Old 07-14-2012, 04:24 PM   #12241
Crofty
Life's a Garden, DIG IT!
Crofty's Avatar
Oddometer: 604
Originally Posted by Big Willy View Post
If you ordered a rim specifically for the DR, check that the wheel lacer hasn't put it on the wrong way round (although all 36 spokes would be showing as slightly bent if that were the case I would think)
Yep this would be the case, but one side is spot on.
1977 BMW R100S
2010 TM 450 FES
2008 DR 650
1995 WR 250Z
Crofty is offline   Reply With Quote
Old 07-14-2012, 04:41 PM   #12242
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,219
If it were me, I'd unlace it and check the spoke angles in the rim. If they are all the same, therein lies your problem.
A battery drill with a flat screwdriver blade makes for quick work after an initial loosening with spoke spanner.
A vewwy good fwiend in Wome
Big Willy is offline   Reply With Quote
Old 07-14-2012, 05:07 PM   #12243
Crofty
Crofty's Avatar
Oddometer: 604
Only problem, wheel is in Launceston and i'm at work in Cobar, doh.
I'm sure he will work it out and get another rim sent if he needs to tomorrow.
1977 BMW R100S
2010 TM 450 FES
2008 DR 650
1995 WR 250Z
Old 07-19-2012, 04:25 AM   #12244
speedwobble2
Oddometer: 98
07 DR smokes on start up
A mates 07 DR650 smokes badly on start up when cold. Fine when hot. Has not done a lot of K's. It does not use oil between changes and has just replaced the valve guide seals to see if that was the problem, it wasn't. Anyone got any ideas or suggestions?
speedwobble2 is offline   Reply With Quote
Old 07-19-2012, 04:46 AM   #12245
outback jack
outback jack's Avatar
Oddometer: 6,856
What colour smoke?
blue = oil
black = fuel
white = coolant
There's something ugly about a NEW bike on a trailer.
CCC ride Cattle, Coal & Cane or Captains Crossing & Castlemaine.
http://www.advrider.com/forums/showt...1#post17025601
outback jack is offline   Reply With Quote
Old 07-19-2012, 04:50 AM   #12246
DRjoe
DRjoe's Avatar
Oddometer: 5,096
Originally Posted by outback jack View Post
What colour smoke?
blue = oil
black = fuel
white = coolant
Old 07-19-2012, 04:52 AM   #12247
DRjoe
DRjoe's Avatar
Oddometer: 5,096
tell him to put slightly less oil in it and see if that stops it.
They dont respond well to being over full especialy the higher k ones.
Old 07-19-2012, 04:55 AM   #12248
podge NT
Podge NT
podge NT's Avatar
Oddometer: 2,280
Originally Posted by DRjoe View Post
Coolant = peeing on it
http://share.findmespot.com/shared/f...1IWs2Hg87TZcsW
Plan, what plan, there is no plan
podge NT is offline   Reply With Quote
Old 07-19-2012, 04:55 AM   #12249
outback jack
Oddometer: 6,856
A check of the air box would be a good indicator, mine could top up a KLR that's why i overfill it.
Old 07-19-2012, 04:19 PM   #12250
speedwobble2
Oddometer: 98
What colour smoke?
blue = oil
black = fuel
white = coolant
HI Pete
It's oil smoke and airbox is clean
He's having real trouble finding the coolant smoke Maybe some of the Guru's on here may give him some pointers
I have had 5 DR's over the years and a couple of them high milers and have never seen this before.
Old 07-19-2012, 05:18 PM   #12251
outback jack
Oddometer: 6,856
HI Pete
Max, the only thing that would be logical other than valves, would have to be rings, or a very small leak in the head gasket, or a kink in the crank case vent hose, but if it's using no oil well it's got me stumped Oh yeah leaving for the Cape in 2 weeks, twist your arm?
Old 07-19-2012, 05:47 PM   #12252
Thumper Dan
Oddometer: 325
K60 scout 150/70 x 17
anybody try these? I have currently T63 on the rear but seems to be wearing out reasonably fast now; probably due to too much bitumen riding.
https://www.adventuremoto.com.au/pro...oducts_id=1060
They're expensive tyres but if they last a lot longer, than maybe worth it?? The 140 is $214 compared to the $275 for the 150 (out of stock for six weeks or so). Does anybody recommend them?
Are there any other cheaper sites for tyres??
thanks heaps.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan screwed with this post 07-19-2012 at 06:41 PM
Thumper Dan is offline   Reply With Quote
Old 07-19-2012, 06:52 PM   #12253
fayeslane
Rankest of amateurs
fayeslane's Avatar
Oddometer: 1,741
Fine on road, OK on dry off road, useless in wet off road. Longevity -lasted until after my first wet off road ride then I took them off when I stopped shaking
Google Pablos in Melbourne. Good prices and service, freight all over.
fayeslane
Faster than a speeding pullet
2002 Yamaha TDM900
various BMW airheads
fayeslane is offline   Reply With Quote
Old 07-20-2012, 01:00 AM   #12254
Thumper Dan
Oddometer: 325
Starter motor and warranty
I posted about this previously and how Suzuki would pay for the noisy choked chicken noise that is coming form the starter motor.
Just went and picked it up and low and behold..............it still does it The dealer said "well they all do it and its now been officially noted, so if something happens up the track, Suzuki will take care of it! Huh? Apparently they replaced the clutch mechanism in it which obviously isn't it. I thought it was the lack of grease that was in there. Anyway, I'll see how it goes
On another note, there was a 2011 DR650................the owner got ran off the road and now his frame is bent and a total write off. I can see that baby being parted out (if you're the owner and readng this..........condolences).
Old 07-20-2012, 01:21 AM   #12255
woopwoop
will think for food
woopwoop's Avatar
Oddometer: 5,354
thanks heaps.
The standard tyre size for a DR is a 120/90.
A 130/80 or a 130/90 will of course easily fit and is what most people use.
You occasionally hear of someone squeezing a 140 on there, but I don't know why.
I'd be very doubtful about a 150...I'm pretty sure it's designed for a much wider rim as fitted to bigger bikes.
Do a google search for a recommended tyre size to rim width chart...I've seen a Michelin one for example.
Those T63s might wear out quicker but they are a LOT cheaper than the prices you've mentioned....I just got a front and rear fitted (same sizes as a DR) for $215.00.
woopwoop is online now   Reply With Quote
Times are GMT -7.   It's 04:05 AM.
