfull.
1977 BMW R100S
2010 TM 450 FES
2008 DR 650
1995 WR 250Z
Times are GMT -7.   It's 11:49 PM.
