Old 09-14-2012, 02:36 AM   #12481
eRRmmm
Oddometer: 576
Originally Posted by rosiethestarfish View Post
Just signing in. I live in Broken Hill NSW and recently bought a stock 09 dr 650, 14k on the clock for $3200. I thought it was a pretty good price. Have had to spend another 800 so far due to the stator stuffinf up and a few other minor things. I still think i got a good priced bike (??). I am currently having issues with the stupid countershaft seal (has popped out three times). I'm hoping Ill have the problem rectified very soon and then be good to go. I plan on buying a bigger tank, seat upgrade windshield and adding some storage capacity and then good too go.
Bergdonk has worked out a fix for this problem on his bike, search for his posts using something like this in google
bergdonk countershaft seal site:advrider.com
That is a good price on the DR, well done. If you're looking for a ride down Mildura way let me know, I need to get out more... (must get to Cameron's corner this year).
eRRmmm is offline   Reply With Quote
Old 09-14-2012, 04:00 AM   #12482
rosiethestarfish
Oddometer: 10
Yeah I want to get up to camerons corner this year also. Sounds like a plan somewhere along the way.
rosiethestarfish is offline   Reply With Quote
Old 09-15-2012, 04:32 PM   #12483
Benz-in-Oz
Benz-in-Oz's Avatar
Oddometer: 187
Bearing Noise
I have some bearing noise in my DR, that quietens when the clutch is disengaged, also it has started grinding badly going into gear when hot, it's normal when cold. Does anyone have a clue which bearing is stuffing out here. By the way it's an 08 model 16500kms.
Benz-in-Oz is offline   Reply With Quote
Old 09-15-2012, 07:18 PM   #12484
ninja97
Oddometer: 117
Just a guess and i hope i am wrong but it could be the input shaft bearing, the one behind the clutch, i had a similar problem with mine and it was a complete strip down of the engine. Only real way to check is to take the cover off and see if there is movement in the shaft. Have to admit mine had done 100,000klm,s at the time.
ninja97 is offline   Reply With Quote
Old 09-15-2012, 09:48 PM   #12485
Benz-in-Oz
Benz-in-Oz's Avatar
Oddometer: 187
Yeah that's what I'm afraid of.
Old 09-15-2012, 11:43 PM   #12486
Born-to-ride
GSXR!!!
Born-to-ride's Avatar
Oddometer: 100
Took the DR out today for the first time with the FCR carb on. It added heaps of grunt through the range. Idles a bit high. Still need to figure that part out. Excellent mod!!!
Born-to-ride is offline   Reply With Quote
Old 09-17-2012, 01:25 AM   #12487
RAR
Oddometer: 110
Will heavier weight fork oil affect COMPRESSION damping or REBOUND damping or BOTH ? ? ?
RAR is offline   Reply With Quote
Old 09-17-2012, 01:30 AM   #12488
RAR
Oddometer: 110
Also, I`m considering angle grinding the lip inside the rear rim ( the lip that keeps the flat tyre on the bead ) for quicker and easier tyre changing. Will this weaken the rim ? Has anyone done this ?
Old 09-17-2012, 03:41 AM   #12489
usi
SNAFU
usi's Avatar
Oddometer: 53
I'm looking for options to delete my ignition key switch for something smaller as it interferes with my headlight setup
Ideally it would be half the size and suited for off road conditions, i wouldn't mind still having a key of some description,
Mind you if you have seen some trick sealed on off options i am open for ideas
Throw some makes and models if you can think of anything i should look into
usi is offline   Reply With Quote
Old 09-17-2012, 04:43 AM   #12490
great southern land
Apprentice
Oddometer: 29
fcr
i have not long done the same mod think its not to bad better torque through the range
great southern land is offline   Reply With Quote
Old 09-17-2012, 04:53 AM   #12491
DRjoe
DRjoe's Avatar
Oddometer: 5,092
Both
Old 09-17-2012, 04:55 AM   #12492
DRjoe
DRjoe's Avatar
Oddometer: 5,092
Doubt it and yes to three without issue, if your running low pressure fit a rim lock.
Old 09-17-2012, 05:03 AM   #12493
Hardhead
Hardhead's Avatar
Oddometer: 2,427
I'm pretty sure Rumble did that to his DR and swears by it.
You think hiring a professional is expensive, wait until you hire an Amateur!
Hardhead is offline   Reply With Quote
Old 09-17-2012, 06:39 AM   #12494
greendude
greendude's Avatar
Oddometer: 1,132
if you fit racetech emulators you can adjust compression damping on the emulators and rebound damping through your oil weight
greendude is offline   Reply With Quote
Old 09-17-2012, 02:35 PM   #12495
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,216
I put a button off a WR450 on mine (they come in the spares kit so should be plenty floating around)
You will need to put a resistor in the circuit or you wont be able to start the bike. I can't remember the ohmage right now but a google should uncover it.
If you put the resistor in some sort of connector, you can then pull the resistor out effectively making it your key.
A vewwy good fwiend in Wome
Big Willy is offline   Reply With Quote
Times are GMT -7.   It's 11:44 PM.
