Old 11-11-2012, 05:13 AM   #12691
LukasM
Oddometer: 5,425
Well here are some pics so you lot can compare that with a standard head to see if it would even fit. Since every part except the head is the same, I would assume so. Same oil lines, cases, cam, cylinder, piston, gearbox, timing chain,.....
Old 11-11-2012, 06:20 AM   #12692
DocSuzuki
Suzuki Fool.
DocSuzuki's Avatar
Oddometer: 76
Originally Posted by DRjoe View Post
do you realy reckon you got any more go out of your bike by polishing your ports?
I dont think i've heard of any tuner that will polish an intake port because of the boundry layer caused.
Joe, I know.
It helps when you have access to another DR (2003 model- 11 thousand k`s).
Before I fixed the base gasket on mine ( and new rings, which was unneeded but copped em anyway ) the `03 had slightly more arse dyno torque than mine. Same gear, same steep hill.
Now, mine will eat the 03 DR everywhere ( and i`m running taller than stock gearing for top gear revs reduction ). Have proper dynosheets for both bikes to back it up.
There`s no way on this earth a new set of rings will do it.
There`s no way a Staintune will do it. (Which both bikes have anyway)
Of course just polishing ports by themselves won`t make a dragster. Neither will an open chamber exhaust being fed by a choked off airbox. Any mods need to be done as a set to really benefit. The port job creates an `edge` over the engine with just jets, pipe and good rings because it`s breathing a little better (read- faster).
You don`t have to believe me, but polishing does help. There`s a bit more info about it on my build thread, which no one seems to write in.... yes, i`m an attention whore!
BTW...WTF is a boundary layer?
I also am that nub MCRatworks. After 2 years, figured out how to get this account`s password back. Yes, i am indeed, an idiot.
Sniffing CCI arsecrack since 1997
DocSuzuki screwed with this post 11-11-2012 at 06:33 AM Reason: putting in shameless plug for build thread......>.>
DocSuzuki is offline   Reply With Quote
Old 11-11-2012, 06:53 AM   #12693
DRjoe
DRjoe's Avatar
Oddometer: 5,150
My terminology might be wrong and it might be called something else but a good example of what I mean can be seen when rain and a smooth surface meet at speed.
Next time your driving or riding along in the rain have a look at what the water is doing on the smooth surfaces like your visor, windscreen or bonnet.
The smooth surface creates a layer of air that is slow moving so you'll see that the water is barely creeping along the surface.
Now apparently this is what happens in a polished port, The slow moving air lets the atomised fuel condensate on to the port surface where it then starts to trickle down into the cylinder and because its not atomised it won't burn as well and most of it will end up coming out your exhaust.
A slightly roughened surface stops this happening.
Hopefully some one that knows about it and why it happens will come along and explain it better.
Maybe you've just proved a lot of people wrong or maybe the set of rings you pulled out had never seated properly from new and leaked more than you thought.
Old 11-11-2012, 07:48 AM   #12694
DocSuzuki
Suzuki Fool.
DocSuzuki's Avatar
Oddometer: 76
That is a good and quite valid point.
One that I myself was wondering about when I was doing this. To a certain degree I think this actually does happen, as I have noticed a slight smear of liquid fuel after running the engine and then pulling off the carb and checking the port. (Don`t know if this always occurs regardless)
On the other hand, there is also a valve at the end of it`s journey which is not polished, and also forces a change of direction which is bound to combine to help reatomise it, by which time it`s already in the chamber. I`m sure that phenomenon only occurs on the ports surface. The rest of the port is full of high velocity mix, because the surface is not creating a gutload of turbulence slowing the entire flow down. That is the whole ideal behind polishing, it reduces turbulence increasing velocity. A downside of this would be what you are describing.
In any case, if you check the XR650 thread, I have pics of the inlet ports in question. There is still seams which I didn`t flatten because of time constraints. I could possibly be wasting a bit of fuel, but when you`ve never EVER bothered checking the price on the pump before filling, who gives a shit? (I`m not running a waste of space Landcruiser or V8 Commode) What I do know is I have more grunt than before, and the old rings were sealing, as there wasn`t black shit on the sides of the piston. The piston was quite clean apart from the obvious on the crown.
I`m not an expert hot rodder, just someone who picks up things from people who have done this before, but at the same time keeping an open mind.
Old 11-11-2012, 09:52 AM   #12695
ER70S-2
ER70S-2's Avatar
Oddometer: 6,724
Originally Posted by DocSuzuki View Post
1.......
And YES! I have worked out multiquote.....time for another beer!
2.....
Originally Posted by LukasM View Post
3.....
fwiw: Three is the limit on multi-quotes. If you want more you can open another ADVrider window, multi-quote three more, copy and paste those into the first window: Six guotes, etc, etc, etc.
There's snow on the ground and it's 28* F.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 11-13-2012, 12:11 AM   #12696
Tyrepower
Tyrepower's Avatar
Oddometer: 148
That's why golf balls have dimples!! The dimples trap a layer of air which then has less resistance than if it was smooth and causing the air to "stick". Try it! get some wet and dry sand paper, sand out most of the dimples and give it a hit. Won't go anywhere near as far. Not that it matters to me. I could hit a Baseball and still only make it to the lady's Tee. And then it would be a slice!!! But that's why I ride bikes, and not waste a good walk by trying to play>
My biggest fear is when I die, my wife will sell all my bikes for what I "told her" they cost!!!
It's all good fun until someone gets hurt......... then it's hilarious!!!
Tyrepower is offline   Reply With Quote
Old 11-27-2012, 12:45 AM   #12697
Tasmag
Oddometer: 15
GSXR Mid pipe
Was wondering if anyone new of an aus source for the TB mid pipe for the GSXR can on the DR650?
regards
Tasmag is offline   Reply With Quote
Old 11-27-2012, 01:06 PM   #12698
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,401
Originally Posted by Tasmag View Post
Was wondering if anyone new of an aus source for the TB mid pipe for the GSXR can on the DR650? regards
no help to you but the motorobike exhaust professionals at slacks creek in brisbane will make one up and fit it for $150. might be worth checking if there's a similar shop in tassie? problem is they'll need your bike and the pipe to work out the bends so it would need to be within riding distance.
B1 is offline   Reply With Quote
Old 11-27-2012, 10:21 PM   #12699
Tasmag
Oddometer: 15
Thanks B1
Will investigate the custom option.
And while I am here does anyone know of a wide front tyre for the DR, I was told of one by a fellow DR rider in Renmark earlier in the year. I think he said it was a michelin sand tyre that would just fit.
Currently running the mt21 but would like something wider on the front.
Mike
Old 11-27-2012, 11:33 PM   #12700
gavo
Slacker
gavo's Avatar
Oddometer: 1,839
I had a mate years ago who raced a mini with a much modified 1100 motor He pulled the head and hand polished the ports to a mirror finish ( did I say how anal he was), anyway after one meeting he removed the head and binned it, the verdict was not enough turbulence and the fuel was not atomizing properly. This was the only new mod on a well sorted head. He also raced bikes and was a very smart fella
gavo is offline   Reply With Quote
Old 11-28-2012, 12:46 AM   #12701
Eddieb
Eddieb's Avatar
Oddometer: 995
BST40 Dynojet question
I've just acquired another DR, this one has the stock BST fitted with fully opened airbox, Cycleworks pipe and a dynojet kit fitted.
It idles fine but has the hugest bog just as you come off idle. Whats that usually a sign of? I'm guessing the pilot jet is wrong but I don't know whether it would be too rich or too lean.
This bog also exhibits itself in higher gears at certain speeds, e.g. 3rd at about 60km/h and 4th at about 80km/h.
I'm not sure what jets are in it or the needle position yet but I'm planning on opening it up over the next few days. I have the remainder of the dynojet kit which has a DJ150 jet left in it and 155 & 170 jets though I'm not sure if they are DJ or stock jets.
'05 DR650 - '06 Wee Strom - '86 BMW R80 with Velorex sidecar - '67 Ducati 250 Mark 3 Narrow Case
www.AdventureRidingNZ.co.nz Free GPS tracks for New Zealand, over 60 Owners and workshop manual downloads, ADV bike specs chart & more
Eddieb is online now   Reply With Quote
Old 11-28-2012, 01:47 PM   #12702
loxsmith
Good ol days my arse
loxsmith's Avatar
Location: Ex. Little village called Brisbane, Australia
Oddometer: 443
I think the Cheng Shin 3.25/3.50 - 21 is the widest I have seen
More info here http://issuu.com/mcleod/docs/chengsh...owFlipBtn=true
Glen
Thanks B1
Mike
Feb 2014, currently travelling the America's on a Tiger 800XC
Live every day like it's your last, one day you'll get it right!!!
loxsmith is offline   Reply With Quote
Old 11-28-2012, 01:55 PM   #12703
B1
B1's Avatar
Oddometer: 3,401
before messing around with jets, might be worth looking at the choke... it's just a plastic bolt (?!) that screws into the carby body. i think i remember reading somewhere that they can get a bit sticky, or previous owners might strip the thread etc and create issues. not sure if that would create the bogs you are getting but worth checking the easy stuff like this first.
free enduro training vids for gumbies here
Old 11-28-2012, 02:21 PM   #12704
Gee1
Oddometer: 168
[QUOTE=Eddieb;20132495]I've just acquired another DR, this one has the stock BST fitted with fully opened airbox, Cycleworks pipe and a dynojet kit fitted.
I had the same problem when setting up my DR. Try mucking around with the air mixture screw. Very small adjustments can make all the difference.
G1
Gee1 is offline   Reply With Quote
Old 11-28-2012, 03:45 PM   #12705
0405canvet
Oddometer: 391
jetting
Good advise from B1, even if he rides a bike with the engine backwards! My experience with the DJ needle is that most people run the needle too rich.Try the middle clip position first. I have even run the second clip position when the weather is really hot. Mixture screw should be around 1 3/4 plus or minus 1/4 turn. Stock pilot is #40 and may be partially plugged so clean or replace. Good luck!
0405canvet is offline   Reply With Quote
Times are GMT -7.   It's 12:32 AM.
